Standards and projects under the direct responsibility of ISO/TC 21 Secretariat
ISO 8421-1:1987 Fire protection -- Vocabulary -- Part 1: General terms and phenomena of fire
ISO 8421-2:1987 Fire protection -- Vocabulary -- Part 2: Structural fire protection
ISO 8421-3:1989 Fire protection -- Vocabulary -- Part 3: Fire detection and alarm
ISO 8421-4:1990 Fire protection -- Vocabulary -- Part 4: Fire extinction equipment
ISO 8421-5:1988 Fire protection -- Vocabulary -- Part 5: Smoke control
ISO 8421-6:1987 Fire protection -- Vocabulary -- Part 6: Evacuation and means of escape
ISO 8421-7:1987 Fire protection -- Vocabulary -- Part 7: Explosion detection and suppression means
ISO 8421-8:1990 Fire protection -- Vocabulary -- Part 8: Terms specific to fire-fighting* rescue services and handling hazardous materials
ISO 16852:2016 Flame arresters -- Performance requirements* test methods and limits for use
Manually transportable fire extinguishers
ISO 3941:2007 Classification of fires
ISO 7165:2009 Fire fighting -- Portable fire extinguishers -- Performance and construction
ISO 11601:2008 Fire fighting -- Wheeled fire extinguishers -- Performance and construction
ISO/TS 11602-1:2010 Fire protection -- Portable and wheeled fire extinguishers -- Part 1: Selection and installation
ISO/TS 11602-2:2010 Fire protection -- Portable and wheeled fire extinguishers -- Part 2: Inspection and maintenance
Fire detection and alarm systems
ISO 7240-1:2014 Fire detection and alarm systems -- Part 1: General and definitions
ISO 7240-2:2003 Fire detection and alarm systems -- Part 2: Control and indicating equipment
ISO 7240-3:2010 Fire detection and alarm systems -- Part 3: Audible alarm devices
ISO 7240-4:2003 Fire detection and alarm systems -- Part 4: Power supply equipment
ISO 7240-5:2012 Fire detection and alarm systems -- Part 5: Point-type heat detectors
ISO 7240-6:2011 Fire detection and alarm systems -- Part 6: Carbon monoxide fire detectors using electro-chemical cells
ISO 7240-7:2011 Fire detection and alarm systems -- Part 7: Point-type smoke detectors using scattered light* transmitted light or ionization
ISO 7240-8:2014 Fire detection and alarm systems -- Part 8: Point-type fire detectors using a carbon monoxide sensor in combination with a heat sensor
ISO/TS 7240-9:2012 Fire detection and alarm systems -- Part 9: Test fires for fire detectors
ISO 7240-10:2012 Fire detection and alarm systems -- Part 10: Point-type flame detectors
ISO 7240-11:2011 Fire detection and alarm systems -- Part 11: Manual call points
ISO 7240-12:2014 Fire detection and alarm systems -- Part 12: Line type smoke detectors using a transmitted optical beam
ISO 7240-13:2005 Fire detection and alarm systems -- Part 13: Compatibility assessment of system components
ISO 7240-14:2013 Fire detection and alarm systems -- Part 14: Design* installation* commissioning and service of fire detection and fire alarm systems in and around buildings
ISO 7240-15:2014 Fire detection and alarm systems -- Part 15: Point-type fire detectors using smoke and heat sensors
ISO 7240-16:2007 Fire detection and alarm systems -- Part 16: Sound system control and indicating equipment
ISO 7240-17:2009 Fire detection and fire alarm systems -- Part 17: Short-circuit isolators
ISO 7240-18:2009 Fire detection and alarm systems -- Part 18: Input/output devices
ISO 7240-19:2007 Fire detection and alarm systems -- Part 19: Design* installation* commissioning and service of sound systems for emergency purposes
ISO 7240-20:2010 Fire detection and alarm systems -- Part 20: Aspirating smoke detectors
ISO 7240-21:2005 Fire detection and alarm systems -- Part 21: Routing equipment
ISO 7240-22:2007 Fire detection and alarm systems -- Part 22: Smoke-detection equipment for ducts
ISO 7240-23:2013 Fire detection and alarm systems -- Part 23: Visual alarm devices
ISO 7240-24:2016 Fire detection and fire alarm systems -- Part 24: Fire alarm loudspeakers
ISO 7240-25:2010 Fire detection and fire alarm systems -- Part 25: Components using radio transmission paths
ISO 7240-27:2009 Fire detection and alarm systems -- Part 27: Point-type fire detectors using a scattered-light* transmitted-light or ionization smoke sensor* an electrochemical-cell carbon-monoxide sensor and a heat sensor
ISO 7240-28:2014 Fire detection and alarm systems -- Part 28: Fire protection control equipment
ISO 8201:1987 Acoustics -- Audible emergency evacuation signal
ISO 12239:2010 Smoke alarms using scattered light* transmitted light or ionization
Fixed firefighting systems using water
ISO 6182-1:2014 Fire protection -- Automatic sprinkler systems -- Part 1: Requirements and test methods for sprinklers
ISO 6182-2:2012 Fire protection -- Automatic sprinkler systems -- Part 2: Requirements and test methods for wet alarm valves* retard chambers and water motor alarms
ISO 6182-3:2012 Fire protection -- Automatic sprinkler systems -- Part 3: Requirements and test methods for dry pipe valves
ISO 6182-4:1993 Fire protection -- Automatic sprinkler systems -- Part 4: Requirements and test methods for quick-opening devices
ISO 6182-5:2012 Fire protection -- Automatic sprinkler systems -- Part 5: Requirements and test methods for deluge valves
ISO 6182-6:2006 Fire protection -- Automatic sprinkler systems -- Part 6: Requirements and test methods for check valves
ISO 6182-7:2004 Fire protection -- Automatic sprinkler systems -- Part 7: Requirements and test methods for early suppression fast response (ESFR) sprinklers
ISO 6182-8:2006 Fire protection -- Automatic sprinkler systems -- Part 8: Requirements and test methods for pre-action dry alarm valves
ISO 6182-9:2005 Fire protection -- Automatic sprinkler system -- Part 9: Requirements and test methods for water mist nozzles
ISO 6182-10:2014 Fire protection -- Automatic sprinkler systems -- Part 10: Requirements and test methods for domestic sprinklers
ISO 6182-11:2003 Fire protection -- Automatic sprinkler systems -- Part 11: Requirements and test methods for pipe hangers
ISO 6182-12:2014 Fire protection -- Automatic sprinkler systems -- Part 12: Requirements and test methods for grooved-end components for steel pipe systems
ISO 6184-1:1985 Explosion protection systems -- Part 1: Determination of explosion indices of combustible dusts in air
ISO 6184-2:1985 Explosion protection systems -- Part 2: Determination of explosion indices of combustible gases in air
ISO 6184-3:1985 Explosion protection systems -- Part 3: Determination of explosion indices of fuel/air mixtures other than dust/air and gas/air mixtures
ISO 6184-4:1985 Explosion protection systems -- Part 4: Determination of efficacy of explosion suppression systems
Foam and powder media and firefighting systems using foam and powder
ISO 7076-1:2012 Fire protection - Foam fire extinguishing systems -- Part 1: Foam proportioning equipment
ISO 7076-2:2012 Fire protection - Foam fire extinguishing systems -- Part 2: Low expansion foam equipment
ISO 7076-3:2016 Fire protection -- Foam fire extinguishing systems -- Part 3: Medium expansion foam equipment
ISO 7076-4:2016 Fire protection -- Foam fire extinguishing systems -- Part 4: High expansion foam equipment
ISO 7076-5:2014 Fire protection -- Foam fire extinguishing systems -- Part 5: Fixed compressed air foam equipment
ISO 7076-6:2016 Fire protection -- Foam fire extinguishing systems -- Part 6: Vehicle mounted compressed air foam systems
ISO 7202:2012 Fire protection -- Fire extinguishing media -- Powder
ISO 7203-1:2011 Fire extinguishing media -- Foam concentrates -- Part 1: Specification for low-expansion foam concentrates for top application to water-immiscible liquids
ISO 7203-2:2011 Fire extinguishing media -- Foam concentrates -- Part 2: Specification for medium- and high-expansion foam concentrates for top application to water-immiscible liquids
ISO 7203-3:2011 Fire extinguishing media -- Foam concentrates -- Part 3: Specification for low-expansion foam concentrates for top application to water-miscible liquids
Gaseous media and firefighting systems using gas
ISO 5923:2012 Equipment for fire protection and fire fighting -- Fire extinguishing media -- Carbon dioxide
ISO 6183:2009 Fire protection equipment -- Carbon dioxide extinguishing systems for use on premises -- Design and installation
ISO 7201-1:1989 Fire protection -- Fire extinguishing media -- Halogenated hydrocarbons -- Part 1: Specifications for halon 1211 and halon 1301
ISO 7201-2:1991 Fire extinguishing media -- Halogenated hydrocarbons -- Part 2: Code of practice for safe handling and transfer procedures of halon 1211 and halon 1301
ISO/TS 12854:2009 Gaseous media fire-extinguishing systems -- Physical properties and system design -- Scaling factors for Class B fuels other than heptane
ISO 14520-1:2015 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 1: General requirements
ISO 14520-2:2016 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 2: CF3I extinguishant
ISO 14520-5:2016 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 5: FK-5-1-12 extinguishant
ISO 14520-6:2016 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 6: HCFC Blend A extinguishant
ISO 14520-8:2016 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 8: HFC 125 extinguishant
ISO 14520-9:2016 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 9: HFC 227ea extinguishant
ISO 14520-10:2016 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 10: HFC 23 extinguishant
ISO 14520-11:2016 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 11: HFC 236fa extinguishant
ISO 14520-12:2015 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 12: IG-01 extinguishant
ISO 14520-13:2015 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 13: IG-100 extinguishant
ISO 14520-14:2015 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 14: IG-55 extinguishant
ISO 14520-15:2015 Gaseous fire-extinguishing systems -- Physical properties and system design -- Part 15: IG-541 extinguishant
ISO 15779:2011 Condensed aerosol fire extinguishing systems -- Requirements and test methods for components and system design* installation and maintenance -- General requirements
ISO 16003:2008 Components for fire-extinguishing systems using gas-- Requirements and test methods -- Container valve assemblies and their actuators; selector valves and their actuators; nozzles; flexible and rigid connectors; and check valves and non-return valves
Smoke and heat control systems and components
ISO 21927-1:2008 Smoke and heat control systems -- Part 1: Specification for smoke barriers
ISO 21927-2:2006 Smoke and heat control systems -- Part 2: Specification for natural smoke and heat exhaust ventilators
ISO 21927-2:2006/Amd 1:2010 Smoke and heat control systems -- Part 2: Specification for natural smoke and heat exhaust ventilators
ISO 21927-3:2006 Smoke and heat control systems -- Part 3: Specification for powered smoke and heat exhaust ventilators
ISO 21927-3:2006/Amd 1:2010 Smoke and heat control systems -- Part 3: Specification for powered smoke and heat exhaust ventilators
ISO 21927-9:2012 Smoke and heat control systems -- Part 9: Specification for control equipment
ISO 21927-10:2011 Smoke and heat control systems -- Part 10: Specification for power output devices
missing are:
links:
or
