Results 1 to 5 of 5
Thread: ISO Collection 113/300:ISO/TC 33 - Refractories
    full list:
    ISO 528:1983 Refractory products -- Determination of pyrometric cone equivalent (refractoriness)
    ISO 836:2001 Terminology for refractories
    ISO 1146:1988 Pyrometric reference cones for laboratory use -- Specification
    ISO 1893:2007 Refractory products -- Determination of refractoriness under load -- Differential method with rising temperature
    ISO 1927-1:2012 Monolithic (unshaped) refractory products -- Part 1: Introduction and classification
    ISO 1927-2:2012 Monolithic (unshaped) refractory products -- Part 2: Sampling for testing
    ISO 1927-3:2012 Monolithic (unshaped) refractory products -- Part 3: Characterization as received
    ISO 1927-4:2012 Monolithic (unshaped) refractory products -- Part 4: Determination of consistency of castables
    ISO 1927-5:2012 Monolithic (unshaped) refractory products -- Part 5: Preparation and treatment of test pieces
    ISO 1927-6:2012 Monolithic (unshaped) refractory products -- Part 6: Measurement of physical properties
    ISO 1927-7:2012 Monolithic (unshaped) refractory products -- Part 7: Tests on pre-formed shapes
    ISO 1927-8:2012 Monolithic (unshaped) refractory products -- Part 8: Determination of complementary properties
    ISO 2245:2006 Shaped insulating refractory products -- Classification
    ISO 2477:2005 Shaped insulating refractory products -- Determination of permanent change in dimensions on heating
    ISO 2478:1987 Dense shaped refractory products -- Determination of permanent change in dimensions on heating
    ISO 3187:1989 Refractory products -- Determination of creep in compression
    ISO 5013:1985 Refractory products -- Determination of modulus of rupture at elevated temperatures
    ISO 5014:1997 Dense and insulating shaped refractory products -- Determination of modulus of rupture at ambient temperature
    ISO 5016:1997 Shaped insulating refractory products -- Determination of bulk density and true porosity
    ISO 5017:2013 Dense shaped refractory products -- Determination of bulk density* apparent porosity and true porosity
    ISO 5018:1983 Refractory materials -- Determination of true density
    ISO 5019-1:1984 Refractory bricks -- Dimensions -- Part 1: Rectangular bricks
    ISO 5019-2:1984 Refractory bricks -- Dimensions -- Part 2: Arch bricks
    ISO 5019-3:1984 Refractory bricks -- Dimensions -- Part 3: Rectangular checker bricks for regenerative furnaces
    ISO 5019-4:1988 Refractory bricks -- Dimensions -- Part 4: Dome bricks for electric arc furnace roofs
    ISO 5019-5:1984 Refractory bricks -- Dimensions -- Part 5: Skewbacks
    ISO 5019-6:2005 Refractory bricks -- Dimensions -- Part 6: Basic bricks for oxygen steel-making converters
    ISO 5022:1979 Shaped refractory products -- Sampling and acceptance testing
    ISO 5417:1986 Refractory bricks for use in rotary kilns -- Dimensions
    ISO 8656-1:1988 Refractory products -- Sampling of raw materials and unshaped products -- Part 1: Sampling scheme
    ISO 8840:1987 Refractory materials -- Determination of bulk density of granular materials (grain density)
    ISO 8841:1991 Dense* shaped refractory products -- Determination of permeability to gases
    ISO 8890:1988 Dense shaped refractory products -- Determination of resistance to sulfuric acid
    ISO 8894-1:2010 Refractory materials -- Determination of thermal conductivity -- Part 1: Hot-wire methods (cross-array and resistance thermometer)
    ISO 8894-2:2007 Refractory materials -- Determination of thermal conductivity -- Part 2: Hot-wire method (parallel)
    ISO 8895:2004 Shaped insulating refractory products -- Determination of cold crushing strength
    ISO 9205:1988 Refractory bricks for use in rotary kilns -- Hot-face identification marking
    ISO 10058-1:2008 Chemical analysis of magnesite and dolomite refractory products (alternative to the X-ray fluorescence method) -- Part 1: Apparatus* reagents* dissolution and determination of gravimetric silica
    ISO 10058-2:2008 Chemical analysis of magnesite and dolomite refractory products (alternative to the X-ray fluorescence method) -- Part 2: Wet chemical analysis
    ISO 10058-3:2008 Chemical analysis of magnesite and dolomite refractory products (alternative to the X-ray fluorescence method) -- Part 3: Flame atomic absorption spectrophotometry (FAAS) and inductively coupled plasma atomic emission spectrometry (ICP-AES)
    ISO 10059-1:1992 Dense* shaped refractory products -- Determination of cold compressive strength -- Part 1: Referee test without packing
    ISO 10059-2:2003 Dense* shaped refractory products -- Determination of cold compressive strength -- Part 2: Test with packing
    ISO 10060:1993 Dense* shaped refractory products -- Test methods for products containing carbon
    ISO 10080:1990 Refractory products -- Classification of dense* shaped acid-resisting products
    ISO 10081-1:2003 Classification of dense shaped refractory products -- Part 1: Alumina-silica
    ISO 10081-2:2003 Classification of dense shaped refractory products -- Part 2: Basic products containing less than 7 % residual carbon
    ISO 10081-2:2003/Cor 1:2008 Classification of dense shaped refractory products -- Part 2: Basic products containing less than 7 % residual carbon
    ISO 10081-3:2003 Classification of dense shaped refractory products -- Part 3: Basic products containing from 7 % to 50 % residual carbon
    ISO 10081-4:2014 Classification of dense shaped refractory products -- Part 4: Special products
    ISO 10635:1999 Refractory products -- Methods of test for ceramic fibre products
    ISO 12676:2000 Refractory products -- Determination of resistance to carbon monoxide
    ISO 12677:2011 Chemical analysis of refractory products by X-ray fluorescence (XRF) -- Fused cast-bead method
    ISO 12678-1:1996 Refractory products -- Measurement of dimensions and external defects of refractory bricks -- Part 1: Dimensions and conformity to drawings
    ISO 12678-2:1996 Refractory products -- Measurement of dimensions and external defects of refractory bricks -- Part 2: Corner and edge defects and other surface imperfections
    ISO 12680-1:2005 Methods of test for refractory products -- Part 1: Determination of dynamic Young's modulus (MOE) by impulse excitation of vibration
    ISO 13765-1:2004 Refractory mortars -- Part 1: Determination of consistency using the penetrating cone method
    ISO 13765-2:2004 Refractory mortars -- Part 2: Determination of consistency using the reciprocating flow table method
    ISO 13765-3:2004 Refractory mortars -- Part 3: Determination of joint stability
    ISO 13765-4:2004 Refractory mortars -- Part 4: Determination of flexural bonding strength
    ISO 13765-5:2004 Refractory mortars -- Part 5: Determination of grain size distribution (sieve analysis)
    ISO 13765-6:2004 Refractory mortars -- Part 6: Determination of moisture content of ready-mixed mortars
    ISO 14719:2011 Chemical analysis of refractory material glass and glazes -- Determination of Fe2+ and Fe3+ by the spectral photometric method with 1*10-phenanthroline
    ISO 14720-1:2013 Testing of ceramic raw and basic materials -- Determination of sulfur in powders and granules of non-oxidic ceramic raw and basic materials -- Part 1: Infrared measurement methods
    ISO 14720-2:2013 Testing of ceramic raw and basic materials -- Determination of sulfur in powders and granules of non-oxidic ceramic raw and basic materials -- Part 2: Inductively coupled plasma optical emission spectrometry (ICP/OES) or ion chromatography after burning i
    ISO 16282:2007 Methods of test for dense shaped refractory products -- Determination of resistance to abrasion at ambient temperature
    ISO 16334:2013 Monolithic refractory products -- Determination of resistance to explosive spalling
    ISO 16349:2015 Refractory materials -- Determination of abrasion resistance at elevated temperature
    ISO 16835:2014 Refractory products -- Determination of thermal expansion
    ISO 18886:2016 Refractory test-piece preparation -- Gunning refractory panels by wet gunning techniques
    ISO 20182:2008 Refractory test-piece preparation -- Gunning refractory panels by the pneumatic-nozzle mixing type guns
    ISO 20565-1:2008 Chemical analysis of chrome-bearing refractory products and chrome-bearing raw materials (alternative to the X-ray fluorescence method) -- Part 1: Apparatus* reagents* dissolution and determination of gravimetric silica
    ISO 20565-2:2008 Chemical analysis of chrome-bearing refractory products and chrome-bearing raw materials (alternative to the X-ray fluorescence method) -- Part 2: Wet chemical analysis
    ISO 20565-3:2008 Chemical analysis of chrome-bearing refractory products and chrome-bearing raw materials (alternative to the X-ray fluorescence method) -- Part 3: Flame atomic absorption spectrometry (FAAS) and inductively coupled plasma atomic emission spectrometry (ICP
    ISO 21068-1:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products -- Part 1: General information and sample preparation
    ISO 21068-2:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products -- Part 2: Determination of loss on ignition* total carbon* free carbon and silicon carbide* total and free silica and total and free silicon
    ISO 21068-3:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products -- Part 3: Determination of nitrogen* oxygen and metallic and oxidic constituents
    ISO 21078-1:2008 Determination of boron (III) oxide in refractory products -- Part 1: Determination of total boron (III) oxide in oxidic materials for ceramics* glass and glazes
    ISO 21078-2:2006 Determination of boron(III) oxide in refractory products -- Part 2: Acid extraction method for the determination of boron(III) oxide in binder components
    ISO 21079-1:2008 Chemical analysis of refractories containing alumina* zirconia and silica -- Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) -- Part 1: Apparatus* reagents and dissolution
    ISO 21079-2:2008 Chemical analysis of refractories containing alumina* zirconia* and silica -- Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) -- Part 2: Wet chemical analysis
    ISO 21079-3:2008 Chemical analysis of refractories containing alumina* zirconia* and silica -- Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) -- Part 3: Flame atomic absorption spectrophotometry (FAAS) and inductivel
    ISO 21587-1:2007 Chemical analysis of aluminosilicate refractory products (alternative to the X-ray fluorescence method) -- Part 1: Apparatus* reagents* dissolution and gravimetric silica
    ISO 21587-2:2007 Chemical analysis of aluminosilicate refractory products (alternative to the X-ray fluorescence method) -- Part 2: Wet chemical analysis
    ISO 21587-3:2007 Chemical analysis of aluminosilicate refractory products (alternative to the X-ray fluorescence method) -- Part 3: Inductively coupled plasma and atomic absorption spectrometry methods
    ISO/TR 21828:2010 Guidance on standards available for preparation and testing of monolithic* unshaped refractory products
    ISO 22016:2015 Determination of sulfur in refractory products and raw materials by gravimetric* photometric and titrimetric methods
    ISO 26845:2008 Chemical analysis of refractories -- General requirements for wet chemical analysis* atomic absorption spectrometry (AAS) and inductively coupled plasma atomic emission spectrometry (ICP-AES) methods
    missing are:
    links:
    or
    Re: ISO/TC 33 - Refractories
    ISO 5022- clear ver.
    Attached Files Attached Files
    Re: ISO Collection 113/300:ISO/TC 33 - Refractories
    nothing changed* same still missing:
    new link:
    update:
    added missing or EN or better qualities:
    still missing:
    http://www.mediafire.com/file/zi66qxopm4o1azk/ISO_113-Refracrtories_%2818-06-2017%29.rar
    full list 27.12.2017.
    ISO 5017:2013 Dense shaped refractory products -- Determination of bulk density, apparent porosity and true porosity
    ISO 8841:1991 Dense, shaped refractory products -- Determination of permeability to gases
    ISO 10058-1:2008 Chemical analysis of magnesite and dolomite refractory products (alternative to the X-ray fluorescence method) -- Part 1: Apparatus, reagents, dissolution and determination of gravimetric silica
    ISO 10059-1:1992 Dense, shaped refractory products -- Determination of cold compressive strength -- Part 1: Referee test without packing
    ISO 10059-2:2003 Dense, shaped refractory products -- Determination of cold compressive strength -- Part 2: Test with packing
    ISO 10060:1993 Dense, shaped refractory products -- Test methods for products containing carbon
    ISO 10080:1990 Refractory products -- Classification of dense, shaped acid-resisting products
    ISO 14719:2011 Chemical analysis of refractory material glass and glazes -- Determination of Fe2+ and Fe3+ by the spectral photometric method with 1,10-phenanthroline
    ISO 20565-1:2008 Chemical analysis of chrome-bearing refractory products and chrome-bearing raw materials (alternative to the X-ray fluorescence method) -- Part 1: Apparatus, reagents, dissolution and determination of gravimetric silica
    ISO 21068-2:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products -- Part 2: Determination of loss on ignition, total carbon, free carbon and silicon carbide, total and free silica and total and free silicon
    ISO 21068-3:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products -- Part 3: Determination of nitrogen, oxygen and metallic and oxidic constituents
    ISO 21078-1:2008 Determination of boron (III) oxide in refractory products -- Part 1: Determination of total boron (III) oxide in oxidic materials for ceramics, glass and glazes
    ISO 21079-1:2008 Chemical analysis of refractories containing alumina, zirconia and silica -- Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) -- Part 1: Apparatus, reagents and dissolution
    ISO 21079-2:2008 Chemical analysis of refractories containing alumina, zirconia, and silica -- Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) -- Part 2: Wet chemical analysis
    ISO 21079-3:2008 Chemical analysis of refractories containing alumina, zirconia, and silica -- Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) -- Part 3: Flame atomic absorption spectrophotometry (FAAS) and inductivel
    ISO 21587-1:2007 Chemical analysis of aluminosilicate refractory products (alternative to the X-ray fluorescence method) -- Part 1: Apparatus, reagents, dissolution and gravimetric silica
    ISO/TR 21828:2010 Guidance on standards available for preparation and testing of monolithic, unshaped refractory products
    ISO 22016:2015 Determination of sulfur in refractory products and raw materials by gravimetric, photometric and titrimetric methods
    ISO 26845:2008 Chemical analysis of refractories -- General requirements for wet chemical analysis, atomic absorption spectrometry (AAS) and inductively coupled plasma atomic emission spectrometry (ICP-AES) methods
    the missing:
  1. API 560-Refractories requirements
    By RefMet in forum Oil And Gas Process
    Last Post: 08-13-2018, 02:31 PM
