Thread: IEC SC 65B - Measurement and control devices
    full list:
    IEC 60528: 1975 Expression of performance of air quality infra-red analyzers
    IEC 60534-1: 2005 Industrial-process control valves - Part 1: Control valve terminology and general considerations
    IEC 60534-2-1: 2011 Industrial-process control valves - Part 2-1: Flow capacity - Sizing equations for fluid flow under installed conditions
    IEC 60534-2-1:2011+COR.1:2015 Corrigendum 1 - Industrial-process control valves - Part 2-1: Flow capacity - Sizing equations for fluid flow under installed conditions
    IEC 60534-2-3: 2015 Industrial-process control valves - Part 2-3: Flow capacity - Test procedures
    IEC 60534-2-4: 2009 Industrial-process control valves - Part 2-4: Flow capacity - Inherent flow characteristics and rangeability
    IEC 60534-3-1: 2000 Industrial-process control valves - Part 3-1: Dimensions - Face-to-face dimensions for flanged, two-way, globe-type, straight pattern and centre-to-face dimensions for flanged, two-way, globe-type, angle pattern control valves
    IEC 60534-3-2: 2001 Industrial-process control valves - Part 3-2: Dimensions - Face-to-face dimensions for rotary control valves except butterfly valves
    IEC 60534-3-3: 1998 Industrial-process control valves - Part 3-3: Dimensions End-to-end dimensions for buttweld, two-way, globe-type, straight pattern control valves
    IEC 60534-4: 2006 Industrial-process control valves - Part 4: Inspection and routine testing
    IEC 60534-5: 2004 Industrial-process control valves - Part 5: Marking
    IEC 60534-6-1: 1997 Industrial-process control valves - Part 6-1: Mounting details for attachment of positioners to control valves - Section 1: Positioner mounting on linear actuators
    IEC 60534-6-2: 2000 Industrial-process control valves - Part 6-2: Mounting details for attachment of positioners to control valves - Positioner mounting on rotary actuators
    IEC 60534-7: 2010 Industrial-process control valves - Part 7: Control valve data sheet
    IEC 60534-8-1: 2005 Industrial-process control valves - Part 8-1: Noise considerations - Laboratory measurement of noise generated by aerodynamic flow through control valves
    IEC 60534-8-2: 2011 Industrial-process control valves - Part 8-2: Noise considerations - Laboratory measurement of noise generated by hydrodynamic flow through control valves
    IEC 60534-8-3: 2010 Industrial-process control valves - Part 8-3: Noise considerations - Control valve aerodynamic noise prediction method
    IEC 60534-8-4: 2015 Industrial-process control valves - Part 8-4: Noise considerations - Prediction of noise generated by hydrodynamic flow
    IEC 60534-9-2007 Industrial-process control valves - Part 9: Test procedure for response measurements from step inputs
    IEC 60534-9-COR 1: 2008 Corrigendum 1 - Industrial-process control valves - Part 9: Test procedure for response measurements from step inputs
    IEC 60546-1: 2010 Controllers with analogue signals for use in industrial-process control systems - Part 1: Methods of evaluating the performance
    IEC 60546-2: 2010 Controllers with analogue signals for use in industrial-process control systems - Part 2: Guidance for inspection and routine testing
    IEC 60584-1: 2013 Thermocouples - Part 1: EMF specifications and tolerances
    IEC 60584-3: 2007 Thermocouples - Part 3: Extension and compensating cables - Tolerances and identification system
    IEC TR 60668: 1980 Dimensions of panel areas and cut-outs for panel and rack-mounted industrial-process measurement and control instruments
    IEC 60746-1: 2003 Expression of performance of electrochemical analyzers - Part 1: General
    IEC 60746-2: 2003 Expression of performance of electrochemical analyzers - Part 2: pH value
    IEC 60746-2: 2003 +COR.1:2003 Expression of performance of electrochemical analyzers - Part 2: pH value
    IEC 60746-2: 2003 +COR.2:2003 Expression of performance of electrochemical analyzers - Part 2: pH value
    IEC 60746-3: 2002 Expression of performance of electrochemical analyzers - Part 3: Electrolytic conductivity
    IEC 60746-3: 2002 + COR.1: 2003 Expression of performance of electrochemical analyzers - Part 3: Electrolytic conductivity
    IEC 60746-4: 1992 Expression of performance of electrochemical analyzers - Part 4: Dissolved oxygen in water measured by membrane covered amperometric sensors
    IEC 60746-5: 1992 Expression of performance of electrochemical analyzers - Part 5: Oxidation-reduction potential or redox potential
    IEC 60751: 2008 Industrial platinum resistance thermometers and platinum temperature sensors
    IEC 60770-1: 2010 Transmitters for use in industrial-process control systems - Part 1: Methods for performance evaluation
    IEC 60770-2: 2010 Transmitters for use in industrial-process control systems - Part 2: Methods for inspection and routine testing
    IEC 60770-3: 2014 Transmitters for use in industrial-process control systems - Part 3: Methods for performance evaluation of intelligent transmitters
    IEC 60873-1: 2003 Electrical and pneumatic analogue chart recorders for use in industrial-process systems - Part 1: Methods for performance evaluation
    IEC 60873-2: 2004 Electrical and pneumatic analogue chart recorders for use in industrial process control systems - Part 2: Guidance for inspection and routine testing
    IEC TR 60877: 1999 Procedures for ensuring the cleanliness of industrial-process measurement and control equipment in oxygen service
    IEC 61003-1: 2016 Industrial-process control systems - Instruments with analogue inputs and two-or multi-state outputs - Part 1: Methods of evaluating performance
    IEC 61003-2: 2016 Industrial-process control systems - Instruments with analogue inputs and two or multi-state outputs - Part 2: Guidance for inspection and routine testing
    IEC 61115: 1992 Expression of performance of sample handling systems for process analyzers
    IEC 61131-1: 2003 Programmable controllers - Part 1: General information
    IEC 61131-2: 2007 Programmable controllers - Part 2: Equipment requirements and tests
    IEC 61131-3: 2013 Programmable controllers - Part 3: Programming languages
    IEC 61131-4: 2004 Programmable controllers - Part 4: User guidelines
    IEC 61131-5: 2000 Programmable controllers - Part 5: Communications
    IEC 61131-6: 2012 Programmable controllers - Part 6: Functional safety
    IEC 61131-7: 2000 Programmable controllers - Part 7: Fuzzy control programming
    IEC 61131-8: 2003 Programmable controllers - Part 8: Guidelines for the application and implementation of programming languages
    IEC 61131-9: 2013 Programmable controllers - Part 9: Single-drop digital communication interface for small sensors and actuators (SDCI)
    IEC 61152: 1992 Dimensions of metal-sheathed thermometer elements
    IEC 61207-1: 2010 Expression of performance of gas analyzers - Part 1: General
    IEC 61207-2: 1994 Expression of performance of gas analyzers - Part 2: Oxygen in gas (utilizing high-temperature electrochemical sensors)
    IEC 61207-2: 1994 + COR.1: 1994 Expression of performance of gas analyzers - Part 2: Oxygen in gas (utilizing high-temperature electrochemical sensors)
    IEC 61207-3: 2002 Gas analyzers - Expression of performance - Part 3: Paramagnetic oxygen analyzers
    IEC 61207-3: 2002 + COR.1: 2003 Gas analyzers - Expression of performance - Part 3: Paramagnetic oxygen analyzers
    IEC 61207-3: 2002 + COR.2: 2003 Gas analyzers - Expression of performance - Part 3: Paramagnetic oxygen analyzers
    IEC 61207-6: 2014 Expression of performance of gas analyzers - Part 6: Photometric analyzers
    IEC 61207-7: 2013 Expression of performance of gas analyzers - Part 7: Tuneable semiconductor laser gas analyzers
    IEC 61207-7:2013+COR.1:2015 Corrigendum 1 - Expression of performance of gas analyzers - Part 7: Tuneable semiconductor laser gas analyzers
    IEC 61285: 2015 Industrial-process control - Safety of analyser houses
    IEC 61297: 1995 Industrial-process control systems - Classification of adaptive controllers for the purpose of evaluation
    IEC 61298-1: 2008 Process measurement and control devices - General methods and procedures for evaluating performance - Part 1: General considerations
    IEC 61298-2: 2008 Process measurement and control devices - General methods and procedures for evaluating performance - Part 2: Tests under reference conditions
    IEC 61298-3: 2008 Process measurement and control devices - General methods and procedures for evaluating performance - Part 3: Tests for the effects of influence quantities
    IEC 61298-4: 2008 Process measurement and control devices - General methods and procedures for evaluating performance - Part 4: Evaluation report content
    IEC 61499-1: 2012 Function blocks - Part 1: Architecture
    IEC 61499-2: 2012 Function blocks - Part 2: Software tool requirements
    IEC 61499-4: 2013 Function blocks - Part 4: Rules for compliance profiles
    IEC 61514: 2000 Industrial-process control systems - Methods of evaluating the performance of valve positioners with pneumatic outputs
    IEC 61514-2: 2013 Industrial process control systems - Part 2: Methods of evaluating the performance of intelligent valve positioners with pneumatic outputs mounted on an actuator valve assembly
    IEC 61515: 2016 Mineral insulated thermocouple cables and thermocouples
    IEC 61518: 2001 Mating dimensions between differential pressure (type) measuring instruments and flanged-on shut-off devices up to 413 BAR (41,3 MPa)
    IEC 61520: 2000 Metal thermowells for thermometer sensors - Functional dimensions
    IEC TR 61831: 2011 On-line analyser systems - Guide to design and installation
    IEC TR 61832: 2015 Analyser systems - Guide to technical enquiry and bid evaluation
    IEC 61987-21:2015 Industrial-process measurement and control - Data structures and elements in process equipment catalogues - Part 21: List of Properties (LOP) of automated valves for electronic data exchange - Generic structures
    IEC 61987-22:2015 Industrial-process measurement and control - Data structures and elements in process equipment catalogues - Part 22: Lists of Properties (LOPs) of valve body assemblies for electronic data exchange
    IEC 61987-23:2015 Industrial-process measurement and control - Data structures and elements in process equipment catalogues - Part 23: Lists of Properties (LOPs) of actuators for electronic data exchange
    IEC 61987-24-1:2015 Industrial-process measurement and control - Data structures and elements in process equipment catalogues - Part 24-1: List of Properties (LOPs) of positioners and I/P converters for electronic data exchange
    IEC TR 62010: 2005 Analyser systems - Guidance for maintenance management
    IEC TS 62098: 2000 Evaluation methods for microprocessor- based instruments
    IEC 62339-1: 2006 Modular component interfaces for surface-mount fluid distribution components - Part 1: Elastomeric seals
    IEC TR 62432: 2006 The rH index in aqueous and aqueous-organic media
    IEC TR 62434: 2006 pH measurements in difficult media - Definitions, standards and procedures
    IEC TR 62456: 2007 An electrochemical reference system for use in different solvent media - The decamethylated ferricinium/ferrocene redox couple
    IEC 62460: 2008 Temperature - Electromotive force (EMF) tables for pure-element thermocouple combinations
    IEC TS 62492-1: 2008 Industrial process control devices - Radiation thermometers - Part 1: Technical data for radiation thermometers
    IEC TS 62492-2: 2013 Industrial process control devices - Radiation thermometers - Part 2: Determination of the technical data for radiation thermometers
    IEC TS 62603-1: 2014 Industrial process control systems - Guideline for evaluating process control systems - Part 1: Specifications
    IEC 62703: 2013 Expression of performance of fluorometric oxygen analyzers in liquid media
    IEC 62952-1:2016 Power sources for a wireless communication device - Part 1: General requirements of power modules
    IEC 62952-2:2016 Power sources for a wireless communication device - Part 2: Profile for power modules with batteries
    missing are:
    links:
    or
    Re: IEC SC 65B - Measurement and control devices
    Thanks a lot friend!
    thanks a lot dear.... i also need IEC 60317 series if it is possible plss....
  6. Re: IEC SC 65B - Measurement and control devices
    thanks!!!!
  1. Replies: 2
    Last Post: 01-06-2017, 11:04 PM
  2. Replies: 0
    Last Post: 03-10-2015, 08:11 PM
  3. Instrumentation for Process Measurement and Control, Third Editon
    By saqibbugti in forum Instrumentation & Control
    Last Post: 09-22-2014, 10:31 AM
  4. Control Valves - Practical Guides for Measurement and Control"
    By Devkumar in forum Instrumentation & Control
    Last Post: 12-07-2013, 05:07 PM
