Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
Thread: How to instally multiple copies and versions of ETAP?
  1. Question How to instally multiple copies and versions of ETAP?
    Hi all,
    currently there are on 4 shared these versions with m.e.d.ici.n.e (do search ,other than V14 most has been on for more than 3 years and can assume aren't going away anytime soon)
    ETAP V4.0.0
    ETAP V5.?.? (large .cst file 29.5GB!!)not sure if working
    ETAP V.6.5.0
    ETAP V7.5.0
    ETAP V11.1.1
    ETAP V12.6.0
    ETAP V14.0.0 (cadguys faulty *****,but good enough to do studies)
    I've installed all of them on the same computer along with our company's licensed version of ETAP V12.6.5 (limited licence due to expense),
    Here's the problem, only
    ETAP V12.6.0
    ETAP V14.0.0
    seem to work with their respected Me.di.cine
    all the others don't seem to work and say the licence server cannot be found
    Even the licenced V12.6.5 with the dongle plugged in can't work.
    My guess is that each medi.c.i.n.e is simulating it's own licence manager,so some overlap,
    but since both
    ETAP V12.6.0
    ETAP V14.0.0
    can work on the same platform simultaneously
    How to work around this problem ?
    Simple, install only the needed etap..
    Sent from Mars using Tapatalk
    v12 and v14 the hot stuffs.
    Sent from my ASUS_T00J using Tapatalk
    Re: How to instally multiple copies and versions of ETAP?
    Quote Originally Posted by surgeArrester View Post
    Very good solution
    versions of etap work simultaniusly, but I don't uderstand to do that, somethimes it creates conflicts with 12,5 and 14,1 version with installers.
    even If you do some same calculations of previus versions of etap, results are different some times, for that reason is better to use the last version of it.
    Quote Originally Posted by himmelstern View Post
    Dear Himmelstern
    Based on your explanation on above, it seems that you have Etap 14.1 including the solution. Could you share it? thanks
    I only wonder because I read in other forum, including some Spanish forum, they are using the med for 12.6, but it seems some of them do not have the error or message " incorrect parameter", time lag etc. Some Arab forum also never mentioned bout that.
    Some says the error is gone once laptop formatted( mine still has error after formatting). Downloaded many med for 12.6 but still the same.Guess the meds are all the same but they changed the name only.
    For 14.0, sometime the toolbars disappear, but it is a faulty med anyway.
    Sometimes Windows crashed.
    La instalación es sencilla y funciona en 32 bits/64 bits en Windows XP y 7. 100% garantizado, en Windows 8 he escuchado que si. Es seguir bien los pasos.
    1. Instale el ETAP 11 y Etap Lic Manager. (Normalmente al instalar ETAP este instala automáticamente el Etap Lic Manager)
    2. Abra Panel de control - > Herramientas - > Servicios administrativos, click derecho en Etaps Lic. Mgr service, y detener.
    3. Copie los archivos del rar del ***** (
    [link Point to another website Only the registered members can access] 4. Iniciar servicio " Etaps Lic. Mngr " de nuevo en servicios.
    5. Pruebe a iniciar Etap 11, si todo ha ido bien le preguntará el código de activación. Si no, este pedirá la licencia o la llave en un equipo local o remoto de la Red.
    5a. Si ETAP Lic . Administrador no encuentra una licencia tendrá que instalar una impresora ECP. después de instalar la impresora ECP se deben repetir los pasos 3 , 4, 5
    6. Introduzca el código de activación: Z@8cUuS5w#nytVgCfvvccA%tDDu4jD6aNb?K
    7. Disfrute :P
    Quote Originally Posted by mukhriz View Post
    I agree.. I have installed it in my wife's laptop and it doesnt show incorrect parameter.
    create an ovl presentation in 12.6 and this message will apear for every presentation that you create.
    if you try the automatic protection coordination in etap 12,6 the program will crash.
  14. #11
    The installation ó n is simple and works in 32-bit / 64-bit Windows XP and 7. 100% guaranteed, in Windows 8 I have heard so. It is to follow the steps well.
    1. Install ETAP 11 and Etap Manager Lic. (Normally when you install ETAP this installed automatic Ã, Lic matically Etap Manager)
    2. Open Control Panel -> Tools -> Administrative Services, right click on Etaps Lic Mgr service, and stop..
    3. Copy the files from rar ***** (
    [link Point to another website Only the registered members can access] 4. Start Service "Etaps Lic. Mngr" back into services.
    5. Try to start Etap 11 if everything went well you ask Ã, the c ó I say activation ó n. If not, this request Ã, license or key in a local or remote computer on the network.
    5A. If ETAP Lic. Manager will have à can not find a license, install an ECP printer. after installing the printer ECP should repeat steps 3, 4, 5
    6. Enter c ó I say activation ó n: Z @ 8cUuS5w # nytVgCfvvccA% tDDu4jD6aNb K?
    7. Enjoy: P
  16. #12
    that's for etap 11 and i'ts for etap demo to run ok, the procedure must do it every time you run etap 11
