Thread: Multiphase Flow Handbook, Second Edition
    Cool Multiphase Flow Handbook, Second Edition
    Efstathios Michaelides (Editor), Clayton T. Crowe (Editor), John D. Schwarzkopf (Editor)
    CRC PRess, 2016
    The Multiphase Flow Handbook, Second Edition is a thoroughly updated and reorganized revision of the late Clayton Crowe’s work, and provides a detailed look at the basic concepts and the wide range of applications in this important area of thermal/fluids engineering. Revised by the new editors, Efstathios E. (Stathis) Michaelides and John D. Schwarzkopf, the new Second Edition begins with two chapters covering fundamental concepts and methods that pertain to all the types and applications of multiphase flow. The remaining chapters cover the applications and engineering systems that are relevant to all the types of multiphase flow and heat transfer. The twenty-one chapters and several sections of the book include the basic science as well as the contemporary engineering and technological applications of multiphase flow in a comprehensive way that is easy to follow and be understood. The editors created a common set of nomenclature that is used throughout the book, allowing readers to easily compare fundamental theory with currently developing concepts and applications. With contributed chapters from sixty-two leading experts around the world, the Multiphase Flow Handbook, Second Edition is an essential reference for all researchers, academics and engineers working with complex thermal and fluid systems.
    if you like it, buy it
    Re: Multiphase Flow Handbook, Second Edition
    Lets try it
    Thanks a lot in advance
    check libgen
    Thanks for the share
  1. Replies: 17
    Last Post: 06-06-2019, 07:51 AM
  2. Multiphase flow correlation
    By Jeff6 in forum Oil And Gas Production
    Last Post: 04-25-2016, 09:36 AM
  3. [E-book Request] Crane Fluid Flow Handbook 2009 Edition
    By polaris44 in forum Oil And Gas Process
    Last Post: 03-09-2016, 01:43 PM
  4. Multiphase Flow
    By RavenKrofft in forum Reservoir
    Last Post: 06-27-2013, 06:16 PM
  5. Multiphase flow books.
    By mkhurram79 in forum Pipeline And Fluid Flow
    Last Post: 10-30-2011, 04:22 PM
