Page 1 of 2 1 2 LastLast
Results 1 to 12 of 14
Thread: ISO Collection 3/300: ISO/TC 164 - Mechanical testing of metals
    Standards and projects under the direct responsibility of ISO/TC 164 Secretariat
    ISO 23718: 2007 Metallic materials -- Mechanical testing -- Vocabulary
    ISO TR 25679: 2005 Mechanical testing of metals -- Symbols and definitions in published standards
    Uniaxial Testing
    ISO 204: 2009 Metallic materials -- Uniaxial creep testing in tension -- Method of test
    ISO 376: 2011 Metallic materials -- Calibration of force-proving instruments used for the verification of uniaxial testing machines
    ISO 6892-1: 2016 Metallic materials -- Tensile testing -- Part 1: Method of test at room temperature
    ISO 6892-2: 2011 Metallic materials -- Tensile testing -- Part 2: Method of test at elevated temperature
    ISO 6892-3:2015 Metallic materials -- Tensile testing -- Part 3: Method of test at low temperature
    ISO 6892-4:2015 Metallic materials -- Tensile testing -- Part 4: Method of test in liquid helium
    ISO 7500-1: 2015 Metallic materials -- Verification of static uniaxial testing machines -- Part 1: Tension/compression testing machines -- Verification and calibration of the force-measuring system
    ISO 7500-2: 2006 Metallic materials -- Verification of static uniaxial testing machines -- Part 2: Tension creep testing machines -- Verification of the applied force
    ISO 9513: 2012 Metallic materials -- Calibration of extensometer systems used in uniaxial testing
    ISO 9513 + COR 1: 2013 Metallic materials -- Calibration of extensometer systems used in uniaxial testing
    ISO 15579: 2000 Metallic materials -- Tensile testing at low temperature
    ISO 19819: 2004 Metallic materials -- Tensile testing in liquid helium
    ISO 26203-1: 2010 Metallic materials -- Tensile testing at high strain rates -- Part 1: Elastic-bar-type systems
    ISO 26203-2: 2011 Metallic materials -- Tensile testing at high strain rates -- Part 2: Servo-hydraulic and other test systems
    Ductility Testing
    ISO 7438: 2016 Metallic materials -- Bend test
    ISO 7799: 1985 Metallic materials -- Sheet and strip 3 mm thick or less -- Reverse bend test
    ISO 7800:2012 Metallic materials -- Wire -- Simple torsion test
    ISO 7801: 1984 Metallic materials -- Wire -- Reverse bend test
    ISO 7802: 2013 Metallic materials -- Wire -- Wrapping test
    ISO 8491: 1998 Metallic materials -- Tube (in full section) -- Bend test
    ISO 8492: 2013 Metallic materials -- Tube -- Flattening test
    ISO 8493: 1998 Metallic materials -- Tube -- Drift-expanding test
    ISO 8494: 2013 Metallic materials -- Tube -- Flanging test
    ISO 8495: 2013 Metallic materials -- Tube -- Ring-expanding test
    ISO 8496: 2013 Metallic materials -- Tube -- Ring tensile test
    ISO 9649: 2016 Metallic materials -- Wire -- Reverse torsion test
    ISO 10113: 2006 Metallic materials -- Sheet and strip -- Determination of plastic strain ratio
    ISO 10275: 2007 Metallic materials -- Sheet and strip -- Determination of tensile strain hardening exponent
    ISO 11531: 2015 Metallic materials -- Earing test
    ISO 12004-1: 2008 Metallic materials -- Sheet and strip -- Determination of forming-limit curves -- Part 1: Measurement and application of forming-limit diagrams in the press shop
    ISO 12004-2: 2008 Metallic materials -- Sheet and strip -- Determination of forming-limit curves -- Part 2: Determination of forming-limit curves in the laboratory
    ISO 13314: 2011 Mechanical testing of metals -- Ductility testing -- Compression test for porous and cellular metals
    ISO 15363: 2000 Metallic materials -- Tube ring hydraulic pressure test
    ISO 16630: 2009 Metallic materials -- Sheet and strip -- Hole expanding test
    ISO 16808: 2014 Metallic materials -- Sheet and strip -- Determination of biaxial stress-strain curve by means of bulge test with optical measuring systems
    ISO 16842: 2014 Metallic materials -- Sheet and strip -- Biaxial tensile testing method using a cruciform test piece
    ISO 17340: 2014 Metallic materials -- Ductility testing -- High speed compression test for porous and cellular metals
    ISO 18338:2015 Metallic materials -- Torsion test at ambient temperature
    ISO 20032: 2013 Method for evaluation of tensile properties of metallic superplastic materials
    ISO 20482: 2013 Metallic materials -- Sheet and strip -- Erichsen cupping test
    ISO 24213: 2008 Metallic materials -- Sheet and strip -- Method for springback evaluation in stretch bending
    Hardness Testing
    ISO 4545-1: 2005 Metallic materials -- Knoop hardness test -- Part 1: Test method
    ISO 4545-2: 2005 Metallic materials -- Knoop hardness test -- Part 2: Verification and calibration of testing machines
    ISO 4545-3: 2005 Metallic materials -- Knoop hardness test -- Part 3: Calibration of reference blocks
    ISO 4545-4: 2005 Metallic materials -- Knoop hardness test -- Part 4: Table of hardness values
    ISO 6506-1: 2014 Metallic materials -- Brinell hardness test -- Part 1: Test method
    ISO 6506-2: 2014 Metallic materials -- Brinell hardness test -- Part 2: Verification and calibration of testing machines
    ISO 6506-3: 2014 Metallic materials -- Brinell hardness test -- Part 3: Calibration of reference blocks
    ISO 6506-4: 2014 Metallic materials -- Brinell hardness test -- Part 4: Table of hardness values
    ISO 6507-1: 2005 Metallic materials -- Vickers hardness test -- Part 1: Test method
    ISO 6507-2: 2005 Metallic materials -- Vickers hardness test -- Part 2: Verification and calibration of testing machines
    ISO 6507-3: 2005 Metallic materials -- Vickers hardness test -- Part 3: Calibration of reference blocks
    ISO 6507-4: 2005 Metallic materials -- Vickers hardness test -- Part 4: Tables of hardness values
    ISO 6508-1: 2016 Metallic materials -- Rockwell hardness test -- Part 1: Test method (scales A, B, C, D, E, F, G, H, K, N, T)
    ISO 6508-2: 2015 Metallic materials -- Rockwell hardness test -- Part 2: Verification and calibration of testing machines (scales A, B, C, D, E, F, G, H, K, N, T)
    ISO 6508-3: 2015 Metallic materials -- Rockwell hardness test -- Part 3: Calibration of reference blocks (scales A, B, C, D, E, F, G, H, K, N, T)
    ISO 14577-1: 2015 Metallic materials -- Instrumented indentation test for hardness and materials parameters -- Part 1: Test method
    ISO 14577-2: 2015 Metallic materials -- Instrumented indentation test for hardness and materials parameters -- Part 2: Verification and calibration of testing machines
    ISO 14577-3: 2015 Metallic materials -- Instrumented indentation test for hardness and materials parameters -- Part 3: Calibration of reference blocks
    ISO 14577-4: 2007 Metallic materials -- Instrumented indentation test for hardness and materials parameters -- Part 4: Test method for metallic and non-metallic coatings
    ISO 16859-1:2015 Metallic materials -- Leeb hardness test -- Part 1: Test method
    ISO 16859-2:2015 Metallic materials -- Leeb hardness test -- Part 2: Verification and calibration of the testing devices
    ISO 16859-3:2015 Metallic materials -- Leeb hardness test -- Part 3: Calibration of reference test blocks
    ISO 18265: 2013 Metallic materials -- Conversion of hardness values
    ISO TR 29381: 2008 Metallic materials -- Measurement of mechanical properties by an instrumented indentation test -- Indentation tensile properties
    Toughness testing -- Fracture (F), Pendulum (P), Tear (T)
    ISO 148-1: 2016 Metallic materials -- Charpy pendulum impact test -- Part 1: Test method
    ISO 148-2: 2016 Metallic materials -- Charpy pendulum impact test -- Part 2: Verification of testing machines
    ISO 148-3: 2016 Metallic materials -- Charpy pendulum impact test -- Part 3: Preparation and characterization of Charpy V-notch test pieces for indirect verification of pendulum impact machines
    ISO 3785: 2006 Metallic materials -- Designation of test specimen axes in relation to product texture
    ISO 12135: 2002 Metallic materials -- Unified method of test for the determination of quasistatic fracture toughness
    ISO 12135 + COR 1: 2008 Metallic materials -- Unified method of test for the determination of quasistatic fracture toughness
    ISO 14556: 2015 Steel -- Charpy V-notch pendulum impact test -- Instrumented test method
    ISO 15653: 2010 Metallic materials -- Method of test for the determination of quasistatic fracture toughness of welds
    ISO 22889: 2013 Metallic materials -- Method of test for the determination of resistance to stable ***** extension using specimens of low constraint
    ISO 26843:2015 Metallic materials -- Measurement of fracture toughness at impact loading rates using pre*****ed Charpy-type test pieces
    ISO 27306: 2016 Metallic materials -- Method of constraint loss correction of CTOD fracture toughness for fracture assessment of steel components
    Fatigue Testing
    ISO 1099: 2006 Metallic materials -- Fatigue testing -- Axial force-controlled method
    ISO 1143: 2010 Metallic materials -- Rotating bar bending fatigue testing
    ISO 1352: 2011 Metallic materials -- Torque-controlled fatigue testing
    ISO 4965-1: 2012 Metallic materials -- Dynamic force calibration for uniaxial fatigue testing -- Part 1: Testing systems
    ISO 4965-2: 2012 Metallic materials -- Dynamic force calibration for uniaxial fatigue testing -- Part 2: Dynamic calibration device (DCD) instrumentation
    ISO 12106: 2003 Metallic materials -- Fatigue testing -- Axial-strain-controlled method
    ISO 12107: 2012 Metallic materials -- Fatigue testing -- Statistical planning and analysis of data
    ISO 12108: 2012 Metallic materials -- Fatigue testing -- Fatigue ***** growth method
    ISO 12110-1: 2013 Metallic materials -- Fatigue testing -- Variable amplitude fatigue testing -- Part 1: General principles, test method and reporting requirements
    ISO 12110-2: 2013 Metallic materials -- Fatigue testing -- Variable amplitude fatigue testing -- Part 2: Cycle counting and related data reduction methods
    ISO 12111: 2011 Metallic materials -- Fatigue testing -- Strain-controlled thermomechanical fatigue testing method
    ISO 23788: 2012 Metallic materials -- Verification of the alignment of fatigue testing machines
    missing are:
    links:
    or
    Re: ISO/TC 164 - Mechanical testing of metals
    thanks dear
  5. Re: ISO/TC 164 - Mechanical testing of metals
    Does anyone has ISO 148-1: 2016 Metallic materials -- Charpy pendulum impact test -- Part 1: Test method
    thank you very much for your sharing.
    do you have 148-1 2016 version to share?
    not yet....btw. there whole set of of EN ISO 148:2016 (parts 1, 2 and 3) and I'm also looking for it
    Re: ISO Collection 3/300: ISO/TC 164 - Mechanical testing of metals
    update:
    better quality:
    ISO 6508-1: 2016 Metallic materials -- Rockwell hardness test -- Part 1: Test method (scales A* B* C* D* E* F* G* H* K* N* T)
    added missing/new standards:
    ISO 12135: 2016 Metallic materials -- Unified method of test for the determination of quasistatic fracture toughness
    the only 1 missing here is:
    ISO 14577-4: 2016 Metallic materials -- Instrumented indentation test for hardness and materials parameters -- Part 4: Test method for metallic and non-metallic coatings
    link:
    update:
    better quality:
    added missing:
    and the new one is missing now:
    ISO 12106: 2017 Metallic materials -- Fatigue testing -- Axial-strain-controlled method
    complete
    great job
    full list 17.11.2017:
    ISO 15363: 2017 Metallic materials -- Tube ring hydraulic pressure test
    ISO 16630: 2017 Metallic materials -- Sheet and strip -- Hole expanding test
    ISO 6506-2: 2017 Metallic materials -- Brinell hardness test -- Part 2: Verification and calibration of testing machines
    ISO 6508-2: 2015 Metallic materials -- Rockwell hardness test -- Part 2: Verification and calibration of testing machines (scales A* B* C* D* E* F* G* H* K* N* T)
    ISO 6508-3: 2015 Metallic materials -- Rockwell hardness test -- Part 3: Calibration of reference blocks (scales A* B* C* D* E* F* G* H* K* N* T)
    ISO 1099:2017 Metallic materials -- Fatigue testing -- Axial force-controlled method
    ISO 12106:2017 Metallic materials -- Fatigue testing -- Axial-strain-controlled method
    ISO 12110-1: 2013 Metallic materials -- Fatigue testing -- Variable amplitude fatigue testing -- Part 1: General principles* test method and reporting requirements
    complete
  14. Re: ISO Collection 3/300: ISO/TC 164 - Mechanical testing of metals
    Hi,
    do you have EN ISO 6507-1: 2018 Edition
  16. Re: ISO Collection 3/300: ISO/TC 164 - Mechanical testing of metals
    Quote Originally Posted by hakkik View Post
    Hi,
    Attached Files Attached Files
  1. ASM Metals Handbook Collection
    By hoangson0211 in forum Materials Science &Corrosion
    Last Post: 08-02-2017, 04:57 PM
  2. Replies: 0
    Last Post: 10-20-2016, 01:55 AM
  3. AWS B4.0-Standard Methods for Mechanical Testing of Welds
    By socri in forum Mechanical Engineering
    Last Post: 10-20-2015, 09:03 PM
  4. 08 - Mechanical Testing and Evaluation
    By dongono in forum General Engineering
    Last Post: 12-26-2014, 10:52 AM
  5. Replies: 0
    Last Post: 08-12-2013, 11:28 AM
