Does any professional members share the following this ?
PHEdesign 1.0 program for simulations of the plate heat exchanger. By setting our controlled variables and material properties, the optimum plate dimensions and materials can be selected by the computer program. These are included rate of heat transfer, the size of plate heat exchanger, and chevron angle (beta) between 25 to 65 degrees under single pass condition. Also this program is capable of calculating the pressure drop in plate, from which the energy and material can be saved by decreasing the pressure drop (decreasing horsepower per unit area) and increasing chevron angle
