A Working Guide to Process Equipment, Fourth EditionPosted By: ksveta6 Date: 17 Mar 2015 23:32:39
A Working Guide to Process Equipment, Fourth Edition by Norman Lieberman, Elizabeth Lieberman
2014 | ISBN: 0071828060 | English | 624 pages | PDF | 10 MB
The latest methods for troubleshooting and maintaining process equipment
Applicable to a broad range of technicians and industries and fully updated throughout, A Working Guide to Process Equipment, Fourth Edition, explains how to diagnose, troubleshoot, and correct problems with chemical and petroleum refining process equipment. Nine new chapters cover:
Tray design details
Shell-and-tube heat exchanger design details
Relief valve system design
Vapor lock and exchanger flooding in steam systems
Steam generation operating and design details
Wastewater strippers
Thermodynamics – how it applies to process equipment
Centrifugal pumps – reducing seal and bearing failures
Hand calculations for distillation towers
Vapor – liquid equilibrium, absorption, and stripping calculations
Filled with examples and illustrations, this practical resource demonstrates how theory applies to solving real-world plant operation problems. Selected hand calculation methods are also provided.
Comprehensive coverage includes:
Distillation Tower Trays * Tower Pressure Control * Distillation Towers * Reboilers * Tower Internals * Instruments * Packed Towers * Steam and Condensate Systems * Bubble Point and Dew Point * Steam Strippers * Draw-Off Nozzle Hydraulics * Pumparounds and Tower Heat Flows * Condensers and Tower Pressure Control * Air Coolers * Deaerators and Steam Systems * Steam Generation * Wastewater Strippers * Vacuum Systems * Steam Turbines * Surface Condensers * Shell-and-Tube Heat Exchangers * Fired Heaters * Refrigeration Systems * Cooling Water Systems * Catalytic Effects * Centrifugal Pumps * Control Valves * Separators * Centrifugal Compressors and Surge * Reciprocating Compressors * Corrosion * Fluid Flow in Pipes * Super-Fractionation Stage * Computer Control * Field Troubleshooting
访问密码(Password): 9920
This is a china' 360 cloud, every body don't need register become a member, only select "download", you will get it. If members register become a member, may be I can easy share more data for you.
