full list:
Standards and projects under the direct responsibility of ISO/TC 44 Secretariat
ISO 3677:2016 Filler metal for soldering and brazing -- Designation
ISO 5187:1985 Welding and allied processes -- Assemblies made with soft solders and brazing filler metals -- Mechanical test methods
ISO 11745:2010 Brazing for aerospace applications -- Qualification test for brazers and brazing operators -- Brazing of metallic components
ISO 11745:2010/AMD 1:2015 Brazing for aerospace applications -- Qualification test for brazers and brazing operators -- Brazing of metallic components
ISO 17672:2016 Brazing -- Filler metals
ISO/TS 18166:2016 Numerical welding simulation -- Execution and documentation
Welding consumables
ISO 544:2011 Welding consumables -- Technical delivery conditions for filler materials and fluxes -- Type of product, dimensions, tolerances and markings
ISO 636:2015 Welding consumables -- Rods, wires and deposits for tungsten inert gas welding of non-alloy and fine-grain steels -- Classification
ISO 1071:2015 Welding consumables - Covered electrodes, wires, rods and tubular cored electrodes for fusion welding of cast iron - Classification
ISO 2401:1972 Covered electrodes -- Determination of the efficiency, metal recovery and deposition coefficient
ISO 2560:2009 Welding consumables -- Covered electrodes for manual metal arc welding of non-alloy and fine grain steels -- Classification
ISO 3580:2010 Welding consumables -- Covered electrodes for manual metal arc welding of creep-resisting steels -- Classification
ISO 3581:2016 Welding consumables -- Covered electrodes for manual metal arc welding of stainless and heat-resisting steels -- Classification
ISO 6848:2015 Arc welding and cutting -- Nonconsumable tungsten electrodes -- Classification
ISO 12153:2011 Welding consumables -- Tubular cored electrodes for gas shielded and non-gas shielded metal arc welding of nickel and nickel alloys -- Classification
ISO 14171:2016 Welding consumables -- Solid wire electrodes, tubular cored electrodes and electrode/flux combinations for submerged arc welding of non alloy and fine grain steels -- Classification
ISO 14172: 2015 Welding consumables -- Covered electrodes for manual metal arc welding of nickel and nickel alloys -- Classification
ISO 14174:2012 Welding consumables -- Fluxes for submerged arc welding and electroslag welding -- Classification
ISO 14175:2008 Welding consumables -- Gases and gas mixtures for fusion welding and allied processes
ISO 14341:2010 Welding consumables -- Wire electrodes and weld deposits for gas shielded metal arc welding of non alloy and fine grain steels -- Classification
ISO 14343:2009 Welding consumables -- Wire electrodes, strip electrodes, wires and rods for arc welding of stainless and heat resisting steels -- Classification
ISO 14344:2010 Welding consumables -- Procurement of filler materials and fluxes
ISO 15792-1:2000 Welding consumables -- Test methods -- Part 1: Test methods for all-weld metal test specimens in steel, nickel and nickel alloys
ISO 15792-1 AMD 1:2011 Welding consumables -- Test methods -- Part 1: Test methods for all-weld metal test specimens in steel, nickel and nickel alloys
ISO 15792-2:2000 Welding consumables -- Test methods -- Part 2: Preparation of single-run and two-run technique test specimens in steel
ISO 15792-3:2011 Welding consumables -- Test methods -- Part 3: Classification testing of positional capacity and root penetration of welding consumables in a fillet weld
ISO 16834:2012 Welding consumables -- Wire electrodes, wires, rods and deposits for gas shielded arc welding of high strength steels -- Classification
ISO 17632:2015 Welding consumables -- Tubular cored electrodes for gas shielded and non-gas shielded metal arc welding of non-alloy and fine grain steels -- Classification
ISO 17633:2010 Welding consumables -- Tubular cored electrodes and rods for gas shielded and non-gas shielded metal arc welding of stainless and heat-resisting steels -- Classification
ISO 17634:2015 Welding consumables -- Tubular cored electrodes for gas shielded metal arc welding of creep-resisting steels -- Classification
ISO 17777:2016 Welding consumables -- Covered electrodes for manual metal arc welding of copper and copper alloys -- Classification
ISO 18273:2015 Welding consumables -- Wire electrodes, wires and rods for welding of aluminium and aluminium alloys -- Classification
ISO 18274:2010 Welding consumables -- Solid wire electrodes, solid strip electrodes, solid wires and solid rods for fusion welding of nickel and nickel alloys -- Classification
ISO 18275:2011 Welding consumables -- Covered electrodes for manual metal arc welding of high-strength steels -- Classification
ISO 18276:2005 Welding consumables -- Tubular cored electrodes for gas-shielded and non-gas-shielded metal arc welding of high-strength steels -- Classification
ISO 19288:2016 Welding consumables -- Solid wire electrodes, solid wires and rods for fusion welding of magnesium and magnesium alloys -- Classificati
ISO 21952:2012 Welding consumables -- Wire electrodes, wires, rods and deposits for gas shielded arc welding of creep-resisting steels -- Classification
ISO 24034:2010 Welding consumables -- Solid wire electrodes, solid wires and rods for fusion welding of titanium and titanium alloys -- Classification
ISO 24373:2008 Welding consumables -- Solid wires and rods for fusion welding of copper and copper alloys -- Classification
ISO 24598:2012 Welding consumables -- Solid wire electrodes, tubular cored electrodes and electrode-flux combinations for submerged arc welding of creep-resisting steels -- Classification
ISO 26304:2011 Welding consumables -- Solid wire electrodes, tubular cored electrodes and electrode-flux combinations for submerged arc welding of high strength steels -- Classification
Testing and inspection of welds
ISO 4136:2012 Destructive tests on welds in metallic materials -- Transverse tensile test
ISO 5173:2009 Destructive tests on welds in metallic materials -- Bend tests
ISO 5173 AMD 1:2011 Destructive tests on welds in metallic materials -- Bend tests
ISO 5178:2001 Destructive tests on welds in metallic materials -- Longitudinal tensile test on weld metal in fusion welded joints
ISO 9015-1:2001 Destructive tests on welds in metallic materials -- Hardness testing -- Part 1: Hardness test on arc welded joints
ISO 9015-2:2016 Destructive tests on welds in metallic materials -- Hardness testing -- Part 2: Microhardness testing of welded joints
ISO 9016:2012 Destructive tests on welds in metallic materials -- Impact tests -- Test specimen location, notch orientation and examination
ISO 9017:2001 Destructive tests on welds in metallic materials -- Fracture test
ISO 9018:2015 Destructive tests on welds in metallic materials -- Tensile test on cruciform and lapped joints
ISO 10675-1:2008 Non-destructive testing of welds -- Acceptance levels for radiographic testing -- Part 1: Steel, nickel, titanium and their alloys
ISO 10675-2:2010 Non-destructive testing of welds -- Acceptance levels for radiographic testing -- Part 2: Aluminium and its alloys
ISO 10863:2011 Non-destructive testing of welds -- Ultrasonic testing -- Use of time-of-flight diffraction technique (TOFD)
ISO 11666:2010 Non-destructive testing of welds -- Ultrasonic testing -- Acceptance levels
ISO 13588:2012 Non-destructive testing of welds -- Ultrasonic testing -- Use of automated phased array technology
ISO 15626:2011 Non-destructive testing of welds -- Time-of-flight diffraction technique (TOFD) -- Acceptance levels
ISO/TR 16060:2003 Destructive tests on welds in metallic materials -- Etchants for macroscopic and microscopic examination
ISO 17405:2014 Non-destructive testing -- Ultrasonic testing -- Technique of testing claddings produced by welding, rolling and explosion
ISO 17635:2010 Non-destructive testing of welds -- General rules for metallic materials
ISO 17636-1:2013 Non-destructive testing of welds -- Radiographic testing -- Part 1: X- and gamma-ray techniques with film
ISO 17636-2:2013 Non-destructive testing of welds -- Radiographic testing -- Part 2: X- and gamma-ray techniques with digital detectors
ISO 17637:2003 Non-destructive testing of welds -- Visual testing of fusion-welded joints
ISO 17638:2016 Non-destructive testing of welds -- Magnetic particle testing
ISO 17639:2003 Destructive tests on welds in metallic materials -- Macroscopic and microscopic examination of welds
ISO 17640:2010 Non-destructive testing of welds -- Ultrasonic testing -- Techniques, testing levels, and assessment
ISO 17641-1:2004 Destructive tests on welds in metallic materials -- Hot *****ing tests for weldments -- Arc welding processes -- Part 1: General
ISO 17641-2:2015 Destructive tests on welds in metallic materials -- Hot *****ing tests for weldments -- Arc welding processes -- Part 2: Self-restraint tests
ISO/TR 17641-3:2005 Destructive tests on welds in metallic materials -- Hot *****ing tests for weldments -- Arc welding processes -- Part 3: Externally loaded tests
ISO 17642-1:2004 Destructive tests on welds in metallic materials -- Cold *****ing tests for weldments -- Arc welding processes -- Part 1: General
ISO 17642-2:2005 Destructive tests on welds in metallic materials -- Cold *****ing tests for weldments -- Arc welding processes -- Part 2: Self-restraint tests
ISO 17642-3:2005 Destructive tests on welds in metallic materials -- Cold *****ing tests for weldments -- Arc welding processes -- Part 3: Externally loaded tests
ISO 17643:2015 Non-destructive testing of welds -- Eddy current testing of welds by complex-plane analysis
ISO 22825:2012 Non-destructive testing of welds -- Ultrasonic testing -- Testing of welds in austenitic steels and nickel-based alloys
ISO 22826:2005 Destructive tests on welds in metallic materials -- Hardness testing of narrow joints welded by laser and electron beam (Vickers and Knoop hardness tests)
ISO 23277:2015 Non-destructive testing of welds -- Penetrant testing -- Acceptance levels
ISO 23278:2015 Non-destructive testing of welds -- Magnetic particle testing -- Acceptance levels
ISO 23279:2010 Non-destructive testing of welds -- Ultrasonic testing -- Characterization of indications in welds
Resistance welding and allied mechanical joining
ISO 669:2016 Resistance welding -- Resistance welding equipment -- Mechanical and electrical requirements
ISO 693:1982 Dimensions of seam welding wheel blanks
ISO 865:1981 Slots in platens for projection welding machines
ISO 1089:1980 Electrode taper fits for spot welding equipment -- Dimensions
ISO 5182:2016 Resistance welding -- Materials for electrodes and ancillary equipment
ISO 5183-1:1998 Resistance welding equipment -- Electrode adaptors, male taper 1:10 -- Part 1: Conical fixing, taper 1:10
ISO 5183-2:2000 Resistance spot welding -- Electrode adaptors, male taper 1:10 -- Part 2: Parallel shank fixing for end-thrust electrodes
ISO 5184:1979 Straight resistance spot welding electrodes
ISO 5821:2009 Resistance welding -- Spot welding electrode caps
ISO 5822:1988 Spot welding equipment -- Taper plug gauges and taper ring gauges
ISO 5826:2014 Resistance welding equipment -- Transformers -- General specifications applicable to all transformers
ISO 5827:1983 Spot welding -- Electrode back-ups and clamps
ISO 5828:2001 Resistance welding equipment -- Secondary connecting cables with terminals connected to water-cooled lugs -- Dimensions and characteristics
ISO 5829:1984 Resistance spot welding -- Electrode adaptors, female taper 1 : 10
ISO 5830:1984 Resistance spot welding -- Male electrode caps
ISO 6210-1:1991 Cylinders for robot resistance welding guns -- Part 1: General requirements
ISO 7285:1995 Pneumatic cylinders for mechanized multiple spot welding
ISO 7286:1986 Graphical symbols for resistance welding equipment
ISO 7931:1985 Insulation caps and bushes for resistance welding equipment
ISO 8167:1989 Projections for resistance welding
ISO 8205-1:2002 Water-cooled secondary connection cables for resistance welding -- Part 1: Dimensions and requirements for double-conductor connection cables
ISO 8205-2:2002 Water-cooled secondary connection cables for resistance welding -- Part 2: Dimensions and requirements for single-conductor connection cables
ISO 8205-3:2012 Water-cooled secondary connection cables for resistance welding -- Part 3: Test requirements
ISO 8430-1:2016 Resistance spot welding -- Electrode holders -- Part 1: Taper fixing 1:10
ISO 8430-2:2016 Resistance spot welding -- Electrode holders -- Part 2: Morse taper fixing
ISO 8430-3:2016 Resistance spot welding -- Electrode holders -- Part 3: Parallel shank fixing for end thrust
ISO 9312:2013 Resistance welding equipment -- Insulated pins for use in electrode back-ups
ISO 9313:1989 Resistance spot welding equipment -- Cooling tubes
ISO 10656: 2016 Electric resistance welding -- Integrated transformers for welding guns
ISO 12996:2013 Mechanical joining -- Destructive testing of joints -- Specimen dimensions and test procedure for tensile shear testing of single joints
ISO 13469:2014 Mechanical joining -- Form-fit blind rivets and (lock) bolt joints -- Specifications and qualification of testing procedures
ISO 14327:2004 Resistance welding -- Procedures for determining the weldability lobe for resistance spot, projection and seam welding
ISO 14554-1:2013 Quality requirements for welding -- Resistance welding of metallic materials -- Part 1: Comprehensive quality requirements
ISO 14554-2:2013 Quality requirements for welding -- Resistance welding of metallic materials -- Part 2: Elementary quality requirements
ISO 15609-5:2011 Specification and qualification of welding procedures for metallic materials -- Welding procedure specification -- Part 5: Resistance welding
ISO 15416-12:2014 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 12: Spot, seam and projection welding
ISO 15614-13:2012 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 13: Upset (resistance butt) and flash welding
ISO 16237:2015 Mechanical joining -- Destructive testing of joints -- Specimen dimensions and test procedure for cross-tension testing of single joints
ISO 17653:2012 Resistance welding -- Destructive tests on welds in metallic materials -- Torsion test of resistance spot welds
ISO 17654:2011 Resistance welding -- Destructive tests of welds -- Pressure test of resistance seam welds
ISO 17657-1:2005 Resistance welding -- Welding current measurement for resistance welding -- Part 1: Guidelines for measurement
ISO 17657-2:2005 Resistance welding -- Welding current measurement for resistance welding -- Part 2: Welding current meter with current sensing coil
ISO 17657-3:2005 Resistance welding -- Welding current measurement for resistance welding -- Part 3: Current sensing coil
ISO 17657-4:2005 Resistance welding -- Welding current measurement for resistance welding -- Part 4: Calibration system
ISO 17657-5:2005 Resistance welding -- Welding current measurement for resistance welding -- Part 5: Verification of welding current measuring system
ISO 17677-1:2009 Resistance welding -- Vocabulary -- Part 1: Spot, projection and seam welding
ISO 18278-1:2015 Resistance welding -- Weldability -- Part 1: General requirements for the evaluation of weldability for resistance spot, seam and projection welding of metallic materials
ISO 18278-2:2016 Resistance welding -- Weldability -- Part 2: Evaluation procedures for weldability in spot welding
ISO 18592:2009 Resistance welding -- Destructive testing of welds -- Method for the fatigue testing of multi-spot-welded specimens
ISO 18594:2007 Resistance spot-, projection- and seam-welding -- Method for determining the transition resistance on aluminium and steel material
ISO 18595:2007 Resistance welding -- Spot welding of aluminium and aluminium alloys -- Weldability, welding and testing
ISO 20168:2016 Resistance welding -- Locking tapers for electrode holders and electrode caps
ISO 22829:2007 Resistance welding -- Transformer-rectifier for welding guns with integrated transformers -- Transformer-rectifier units operating at 1000 Hz frequency
Representation and terms
ISO/TR 581:2005 Weldability -- Metallic materials -- General principles
ISO 857-2:2005 Welding and allied processes -- Vocabulary -- Part 2: Soldering and brazing processes and related terms
ISO 2553:2013 Welding and allied processes -- Symbolic representation on drawings -- Welded joints
ISO 4063:2009 Welding and allied processes -- Nomenclature of processes and reference numbers
ISO 6520-1:2007 Welding and allied processes -- Classification of geometric imperfections in metallic materials -- Part 1: Fusion welding
ISO 6520-2:2013 Welding and allied processes -- Classification of geometric imperfections in metallic materials -- Part 2: Welding with pressure
ISO 6947:2011 Welding and allied processes -- Welding positions
ISO 9692-1:2013 Welding and allied processes -- Types of joint preparation -- Part 1: Manual metal arc welding, gas-shielded metal arc welding, gas welding, TIG welding and beam welding of steels
ISO 9692-2:1998 Welding and allied processes -- Joint preparation -- Part 2: Submerged arc welding of steels
ISO 9692-3:2016 Welding and allied processes -- Types of joint preparation -- Part 3: Metal inert gas welding and tungsten inert gas welding of aluminium and its alloys
ISO 9692-4:2003 Welding and allied processes -- Recommendations for joint preparation -- Part 4: Clad steels
ISO 17658:2002 Welding -- Imperfections in oxyfuel flame cuts, laser beam cuts and plasma cuts -- Terminology
ISO 17659:2002 Welding -- Multilingual terms for welded joints with illustrations
ISO/TS 17845:2004 Welding and allied processes -- Designation system for imperfections
ISO/TR 25901-1:2016 Welding and allied processes -- Vocabulary -- Part 1: General terms
ISO/TR 25901-3:2016 Welding and allied processes -- Vocabulary -- Part 3: Welding processes
ISO/TR 25901-4:2016 Welding and allied processes -- Vocabulary -- Part 4: Arc welding
Equipment for gas welding, cutting and allied processes
ISO 2503:2009 Gas welding equipment -- Pressure regulators and pressure regulators with flow-metering devices for gas cylinders used in welding, cutting and allied processes up to 300 bar (30 MPa)
ISO 2503 AMD 1:2015 Gas welding equipment -- Pressure regulators and pressure regulators with flow-metering devices for gas cylinders used in welding, cutting and allied processes up to 300 bar (30 MPa)
ISO 3821:2008 Gas welding equipment -- Rubber hoses for welding, cutting and allied processes
ISO 5171:2009 Gas welding equipment -- Pressure gauges used in welding, cutting and allied processes
ISO 5172:2006 Gas welding equipment -- Blowpipes for gas welding, heating and cutting -- Specifications and tests
ISO 5172 AMD 1:2012 Gas welding equipment -- Blowpipes for gas welding, heating and cutting -- Specifications and tests
ISO 5172 AMD 2:2015 Gas welding equipment -- Blowpipes for gas welding, heating and cutting -- Specifications and tests
ISO 5175:1987 Equipment used in gas welding, cutting and allied processes -- Safety devices for fuel gases and oxygen or compressed air -- General specifications, requirements and tests
ISO 5175 AMD 1:2015 Equipment used in gas welding, cutting and allied processes -- Safety devices for fuel gases and oxygen or compressed air -- General specifications, requirements and tests
ISO 7287:2002 Graphical symbols for thermal cutting equipment
ISO 7289:2010 Gas welding equipment -- Quick-action couplings with shut-off valves for welding, cutting and allied processes
ISO 7291:2010 Gas welding equipment -- Pressure regulators for manifold systems used in welding, cutting and allied processes up to 30 MPa (300 bar)
ISO 7291 AMD 1:2015 Gas welding equipment -- Pressure regulators for manifold systems used in welding, cutting and allied processes up to 30 MPa (300 bar)
ISO 8206:1991 Acceptance tests for oxygen cutting machines -- Reproducible accuracy -- Operational characteristics
ISO 8207:1996 Gas welding equipment -- Specification for hose assemblies for equipment for welding, cutting and allied processes
ISO 9012:2008 Gas welding equipment -- Air-aspirated hand blowpipes -- Specifications and tests
ISO 9013:2002 Thermal cutting -- Classification of thermal cuts -- Geometrical product specification and quality tolerances
ISO 9090:1989 Gas tightness of equipment for gas welding and allied processes
ISO 9539:2010 Gas welding equipment -- Materials for equipment used in gas welding, cutting and allied processes
ISO 9539 AMD 1:2013 Gas welding equipment -- Materials for equipment used in gas welding, cutting and allied processes
ISO 10225:2013 Gas welding equipment -- Marking for equipment used for gas welding, cutting and allied processes
ISO 12170:1996 Gas welding equipment -- Thermoplastic hoses for welding and allied processes
ISO 14112:1996 Gas welding equipment -- Small kits for gas brazing and welding
ISO 14113:2013 Gas welding equipment -- Rubber and plastics hose and hose assemblies for use with industrial gases up to 450 bar (45 MPa)
ISO 14114:2014 Gas welding equipment -- Acetylene manifold systems for welding, cutting and allied processes -- General requirements
ISO 15296:2004 Gas welding equipment -- Vocabulary -- Terms used for gas welding equipment
ISO 15615:2013 Gas welding equipment -- Acetylene manifold systems for welding, cutting and allied processes -- Safety requirements in high-pressure devices
ISO/TR 28821:2012 Gas welding equipment -- Hose connections for equipment for welding, cutting and allied processes -- Listing of connections which are either standardised or in common use
Health and safety
ISO 10882-1:2011 Health and safety in welding and allied processes -- Sampling of airborne particles and gases in the operator's breathing zone -- Part 1: Sampling of airborne particles
ISO 10882-2:2000 Health and safety in welding and allied processes -- Sampling of airborne particles and gases in the operator's breathing zone -- Part 2: Sampling of gases
ISO 15011-1:2009 Health and safety in welding and allied processes -- Laboratory method for sampling fume and gases -- Part 1: Determination of fume emission rate during arc welding and collection of fume for analysis
ISO 15011-2:2009 Health and safety in welding and allied processes -- Laboratory method for sampling fume and gases -- Part 2: Determination of the emission rates of carbon monoxide (CO), carbon dioxide (CO2), nitrogen monoxide (NO) and nitrogen dioxide (NO2) during arc w
ISO 15011-3:2009 Health and safety in welding and allied processes -- Laboratory method for sampling fume and gases -- Part 3: Determination of ozone emission rate during arc welding
ISO 15011-4:2006 Health and safety in welding and allied processes -- Laboratory method for sampling fume and gases -- Part 4: Fume data sheets
ISO 15011-4 :AMD 1:2008 Health and safety in welding and allied processes -- Laboratory method for sampling fume and gases -- Part 4: Fume data sheets
ISO 15011-5:2011 Health and safety in welding and allied processes -- Laboratory method for sampling fume and gases -- Part 5: Identification of thermal-degradation products generated when welding or cutting through products composed wholly or partly of organic materials
ISO/TS 15011-6:2012 Health and safety in welding and allied processes -- Laboratory method for sampling fume and gases -- Part 6: Procedure for quantitative determination of fume and gases from resistance spot welding
ISO/TS 15011-6:COR 1:2012 Health and safety in welding and allied processes -- Laboratory method for sampling fume and gases -- Part 6: Procedure for quantitative determination of fume and gases from resistance spot welding
ISO 15012-1:2013 Health and safety in welding and allied processes -- Equipment for capture and separation of welding fume -- Part 1: Requirements for testing and marking of separation efficiency
ISO 15012-2:2008 Health and safety in welding and allied processes -- Requirements, testing and marking of equipment for air filtration -- Part 2: Determination of the minimum air volume flow rate of captor hoods and nozzles
ISO 15012-4:2016 Health and safety in welding and allied processes -- Equipment for capture and separation of welding fume -- Part 4: General requirements
ISO 17846:2004 Welding and allied processes -- Health and safety -- Wordless precautionary labels for equipment and consumables used in arc welding and cutting
ISO 17916:2016 Safety of thermal cutting machines
ISO 25980:2014 Health and safety in welding and allied processes -- Transparent welding curtains, strips and screens for arc welding processes
Quality management in the field of welding
ISO 3834-1:2005 Quality requirements for fusion welding of metallic materials -- Part 1: Criteria for the selection of the appropriate level of quality requirements
ISO 3834-2:2005 Quality requirements for fusion welding of metallic materials -- Part 2: Comprehensive quality requirements
ISO 3834-3:2005 Quality requirements for fusion welding of metallic materials -- Part 3: Standard quality requirements
ISO 3834-4:2005 Quality requirements for fusion welding of metallic materials -- Part 4: Elementary quality requirements
ISO 3834-5:2015 Quality requirements for fusion welding of metallic materials -- Part 5: Documents with which it is necessary to conform to claim conformity to the quality requirements of ISO 3834-2, ISO 3834-3 or ISO 3834-4
ISO 3834-6:2007 Quality requirements for fusion welding of metallic materials -- Part 6: Guidelines on implementing ISO 3834
ISO 5817:2014 Welding -- Fusion-welded joints in steel, nickel, titanium and their alloys (beam welding excluded) -- Quality levels for imperfections
ISO 10042:2005 Welding -- Arc-welded joints in aluminium and its alloys -- Quality levels for imperfections
ISO 10042 COR 1:2006 Welding -- Arc-welded joints in aluminium and its alloys -- Quality levels for imperfections
ISO 12932:2013 Welding -- Laser-arc hybrid welding of steels, nickel and nickel alloys -- Quality levels for imperfections
ISO 13916:1996 Welding -- Guidance on the measurement of preheating temperature, interpass temperature and preheat maintenance temperature
ISO 13918:2008 Welding -- Studs and ceramic ferrules for arc stud welding
ISO 13919-1:1996 Welding -- Electron and laser-beam welded joints -- Guidance on quality levels for imperfections -- Part 1: Steel
ISO 13919-2:2001 Welding -- Electron and laser beam welded joints -- Guidance on quality levels for imperfections -- Part 2: Aluminium and its weldable alloys
ISO 13920:1996 Welding -- General tolerances for welded constructions -- Dimensions for lengths and angles -- Shape and position
ISO 14555:2014 Welding -- Arc stud welding of metallic materials
ISO 14744-1:2008 Welding -- Acceptance inspection of electron beam welding machines -- Part 1: Principles and acceptance conditions
ISO 14744-2:2000 Welding -- Acceptance inspection of electron beam welding machines -- Part 2: Measurement of accelerating voltage characteristics
ISO 14744-3:2000 Welding -- Acceptance inspection of electron beam welding machines -- Part 3: Measurement of beam current characteristics
ISO 14744-4:2000 Welding -- Acceptance inspection of electron beam welding machines -- Part 4: Measurement of welding speed
ISO 14744-5:2000 Welding -- Acceptance inspection of electron beam welding machines -- Part 5: Measurement of run-out accuracy
ISO 14744-6:2000 Welding -- Acceptance inspection of electron beam welding machines -- Part 6: Measurement of stability of spot position
ISO/TR 14745:2015 Welding -- Post-weld heat treatment parameters for steels
ISO 15607:2003 Specification and qualification of welding procedures for metallic materials -- General rules
ISO 15607 COR 1:2005 Specification and qualification of welding procedures for metallic materials -- General rules
ISO/TR 15608:2013 Welding -- Guidelines for a metallic materials grouping system
ISO 15609-1:2004 Specification and qualification of welding procedures for metallic materials -- Welding procedure specification -- Part 1: Arc welding
ISO 15609-1 COR 1:2005 Specification and qualification of welding procedures for metallic materials -- Welding procedure specification -- Part 1: Arc welding
ISO 15609-2:2001 Specification and qualification of welding procedures for metallic materials -- Welding procedure specification -- Part 2: Gas welding
ISO 15609-3:2004 Specification and qualification of welding procedures for metallic materials -- Welding procedure specification -- Part 3: Electron beam welding
ISO 15609-4:2009 Specification and qualification of welding procedures for metallic materials -- Welding procedure specification -- Part 4: Laser beam welding
ISO 15609-6:2013 Specification and qualification of welding procedures for metallic materials -- Welding procedure specification -- Part 6: Laser-arc hybrid welding
ISO 15610:2003 Specification and qualification of welding procedures for metallic materials -- Qualification based on tested welding consumables
ISO 15611:2003 Specification and qualification of welding procedures for metallic materials -- Qualification based on previous welding experience
ISO 15612:2004 Specification and qualification of welding procedures for metallic materials -- Qualification by adoption of a standard welding procedure
ISO 15613:2004 Specification and qualification of welding procedures for metallic materials -- Qualification based on pre-production welding test
ISO 15614-1:2004 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 1: Arc and gas welding of steels and arc welding of nickel and nickel alloys
ISO 15614-1 COR 1:2005 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 1: Arc and gas welding of steels and arc welding of nickel and nickel alloys
ISO 15614-1 AMD 1:2008 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 1: Arc and gas welding of steels and arc welding of nickel and nickel alloys
ISO 15614-1 AMD 2:2012 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 1: Arc and gas welding of steels and arc welding of nickel and nickel alloys
ISO 15614-2:2005 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 2: Arc welding of aluminium and its alloys
ISO 15614-2 COR 1:2005 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 2: Arc welding of aluminium and its alloys
ISO 15614-2 COR 2:2009 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 2: Arc welding of aluminium and its alloys
ISO 15614-3:2008 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 3: Fusion welding of non-alloyed and low-alloyed cast irons
ISO 15614-4:2005 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 4: Finishing welding of aluminium castings
ISO 15614-4 COR 1:2007 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 4: Finishing welding of aluminium castings
ISO 15614-5:2004 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 5: Arc welding of titanium, zirconium and their alloys
ISO 15614-6:2006 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 6: Arc and gas welding of copper and its alloys
ISO 15614-7:2016 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 7: Overlay welding
ISO 15614-8:2016 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 8: Welding of tubes to tube-plate joints
ISO 15614-10:2005 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 10: Hyperbaric dry welding
ISO 15614-11:2002 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 11: Electron and laser beam welding
ISO 15614-14:2013 Specification and qualification of welding procedures for metallic materials -- Welding procedure test -- Part 14: Laser-arc hybrid welding of steels, nickel and nickel alloys
ISO 15616-1:2003 Acceptance tests for CO2-laser beam machines for high quality welding and cutting -- Part 1: General principles, acceptance conditions
ISO 15616-2:2003 Acceptance tests for CO2-laser beam machines for high quality welding and cutting -- Part 2: Measurement of static and dynamic accuracy
ISO 15616-3:2003 Acceptance tests for CO2-laser beam machines for high quality welding and cutting -- Part 3: Calibration of instruments for measurement of gas flow and pressure
ISO 15616-4:2008 Acceptance tests for CO2-laser beam machines for high quality welding and cutting -- Part 4: Machines with 2-D moving optics
ISO 15620:2000 Welding -- Friction welding of metallic materials
ISO 17652-1:2003 Welding -- Test for shop primers in relation to welding and allied processes -- Part 1: General requirements
ISO 17652-2:2003 Welding -- Test for shop primers in relation to welding and allied processes -- Part 2: Welding properties of shop primers
ISO 17652-3:2003 Welding -- Test for shop primers in relation to welding and allied processes -- Part 3: Thermal cutting
ISO 17652-4:2003 Welding -- Test for shop primers in relation to welding and allied processes -- Part 4: Emission of fumes and gases
ISO 17660-1:2006 Welding -- Welding of reinforcing steel -- Part 1: Load-bearing welded joints
ISO 17660-2:2006 Welding -- Welding of reinforcing steel -- Part 2: Non load-bearing welded joints
ISO 17662:2016 Welding -- Calibration, verification and validation of equipment used for welding, including ancillary activities
ISO 17663:2009 Welding -- Quality requirements for heat treatment in connection with welding and allied processes
ISO/TR 17671-1:2002 Welding -- Recommendations for welding of metallic materials -- Part 1: General guidance for arc welding
ISO/TR 17671-2:2002 Welding -- Recommendations for welding of metallic materials -- Part 2: Arc welding of ferritic steels
ISO/TR 17671-3:2002 Welding -- Recommendations for welding of metallic materials -- Part 3: Arc welding of stainless steels
ISO/TR 17671-4:2002 Welding -- Recommendations for welding of metallic materials -- Part 4: Arc welding of aluminium and aluminium alloys
ISO/TR 17671-5:2004 Welding -- Recommendations for welding of metallic materials -- Part 5: Welding of clad steels
ISO/TR 17671-6:2005 Welding -- Recommendations for welding of metallic materials -- Part 6: Laser beam welding
ISO/TR 17671-7:2004 Welding -- Recommendations for welding of metallic materials -- Part 7: Electron beam welding
ISO/TR 17844:2004 Welding -- Comparison of standardised methods for the avoidance of cold *****s
ISO/TR 20172:2009 Welding -- Grouping systems for materials -- European materials
ISO/TR 20173:2009 Welding -- Grouping systems for materials -- American materials
ISO/TR 20174:2005 Welding -- Grouping systems for materials -- Japanese materials
ISO 22827-1:2005 Acceptance tests for Nd:YAG laser beam welding machines -- Machines with optical fibre delivery -- Part 1: Laser assembly
ISO 22827-2:2005 Acceptance tests for Nd:YAG laser beam welding machines -- Machines with optical fibre delivery -- Part 2: Moving mechanism
Qualification requirements for welding and allied processes personnel
ISO 9606-1:2012 Qualification testing of welders -- Fusion welding -- Part 1: Steels
ISO 9606-1 COR 1:2012 Qualification testing of welders -- Fusion welding -- Part 1: Steels
ISO 9606-1 COR 2:2013 Qualification testing of welders -- Fusion welding -- Part 1: Steels
ISO 9606-2:2004 Qualification test of welders -- Fusion welding -- Part 2: Aluminium and aluminium alloys
ISO 9606-3:1999 Approval testing of welders -- Fusion welding -- Part 3: Copper and copper alloys
ISO 9606-4:1999 Approval testing of welders -- Fusion welding -- Part 4: Nickel and nickel alloys
ISO 9606-5:2000 Approval testing of welders -- Fusion welding -- Part 5: Titanium and titanium alloys, zirconium and zirconium alloys
ISO 14731:2006 Welding coordination -- Tasks and responsibilities
ISO 14732:2013 Welding personnel -- Qualification testing of welding operators and weld setters for mechanized and automatic welding of metallic materials
ISO 15618-1:2016 Qualification testing of welders for underwater welding -- Part 1: Hyperbaric wet welding
ISO 15618-2:2001 Qualification testing of welders for underwater welding -- Part 2: Diver-welders and welding operators for hyperbaric dry welding
Soldering materials
ISO 5179:1983 Investigation of brazeability using a varying gap test piece
ISO 9453:2014 Soft solder alloys -- Chemical compositions and forms
ISO 9454-1:2016 Soft soldering fluxes -- Classification and requirements -- Part 1: Classification, labelling and packaging
ISO 9454-2:1988 Soft soldering fluxes -- Classification and requirements -- Part 2: Performance requirements
ISO 9455-1:1990 Soft soldering fluxes -- Test methods -- Part 1: Determination of non-volatile matter, gravimetric method
ISO 9455-2:1993 Soft soldering fluxes -- Test methods -- Part 2: Determination of non-volatile matter, ebulliometric method
ISO 9455-3:1992 Soft soldering fluxes -- Test methods -- Part 3: Determination of acid value, potentiometric and visual titration methods
ISO 9455-5:2014 Soft soldering fluxes -- Test methods -- Part 5: Copper mirror test
ISO 9455-6:1995 Soft soldering fluxes -- Test methods -- Part 6: Determination and detection of halide (excluding fluoride) content
ISO 9455-8:1991 Soft soldering fluxes -- Test methods -- Part 8: Determination of zinc content
ISO 9455-9:1993 Soft soldering fluxes -- Test methods -- Part 9: Determination of ammonia content
ISO 9455-10:2012 Soft soldering fluxes -- Test methods -- Part 10: Flux efficacy test, solder spread method
ISO 9455-11:1991 Soft soldering fluxes -- Test methods -- Part 11: Solubility of flux residues
ISO 9455-13:1996 Soft soldering fluxes -- Test methods -- Part 13: Determination of flux spattering
ISO 9455-14:1991 Soft soldering fluxes -- Test methods -- Part 14: Assessment of tackiness of flux residues
ISO 9455-15:1996 Soft soldering fluxes -- Test methods -- Part 15: Copper corrosion test
ISO 9455-16:2013 Soft soldering fluxes -- Test methods -- Part 16: Flux efficacy test, wetting balance method
ISO 9455-17:2002 Soft soldering fluxes -- Test methods -- Part 17: Surface insulation resistance comb test and electrochemical migration test of flux residues
ISO 12224-1:1997 Solder wire, solid and flux cored -- Specification and test methods -- Part 1: Classification and performance requirements
ISO 12224-2:1997 Flux cored solder wire -- Specification and test methods -- Part 2: Determination of flux content
ISO 12224-3:2003 Solder wire, solid and flux cored -- Specifications and test methods -- Part 3: Wetting balance test method for flux cored solder wire efficacy
Brazing materials and processes
ISO 10564:1993 Soldering and brazing materials -- Methods for the sampling of soft solders for analysis
ISO 13585:2012 Brazing -- Qualification test of brazers and brazing operators
ISO 18279:2003 Brazing -- Imperfections in brazed joints
Welding and brazing in aerospace
ISO 16338:2013 Welding for aerospace applications -- Resistance spot and seam welding
ISO 17533:2015 Welding for aerospace applications -- Welding information in design documents
ISO 24394:2008 Welding for aerospace applications -- Qualification test for welders and welding operators -- Fusion welding of metallic components
ISO 24394:2008/AMD 1:2012 Welding for aerospace applications -- Qualification test for welders and welding operators -- Fusion welding of metallic components
the3 missing are:
ISO 5175 AMD 1:2015 Equipment used in gas welding, cutting and allied processes -- Safety devices for fuel gases and oxygen or compressed air -- General specifications, requirements and tests - AMD1 is missing
ISO 9606-1 COR 2:2013 Qualification testing of welders -- Fusion welding -- Part 1: Steels - COR 2 is missing
links:
or
