I am using a Honeywell DR4500A chart recorder and want to configure it to record BTUs on a chilled water loop. I have a supply temp, return temp, and flow. All inputs read and record properly, but when I go into 'input algorithm' and select A-B*C (A = return temp, B = supply temp, and C = flow) input 1 displays what appears to be BTUs. What throws me off here is that input 1 was reading return temp before. If reading input BTUs on input 1 is the expected behavior, how can I see the return temp reading?
