Results 1 to 6 of 6
Thread: ISO Collection 122/300:ISO/TC 60 - Gears
    Standards and projects under the direct responsibility of ISO/TC 60 Secretariat
    ISO 53:1998 Cylindrical gears for general and heavy engineering -- Standard basic rack tooth profile
    ISO 54:1996 Cylindrical gears for general engineering and for heavy engineering -- Modules
    ISO 677:1976 Straight bevel gears for general engineering and heavy engineering -- Basic rack
    ISO 678:1976 Straight bevel gears for general engineering and heavy engineering -- Modules and diametral pitches
    ISO 1328-1:2013 Cylindrical gears -- ISO system of flank tolerance classification -- Part 1: Definitions and allowable values of deviations relevant to flanks of gear teeth
    ISO 1328-2:1997 Cylindrical gears -- ISO system of accuracy -- Part 2: Definitions and allowable values of deviations relevant to radial composite deviations and runout information
    ISO 8579-1:2002 Acceptance code for gear units -- Part 1: Test code for airborne sound
    ISO/TR 10064-1:1992 Code of inspection practice -- Part 1: Inspection of corresponding flanks of gear teeth
    ISO/TR 10064-1:1992/Cor 1:2006 Code of inspection practice -- Part 1: Inspection of corresponding flanks of gear teeth
    ISO/TR 10064-2:1996 Code of inspection practice -- Part 2: Inspection related to radial composite deviations* runout* tooth thickness and backlash
    ISO/TR 10064-2:1996/Cor 1:2001 Code of inspection practice -- Part 2: Inspection related to radial composite deviations* runout* tooth thickness and backlash
    ISO/TR 10064-2:1996/Cor 2:2006 Code of inspection practice -- Part 2: Inspection related to radial composite deviations* runout* tooth thickness and backlash
    ISO/TR 10064-3:1996 Code of inspection practice -- Part 3: Recommendations relative to gear blanks* shaft centre distance and parallelism of axes
    ISO/TR 10064-3:1996/Cor 1:2006 Code of inspection practice -- Part 3: Recommendations relative to gear blanks* shaft centre distance and parallelism of axes
    ISO/TR 10064-4:1998 Code of inspection practice -- Part 4: Recommendations relative to surface texture and tooth contact pattern checking
    ISO/TR 10064-4:1998/Cor 1:2006 Code of inspection practice -- Part 4: Recommendations relative to surface texture and tooth contact pattern checking
    ISO/TR 10064-5:2005 Code of inspection practice -- Part 5: Recommendations relative to evaluation of gear measuring instruments
    ISO/TR 10064-5:2005/Cor 1:2006 Code of inspection practice -- Part 5: Recommendations relative to evaluation of gear measuring instruments
    ISO/TR 10064-6:2009 Code of inspection practice -- Part 6: Bevel gear measurement methods
    ISO 17485:2006 Bevel gears -- ISO system of accuracy
    ISO 18653:2003 Gears -- Evaluation of instruments for the measurement of individual gears
    IEC 61400-4:2012 Wind turbines -- Part 4: Design requirements for wind turbine gearboxes
    Nomenclature and wormgearing
    ISO 701:1998 International gear notation -- Symbols for geometrical data
    ISO 1122-1:1998 Vocabulary of gear terms -- Part 1: Definitions related to geometry
    ISO 1122-1:1998/Cor 1:1999 Vocabulary of gear terms -- Part 1: Definitions related to geometry
    ISO 1122-1:1998/Cor 2:2009 Vocabulary of gear terms -- Part 1: Definitions related to geometry
    ISO 1122-2:1999 Vocabulary of gear terms -- Part 2: Definitions related to worm gear geometry
    ISO 2490:2007 Solid (monobloc) gear hobs with tenon drive or axial keyway* 0*5 to 40 module -- Nominal dimensions
    ISO 4468:2009 Gear hobs -- Accuracy requirements
    ISO 4468:2009/Cor 1:2009 Gear hobs -- Accuracy requirements
    ISO 10825:1995 Gears -- Wear and damage to gear teeth -- Terminology
    ISO/TR 10828:2015 Worm gears -- Worm profiles and gear mesh geometry
    ISO/TR 14521:2010 Gears -- Calculation of load capacity of wormgears
    ISO 21771:2007 Gears -- Cylindrical involute gears and gear pairs -- Concepts and geometry
    Gear capacity calculation
    ISO 6336-1:2006 Calculation of load capacity of spur and helical gears -- Part 1: Basic principles* introduction and general influence factors
    ISO 6336-1:2006/Cor 1:2008 Calculation of load capacity of spur and helical gears -- Part 1: Basic principles* introduction and general influence factors
    ISO 6336-2:2006 Calculation of load capacity of spur and helical gears -- Part 2: Calculation of surface durability (pitting)
    ISO 6336-2:2006/Cor 1:2008 Calculation of load capacity of spur and helical gears -- Part 2: Calculation of surface durability (pitting)
    ISO 6336-3:2006 Calculation of load capacity of spur and helical gears -- Part 3: Calculation of tooth bending strength
    ISO 6336-3:2006/Cor 1:2008 Calculation of load capacity of spur and helical gears -- Part 3: Calculation of tooth bending strength
    ISO 6336-5:2016 Calculation of load capacity of spur and helical gears -- Part 5: Strength and quality of materials
    ISO 6336-6:2006 Calculation of load capacity of spur and helical gears -- Part 6: Calculation of service life under variable load
    ISO 6336-6:2006/Cor 1:2007 Calculation of load capacity of spur and helical gears -- Part 6: Calculation of service life under variable load
    ISO 9083:2001 Calculation of load capacity of spur and helical gears -- Application to marine gears
    ISO 9085:2002 Calculation of load capacity of spur and helical gears -- Application for industrial gears
    ISO 10300-1:2014 Calculation of load capacity of bevel gears -- Part 1: Introduction and general influence factors
    ISO 10300-2:2014 Calculation of load capacity of bevel gears -- Part 2: Calculation of surface durability (pitting)
    ISO 10300-3:2014 Calculation of load capacity of bevel gears -- Part 3: Calculation of tooth root strength
    ISO 13691:2001 Petroleum and natural gas industries -- High-speed special-purpose gear units
    ISO 14104:2014 Gears -- Surface temper etch inspection after grinding* chemical method
    ISO/TR 14179-1:2001 Gears -- Thermal capacity -- Part 1: Rating gear drives with thermal equilibrium at 95 °C sump temperature
    ISO/TR 14179-2:2001 Gears -- Thermal capacity -- Part 2: Thermal load-carrying capacity
    ISO 14635-1:2000 Gears -- FZG test procedures -- Part 1: FZG test method A/8*3/90 for relative scuffing load-carrying capacity of oils
    ISO 14635-2:2004 Gears -- FZG test procedures -- Part 2: FZG step load test A10/16* 6R/120 for relative scuffing load-carrying capacity of high EP oils
    ISO 14635-3:2005 Gears -- FZG test procedures -- Part 3: FZG test method A/2* 8/50 for relative scuffing load-carrying capacity and wear characteristics of semifluid gear greases
    ISO/TR 15144-1:2014 Calculation of micropitting load capacity of cylindrical spur and helical gears -- Part 1: Introduction and basic principles
    ISO/TR 15144-2:2014 Calculation of micropitting load capacity of cylindrical spur and helical gears -- Part 2: Examples of calculation for micropitting
    ISO/TR 18792:2008 Lubrication of industrial gear drives
    ISO/TR 22849:2011 Design recommendations for bevel gears
    ISO 23509:2016 Bevel and hypoid gear geometry
    the missing are;
    links:
    or
    Re: ISO/TC 60 - Gears
    Re: ISO Collection 122/300:ISO/TC 60 - Gears
    update:
    ISO 9085:2002 Calculation of load capacity of spur and helical gears -- Application for industrial gears - added missing standard
    ISO/TR 10064-4:1998 Code of inspection practice -- Part 4: Recommendations relative to surface texture and tooth contact pattern checking - added missing standard thanks to eden0914
    the only 1 missing now is:
    new link:
  6. Re: ISO Collection 122/300:ISO/TC 60 - Gears
    update:
    missing or new or BQ or EN:
    ISO 14104:2017 Gears -- Surface temper etch inspection after grinding* chemical method
    complete!
    full list 28.12.2017.
    ISO/TR 10064-1:2017 Code of inspection practice -- Part 1: Measurement of cylindrical gear tooth flanks
    ISO/TR 10064-2:1996 Code of inspection practice -- Part 2: Inspection related to radial composite deviations, runout, tooth thickness and backlash
    ISO/TR 10064-2:1996/Cor 1:2001 Code of inspection practice -- Part 2: Inspection related to radial composite deviations, runout, tooth thickness and backlash
    ISO/TR 10064-2:1996/Cor 2:2006 Code of inspection practice -- Part 2: Inspection related to radial composite deviations, runout, tooth thickness and backlash
    ISO/TR 10064-3:1996 Code of inspection practice -- Part 3: Recommendations relative to gear blanks, shaft centre distance and parallelism of axes
    ISO/TR 10064-3:1996/Cor 1:2006 Code of inspection practice -- Part 3: Recommendations relative to gear blanks, shaft centre distance and parallelism of axes
    ISO 2490:2007 Solid (monobloc) gear hobs with tenon drive or axial keyway, 0,5 to 40 module -- Nominal dimensions
    ISO 6336-1:2006 Calculation of load capacity of spur and helical gears -- Part 1: Basic principles, introduction and general influence factors
    ISO 6336-1:2006/Cor 1:2008 Calculation of load capacity of spur and helical gears -- Part 1: Basic principles, introduction and general influence factors
    ISO/TS 6336-20:2017 Calculation of load capacity of spur and helical gears -- Part 20: Calculation of scuffing load capacity (also applicable to bevel and hypoid gears) -- Flash temperature method
    ISO/TS 6336-21:2017 Calculation of load capacity of spur and helical gears -- Part 21: Calculation of scuffing load capacity (also applicable to bevel and hypoid gears) -- Integral temperature method
    ISO/TR 6336-30:2017 Calculation of load capacity of spur and helical gears -- Part 30: Calculation examples for the application of ISO 6336 parts 1,2,3,5
    ISO/TR 10300-30:2017 Calculation of load capacity of bevel gears -- Part 30: ISO rating system for bevel and hypoid gears -- Sample calculations
    ISO 14104:2017 Gears -- Surface temper etch inspection after grinding, chemical method
    ISO 14635-1:2000 Gears -- FZG test procedures -- Part 1: FZG test method A/8,3/90 for relative scuffing load-carrying capacity of oils
    ISO 14635-2:2004 Gears -- FZG test procedures -- Part 2: FZG step load test A10/16, 6R/120 for relative scuffing load-carrying capacity of high EP oils
    ISO 14635-3:2005 Gears -- FZG test procedures -- Part 3: FZG test method A/2, 8/50 for relative scuffing load-carrying capacity and wear characteristics of semifluid gear greases
    the missing:
  1. Cylindrical Gears
    By selmagis in forum Mechanical Engineering
    Last Post: 01-23-2017, 11:10 PM
  2. BS 721Part - 2 Reg. for Specification of Worm Gears Metric Units
    By saahil in forum Mechanical Engineering
    Last Post: 12-09-2015, 08:38 PM
  3. ASM - Heat Treatment of Gears: A Practical Guide for Engineers
    By vfq3481 in forum Mechanical Engineering
    Last Post: 10-28-2015, 08:47 AM
  4. Gears
    By Han Ah kwang in forum Mechanical Engineering
    Last Post: 02-19-2015, 10:19 AM
  5. Request ISO TC60 Standards (gears)
    By TCZ in forum Mechanical Engineering
    Last Post: 08-24-2012, 07:44 PM
