Weldassistant Pro 7.4.0.1536Posted By: Messer2 Date: 9 Jul 2016 12:11:19
Weldassistant Pro 7.4.0.1536 | 123.8 Mb
Generate, print and use a WPS (Welding Procedure Specification) in no time at all. Perform the associated welding cost calculation and welding cost optimisation. The result can be actioned in the daily routine immediately. Whether it's in the workshop, office or on building sites - weldassistant® can be used without any additional resources. You have a constant overview of you welders' qualifications and are able to initiate any necessary measures immediately.
Generate welding procedure specifications (WPS) including WPS Template
The comprehensive database and process dependant entry system means you arrive at the welding procedure specification (WPS) quickly and easily.
Managing Welding Procedure Qualification Records (WPQR / PQR)
Quickly find the needed WPQR (PQR) Welding Procedure Qualification Record and keep track of the status.
Welder qualification and Welder certification management (e.g. EN 287-1; EN ISO 9606)
Keep a constant eye on your welder qualification and welders certification. The current status of a welder's certification can be seen at a glance on the "traffic light" symbol.
Welding cost calculation
Keep welding costs under control and calculate to meet market requirements.
Compare any calculations with a view to optimizing your weld cost.
Plug-in concept
Following manufacturer plug-ins provide you with welding process data sheets or product information.
- ESAB Welding and Cutting (OK-Handbook)
- Safra (Aluminium + Copper filler metal)
- Linde Gas
- Air Liquide
- PanGas
- Praxair
- Wolfram Industrie
Philosophy
- Don't type - just click
- fast, straightforward, compact and any amount of data
- polish off simple tasks
- the fast track to welding solutions, welding procedure and more
- the WPS program which generates resources
Use the weldassistant software because…
your work, as supervisor or the person accountable, has to be fast and efficient
you place emphasis on proven, practical solutions
you want to concentrate more on the core assignments of your work
you want to gain more time for actual project work by deploying welding procedure software
you want to fulfill the quality requirements of the EN ISO 3834, EN 1090,EN 15614 etc.
All PRO Editions include:
All BASIC features
Welder qualification administration
Operator qualification administration
Welder Certificates preparation (e.g. EN 287-1; ISO 9606)
Operator Certificates preparation (e.g. EN1418; ISO 14732)
Weld cost calculation
weldassistant PRO
All PRO features
ISO - WPS
ASME - WPS
Link:[link Point to another website Only the registered members can access]
Password: qifl
