Standards and projects under the direct responsibility of ISO/TC 149 Secretariat
ISO 6692:1981 Cycles -- Marking of cycle components
ISO 6695:2015 Cycles -- Pedal axle and crank assembly with square end fitting -- Assembly dimensions
ISO 6696:1989 Cycles -- Screw threads used in bottom bracket assemblies
ISO 6697:1994 Cycles -- Hubs and freewheels -- Assembly dimensions
ISO 6698:1989 Cycles -- Screw threads used to assemble freewheels on bicycle hubs
ISO 6699:2016 Cycles -- Handlebar centre and stem dimensions
ISO 6701:1991 Cycles -- External dimensions of spoke nipples
ISO 8488:1986 Cycles -- Screw threads used to assemble head fittings on bicycle forks
ISO 8562:1990 Cycles -- Stem wedge angle
ISO 10230:1990 Cycles -- Splined hub and sprocket -- Mating dimensions
Cycles and major sub-assemblies
ISO 4210-1:2014 Cycles -- Safety requirements for bicycles -- Part 1: Terms and definitions
ISO 4210-2:2015 Cycles -- Safety requirements for bicycles -- Part 2: Requirements for city and trekking, young adult, mountain and racing bicycles
ISO 4210-3:2014 Cycles -- Safety requirements for bicycles -- Part 3: Common test methods
ISO 4210-4:2014 Cycles -- Safety requirements for bicycles -- Part 4: Braking test methods
ISO 4210-5:2014 Cycles -- Safety requirements for bicycles -- Part 5: Steering test methods
ISO 4210-6:2015 Cycles -- Safety requirements for bicycles -- Part 6: Frame and fork test methods
ISO 4210-7:2014 Cycles -- Safety requirements for bicycles -- Part 7: Wheels and rims test methods
ISO 4210-8:2014 Cycles -- Safety requirements for bicycles -- Part 8: Pedal and drive system test methods
ISO 4210-9:2014 Cycles -- Safety requirements for bicycles -- Part 9: Saddles and seat-post test methods
ISO 6742-1:2015 Cycles -- Lighting and retro-reflective devices -- Part 1: Lighting and light signalling devices
ISO 6742-2:2015 Cycles -- Lighting and retro-reflective devices -- Part 2: Retro-reflective devices
ISO 6742-3:2015 Cycles -- Lighting and retro-reflective devices -- Part 3: Installation and use of lighting and retro-reflective devices
ISO 6742-4:2015 Cycles -- Lighting and retro-reflective devices -- Part 4: Lighting systems powered by the cycle's movement
ISO 6742-5:2015 Cycles -- Lighting and retro-reflective devices -- Part 5: Lighting systems not powered by the cycle's movement
ISO 8090:1990 Cycles -- Terminology
ISO 8098:2014 Cycles -- Safety requirements for bicycles for young children
ISO 11243:2016 Cycles -- Luggage carriers for bicycles -- Requirements and test methods
ISO 14878:2015 Cycles -- Audible warning devices -- Technical specification and test methods
the missing are:
links:
or
