Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 25
Thread: ASME PTC Collection
    Nov 2010
    Sweden
    ASME PTC Collection
    Hey people!
    Who can share the ASME PTC Collection???
    ASME PTCs on Power Production
    PTC 6* Steam Turbines
    PTC 6S* Procedures for Routine Performance Test of Steam Turbines
    PTC 6.2* Steam Turbines in Combined Cycles
    PTC 17* Reciprocating Internal Combustion Engines
    PTC 18* Hydraulic Turbines and Pump Turbines
    PTC 22* Gas Turbines
    PTC 29* Speed-Governing Systems for Hydraulic Turbine Generator Units
    PTC 42* Wind Turbines
    PTC 46* Overall Plant Performance
    PTC 48* Overall Plant Performance with Carbon Capture (under development)
    PTC 50* Fuel Cell Power Systems Performance
    PTC 52* Performance Test Code for Concentrating Solar Power Plants (under development)
    PTC 55* Gas Turbine Aircraft Engines
    PTC 70* Ramp Rates
    POM 101* Performance Related Outage Inspections
    POM 102* Operating Walkdowns of Power Plants (under development)
    PTC PM* Performance Monitoring Guidelines for Power Plants
    ASME PTCs on Combustion and Heat Transfer
    PTC 4* Fired Steam Generators
    PTC 4.2* Coal Pulverizers
    PTC 4.3* Air Heaters
    PTC 4.4* Gas Turbine Heat Recovery Steam Generators
    PTC 12.1* Closed Feedwater Heaters
    PTC 12.2* Steam Surface Condensers
    PTC 12.4* Moisture Separator Reheaters
    PTC 12.5* Single Phase Heat Exchangers
    PTC 23* Atmospheric Water Cooling Equipment
    PTC 30* Air-Cooled Heat Exchangers
    PTC 30.1* Air Cooled Steam Condensers
    PTC 34* Waste Combustors with Energy Recovery
    PTC 51* Gas Turbine Compressor Inlet Air Conditioning Equipment
    ASME PTCs on Fluid Handling
    PTC 8.2* Centrifugal Pumps
    PTC 10* Compressors and Exhausters
    PTC 11* Fans
    PTC 12.3* Deaerators
    PTC 13* Blowers (under development)
    PTC 19.11* Steam and Water Sampling* Conditioning* and Analysis in the Power Cycle
    PTC 19.23* Guidance Manual for Model Testing
    PTC 24* Ejectors
    PTC 25* Pressure Relief Devices
    PTC 31* High Purity Water Treatment Systems
    PTC 39* Steam Traps
    ASME PTCs on Emissions
    PTC 19.10* Flue and Exhaust Gas Analysis
    PTC 21* Particulate Matter Collection Equipment
    PTC 28* Determining the Properties of Fine Particulate Matter
    PTC 40* Flue Gas Desulfurization Units
    ASME General Document on Analytical Techniques
    PTC 19.1* Test Uncertainty
    ASME General Documents on Measurement of Process Parameters and Associated Phenomena
    PTC 19.2* Pressure Measurement
    PTC 19.3* Temperature Measurement
    PTC 19.5* Flow Measurement
    PTC 19.6* Electrical Power Measurement (under development)
    PTC 19.7* Measurement of Shaft Power
    PTC 19.22* Data Acquisition Systems
    PTC 36* Measurement of Industrial Sound
    B133.6* Gas Turbine Installation Sound Emissions
    ASME General Documents on Guiding Information
    PTC 1* General Instructions
    PTC 2* Definitions and Values
    PTC 19.3 TW* Thermowells
    MORE INFO HERE....
  3. Re: ASME PTC Collection
    Any body can post if having
    Join us in Telegram and we share all of you want ;-)
    plz share please
    Download at here
    Thanks a lot for the collection
    Nov 2010
    Sweden
    Thanks!!! Are they latest edition?
    Quote Originally Posted by a7k42 View Post
    Download at here
    Thank a lot.
    Quote Originally Posted by raz View Post
    I'm not sure. You should check carefully before use.
  13. Re: ASME PTC Collection
    Thanks a lot for collection...
  14. Re: ASME PTC Collection
    Many thanks and huge respect for you!!!
  16. Re: ASME PTC Collection
    Many thanks* a7k42!
  1. ASME B31.3, ASME B31.4, ASME B31.8 Minimum Allowable Wall Thickness Calculations
    By Jon4242 in forum Engineering Spreadsheets & Presentations
    Last Post: 08-13-2024, 12:03 PM
  2. ASME Piping & Pressure Vessel Design Collection
    By mkhurram79 in forum Pipeline And Fluid Flow
    Last Post: 04-20-2013, 10:40 PM
  3. ASME Collection for Process Vessel and Piping Design
    By bhartendu in forum Oil And Gas Production
    Last Post: 01-20-2011, 07:48 AM
  4. ASME B31.3 - Collection
    By Azad in forum Mechanical Engineering
    Last Post: 05-05-2010, 07:05 PM
  5. ASME collection
    By amshah in forum Instrumentation & Control
    Last Post: 07-07-2009, 09:26 PM
