Thread: Pore Pressure Prediction
  1. Pore Pressure Prediction
    Can sb help me with some question below?
    In this, and indeed many,
    petroleum basins it is
    observed that at
    shallower depths pore
    pressures are mostly
    hydrostatic. Why?
    Deeper in the basin high
    overpressures are
    commonly seen. Why?
    At intermediate depths
    overpressure
    development is more
    variable. Why?
    Note that the
    overpressure appears to
    be limited by the fracture
    pressure as represented
    by the LOT’s. Why?
    Thank you.
  3. Re: Pore Pressure Prediction
    for the first question, i think it is because of the centroid effect
    Aows K. Mohammad
  5. Re: Pore Pressure Prediction
    Q1 - in most cases these are younger sediments, where time, overburden pressure and temperature have not allowed for over-pressure to develop. Also, there is rarely the sealing or confining capacity of over laying sediments to trap building fluid pressure.
    Q2- a general rule is that with increased depth = increased compaction = increased pressure and increased temperature.
    Q3- many factors effect over pressure build-up 1st & foremost is rate of deposition & compaction.
    Q4- LOT is a test of Rock Strength, rock strength governs confining pressure. so, if a LOT is tested to 15.0 ppg (which means it took the equivalent of 15.0 pounds per gallon pressure in a wellbore's annulus to progagate fluid into the rock or to break it down) this test is done at the shallowest open hole point in order to determine a safe drilling margin between over-pressure (pore pressure) and rock strength (fracture gradient).
  1. pore pressure prediction
    By petrophysicist in forum Engineering Spreadsheets & Presentations
    Last Post: 11-20-2013, 11:34 AM
  2. Pore pressure prediction data needed
    By hakimalias in forum Geology & Exploration
    Last Post: 07-30-2011, 08:40 AM
