Results 1 to 5 of 5
Thread: ISO Collection 94/300:ISO/TC 160 - Glass in building
    Product considerations
    ISO 11479-1:2011 Glass in building -- Coated glass -- Part 1: Physical defects
    ISO 11479-2:2011 Glass in building -- Coated glass -- Part 2: Colour of façade
    ISO 11485-1:2011 Glass in building -- Curved glass -- Part 1: Terminology and definitions
    ISO 11485-2:2011 Glass in building -- Curved glass -- Part 2: Quality requirements
    ISO 11485-3:2014 Glass in building -- Curved glass -- Part 3: Requirements for curved tempered and curved laminated safety glass
    ISO 12543-1:2011 Glass in building -- Laminated glass and laminated safety glass -- Part 1: Definitions and description of component parts
    ISO 12543-2:2011 Glass in building -- Laminated glass and laminated safety glass -- Part 2: Laminated safety glass
    ISO 12543-3:2011 Glass in building -- Laminated glass and laminated safety glass -- Part 3: Laminated glass
    ISO 12543-4:2011 Glass in building -- Laminated glass and laminated safety glass -- Part 4: Test methods for durability
    ISO 12543-5:2011 Glass in building -- Laminated glass and laminated safety glass -- Part 5: Dimensions and edge finishing
    ISO 12543-6:2011 Glass in building -- Laminated glass and laminated safety glass -- Part 6: Appearance
    ISO 12543-6:2011/Cor 1:2012 Glass in building -- Laminated glass and laminated safety glass -- Part 6: Appearance
    ISO 16293-1:2008 Glass in building -- Basic soda lime silicate glass products -- Part 1: Definitions and general physical and mechanical properties
    ISO 16293-4:2016 Glass in building -- Basic soda lime silicate glass products -- Part 4: Wired patterned glass
    ISO 16293-5:2016 Glass in building -- Basic soda lime silicate glass products -- Part 5: Patterned glass
    ISO 20492-1:2008 Glass in buildings - Insulating glass -- Part 1: Durability of edge seals by climate tests
    ISO 20492-2:2008 Glass in buildings - Insulating glass -- Part 2: Chemical fogging tests
    ISO 20492-3:2010 Glass in buildings -- Insulating glass -- Part 3: Gas concentration and gas leakage
    ISO 20492-4:2010 Glass in buildings -- Insulating glass -- Part 4: Methods of test for the physical attributes of edge seals
    ISO 21690:2006 Glass in building -- Glass blocks -- Specification and test methods
    ISO 25537:2008 Glass in building -- Silvered* flat-glass mirror
    Use considerations
    ISO 1288-1:2016 Glass in building -- Determination of the bending strength of glass -- Part 1: Fundamentals of testing glass
    ISO 1288-2:2016 Glass in building -- Determination of the bending strength of glass -- Part 2: Coaxial double-ring test on flat specimens with large test surface areas
    ISO 1288-3:2016 Glass in building -- Determination of the bending strength of glass -- Part 3: Test with specimen supported at two points (four point bending)
    ISO 1288-4:2016 Glass in building -- Determination of the bending strength of glass -- Part 4: Testing of channel shaped glass
    ISO 1288-5:2016 Glass in building -- Determination of the bending strength of glass -- Part 5: Coaxial double ring test on flat specimens with small test surface areas
    ISO 9050:2003 Glass in building -- Determination of light transmittance* solar direct transmittance* total solar energy transmittance* ultraviolet transmittance and related glazing factors
    ISO 9051:2001 Glass in building -- Fire-resistant glazed assemblies containing transparent or translucent glass* for use in building
    ISO 10291:1994 Glass in building -- Determination of steady-state U values (thermal transmittance) of multiple glazing -- Guarded hot plate method
    ISO 10292:1994 Glass in building -- Calculation of steady-state U values (thermal transmittance) of multiple glazing
    ISO 10293:1997 Glass in building -- Determination of steady-state U values (thermal transmittance) of multiple glazing -- Heat flow meter method
    ISO 14438:2002 Glass in building -- Determination of energy balance value -- Calculation method
    ISO 16932:2016 Glass in building -- Destructive-windstorm-resistant security glazing -- Test and classification
    ISO 16933:2007 Glass in building -- Explosion-resistant security glazing -- Test and classification for arena air-blast loading
    ISO 16933:2007/Cor 1:2008 Glass in building -- Explosion-resistant security glazing -- Test and classification for arena air-blast loading
    ISO 16934:2007 Glass in building -- Explosion-resistant security glazing -- Test and classification by shock-tube loading
    ISO 16934:2007/Cor 1:2008 Glass in building -- Explosion-resistant security glazing -- Test and classification by shock-tube loading
    ISO 16935:2007 Glass in building -- Bullet-resistant security glazing -- Test and classification
    ISO 16935:2007/Cor 1:2008 Glass in building -- Bullet-resistant security glazing -- Test and classification
    ISO 16936-1:2005 Glass in building -- Forced-entry security glazing -- Part 1: Test and classification by repetitive ball drop
    ISO 16936-2:2005 Glass in building -- Forced-entry security glazing -- Part 2: Test and classification by repetitive impact of a hammer and axe at room temperature
    ISO 16936-3:2005 Glass in building -- Forced-entry security glazing -- Part 3: Test and classification by manual attack
    ISO 16936-4:2005 Glass in building -- Forced-entry security glazing -- Part 4: Test and classification by pendulum impact under thermally and fire stressed conditions
    ISO 16940:2008 Glass in building -- Glazing and airborne sound insulation -- Measurement of the mechanical impedance of laminated glass
    ISO 22897:2003 Glass in building -- Glazing and airborne sound insulation -- Product descriptions and determination of properties
    ISO 28278-1:2011 Glass in building -- Glass products for structural sealant glazing -- Part 1: Supported and unsupported monolithic and multiple glazing
    ISO 28278-2:2010 Glass in building -- Glass products for structural sealant glazing -- Part 2: Assembly rules
    ISO 29584:2015 Glass in building -- Pendulum impact testing and classification of safety glass
    the missing are:
    links:
    or
    Re: ISO Collection 94/300:ISO/TC 160 - Glass in building
    update:
    added missing standards:
    the missing list:
    new link:
    update:
    better quality:
    added missing:
    new missing list:
    ISO 12540:2017 Glass in building -- Tempered soda lime silicate safety glass
    ISO 16293-2:2017 Glass in building -- Basic soda lime silicate glass products -- Part 2: Float glass
    ISO 16293-3:2017 Glass in building -- Basic soda lime silicate glass products -- Part 3: Polished wired glass
    ISO 20657:2017 Glass in building -- Heat soaked tempered soda lime silicate safety glass
    full list 09.12.2017
    ISO 18543:2017 Glass in building -- Electrochromic glazings -- Accelerated ageing test and requirements
    ISO 25537:2008 Glass in building -- Silvered, flat-glass mirror
    ISO 9050:2003 Glass in building -- Determination of light transmittance, solar direct transmittance, total solar energy transmittance, ultraviolet transmittance and related glazing factors
    ISO 9051:2001 Glass in building -- Fire-resistant glazed assemblies containing transparent or translucent glass, for use in building
    complete
  1. CEN Standards Collection 134/370: CEN TC 51 - Cement & Building Limes
    Last Post: 01-22-2019, 02:50 PM
  2. CEN Standards Collection 208/370: CEN TC 129-Glass In Buidling
    Last Post: 07-03-2018, 02:39 PM
  3. Replies: 0
    Last Post: 12-23-2016, 03:36 PM
  4. Materials Literature Collection 118/200 - Glass
    Last Post: 12-10-2016, 09:06 AM
  5. Glass in building - AIRBORNE SOUND INSULATION
    By hopla1234 in forum Safety And Environment
    Last Post: 05-20-2013, 11:36 AM
