Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
Thread: Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry
    Hi:
    This book addresses corrosion problems and their solutions at facilities in the oil refining and petrochemical industry, including cooling water and boiler feed water units. Further, it describes and analyzes corrosion control actions, corrosion monitoring, and corrosion management. Corrosion problems are a perennial issue in the oil refining and petrochemical industry, as they lead to a deterioration of the functional properties of metallic equipment and harm the environment – both of which need to be protected for the sake of current and future generations. Accordingly, this book examines and analyzes typical and atypical corrosion failure cases and their prevention at refineries and petrochemical facilities, including problems with: pipelines, tanks, furnaces, distillation columns, absorbers, heat exchangers, and pumps. In addition, it describes naphthenic acid corrosion, stress corrosion *****ing, hydrogen damages, sulfidic corrosion, microbiologically induced corrosion, erosion-corrosion, and corrosion fatigue occurring at refinery units. At last, fouling, corrosion and cleaning are discussed in this book.
    Number of Pages
    XXIV, 356
    Number of Illustrations and Tables
    19 b/w illustrations, 128 illustrations in colour
    Topics
    Tribology, Corrosion and Coatings
    Engineering Design
    Industrial Chemistry / Chemical Engineering
    Download from:
  3. Re: Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry
    Thnx so much bro
  5. Re: Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry
    Hi, Many thanks for sharing the book however the link in not active. Could you please share again?
    reupload the file
    Please try here:
    Thank you.
  10. Re: Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry
    Thank you so much
  11. Re: Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry
    thenks bros
    Thanks a lot indeed
  13. Re: Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry
    Super! Thks
  14. Re: Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry
    Many thanks
  16. #12
  1. Corrosion in Petroleum Refining and Petrochemical Operations
    By Mohamed in forum Materials Science &Corrosion
    Last Post: 02-25-2015, 06:59 PM
  2. Corrosion in the petrochemical industry
    By sumon emam in forum Materials Science &Corrosion
    Last Post: 11-24-2014, 11:30 AM
  3. Corrosion in the petrochemical industry Need
    By cpchonburi in forum Materials Science &Corrosion
    Last Post: 01-13-2013, 04:59 PM
  4. Replies: 0
    Last Post: 07-04-2011, 12:04 AM
