Page 1 of 8 1 2 3 ... LastLast
Results 1 to 12 of 92
Thread: AWS Codes, Publications....
    Use excel file to open the files, because some codes are in more than one excel sheets, and to avoid repeating of same files, some folders are empty, but in excel sheets they've linked onto location in another folder. Anyway, acc to AWS catalogue, it should look like this:
    BTW. Bolded codes are here, unbolded are missing
    AEROSPACE
    D17.1/D17.1M:2010-AMD 1 Specification for Fusion Welding for Aerospace Applications
    D17.2/D17.2M:2013 Specification for Resistance Welding for Aerospace Applications
    D17.3/D17.3M:2016 Specification for Friction Stir Welding of Aluminum Alloys for Aerospace Applications
    ALUMINIUM
    A5.3/A5.3M:1999 (R2007) Specification for Aluminum and Aluminum-Alloy Electrodes for Shielded Metal Arc Welding
    A5.10/A5.10M (ISO 18273 MOD):2012 Welding Consumables – Wire Electrodes, Wires and Rods for Welding of Aluminum and Aluminum-Alloys – Classification
    B2.1-22-015:2011 Standard Welding Procedure Specification (Aluminum)
    C3.7M/C3.7:2011 Specification for Aluminum Brazing
    D1.2/D1.2M:2014 Structural Welding Code – Aluminum
    D3.7:2004 Guide for Aluminum Hull Welding
    D8.14M:2008 Specification for Automotive Weld Quality—Arc Welding of Aluminum
    D10.7M/D10.7:2008 Guide for the Gas Shielded Arc Welding of Aluminum and Aluminum Alloy Pipe
    PHB-8 The Everyday Pocket Handbook for Gas Metal Arc Welding (GMAW) of Aluminum
    WQA Welding Aluminum–Questions and Answers
    AUTOMOTIVE
    D8.1M:2013 Specification for Automotive Weld Quality – Resistance Spot Welding of Steel
    D8.8M:2014 Specification for Automotive Weld Quality – Arc Welding of Steel
    D8.9M:2012 Recommended Practices for Test Methods for Evaluating the Resistance Spot Welding Behavior of Automotive Sheet Steel Materials
    BRAZING AND BRAZE WELDING
    A5.8M/A5.8-AMD 1:2011 Specification for Filler Metals for Brazing and Braze Welding
    A5.31M/A5.31:2012 Specification for Fluxes for Brazing and Braze Welding
    B2.2/B2.2M:2010 Specification for Brazing Procedure and Performance Qualification
    BRH:2007 Brazing Handbook
    C3.2M/C3.2:2008 Standard Method for Evaluating the Strength of Brazed Joints
    C3.3:2008 Recommended Practices for the Design, Manufacture, and Examination of Critical Brazed Components
    C3.4M/C3.4:2016 Specification for Torch Brazing
    C3.5M/C3.5:2016 Specification for Induction Brazing
    C3.6M/C3.6:2008 Specification for Furnace Brazing
    C3.8M/C3.8:2011 Specification for the Pulse-Echo Ultrasonic Examination of Brazed Joints
    C3.9M/C3.9:2009 Specification for Resistance Brazing
    D10.13/D10.13M:2001 Recommended Practices for the Brazing of Copper Tubing and Fittings for Medical Gas Systems
    BRIDGES
    AASHTO/AWS D1.5:2015 Bridge Welding Code
    CARBON STEEL
    A5.1/A5.1M:2012 Specification for Carbon Steel Electrodes for Shielded Metal Arc Welding
    A5.2/A5.2M:2007 Specification for Carbon and Low Alloy Steel Rods for Oxyfuel Gas Welding
    A5.17/A5.17M:1997 (R2007) Specification for Carbon Steel Electrodes and Fluxes for Submerged Arc Welding
    A5.18/A5.18M:2005 Specification for Carbon Steel Electrodes and Rods for Gas Shielded Arc Welding
    A5.20/A5.20M:2005 (R2015) Specification for Carbon Steel Electrodes for Flux Cored Arc Welding
    A5.25/A5.25M:1997 (R2009) Specification for Carbon and Low-Alloy Steel Electrodes and Fluxes for Electroslag Welding
    A5.26/A5.26M:1997 (R2009) Specification for Carbon and Low-Alloy Steel Electrodes for Electrogas Welding
    A5.36/A5.36M:2016 Specification for Carbon and Low-Alloy Steel Flux Cored Electrodes for Flux Cored Arc Welding and Metal Cored Electrodes for Metal Arc Welding
    GTW:2005 Guide to Weldability: Carbon and Low-Alloy Steels
    CAST IRON
    A5.15:1990 (R2016) Specification for Welding Electrodes and Rods for Cast Iron
    D11.2:1989 (R2006) Guide for Welding Iron Castings
    CERTIFICATION
    CM:2000 Certification Manual for Welding Inspectors
    CMWS:2005 Certified Welding Supervisor Manual
    QC1:2007 Standard for AWS Certification of Welding Inspectors
    QC4:1989 Standard for Accreditation of Test Facilities for AWS Certified Welder Program
    QC5:1991 Standard for AWS Certification of Welding Educators
    QC7:1993 Standard for AWS Certified Welders
    QC7C:1993 Supplement C,Welder Performance Qualification Sheet Metal Test Requirements
    QC7F:1993 Supplement F, Chemical Plant and Petroleum Refinery Piping
    QC7G:1993 Supplement G, AWS Performance Qualification Test
    QC10:2008 Specification for Qualification and Registration of Level I — Entry Welders
    QC11:1996 Specification for Qualification and Certification for Level II — Advanced Welders
    QC12:1996 Specification for Qualification and Certification for Level III — Expert Welders
    QC13:2006 Specification for the Certification of Welding Supervisors
    QC14:2009 Specification for the Certification of Welding Sales Representatives
    QC15:2008 Specification for the Certification of Radiographic Interpreters
    QC17:2015 Specification for AWS Accreditation of Certified Welding Fabricators
    QC19:2002 Standard for the AWS Certification of Robotic Arc Welding Personnel
    QC20:2011 Standard for the AWS Certification of Resistance Welding Technicians
    CHARTS
    A2.1 WC:2012 Welding Symbol Charts
    A2.1 DC:2012 Welding Symbol Charts
    A3.1:2010 Master Chart of Welding and Joining Processes
    D1.1-SWJ-WC Welded Joint Details Wall Chart
    D18.2:2009 Guide to Weld Discoloration Levels on Inside of Austenitic Stainless Steel Tube
    F2.2:2001 (R2010) Lens Shade Selector
    COMPUTERIZATION
    A9.5:2013 Guide for Verification and Validation in Computation Weld Mechanics
    CORROSION RESISTANCE
    C2.20/C2.20M:2002 Specification for Thermal Spraying Zinc Anodes on Steel Reinforced Concrete
    C2.23M/C2.23:2003 Specification for the Application of Thermal Spray Coatings (Metallizing) of Aluminum, Zinc, and Their Alloys and Composites for the Corrosion Protection of Steel
    PRGHF The Practical Reference Guide for Hardfacing
    CUTTING
    A5.12M/A5.12 (ISO 6848 MOD):2009 Specification for Tungsten and Tungsten-Alloy Electrodes for Arc Welding and Cutting
    C4.6M (ISO 9013 IDT) :2006 (R2012) Thermal Cutting—Classification of Thermal Cuts—Geometric Product Specification and Quality Tolerances
    C5.3:2000 (R2011) Recommended Practices for Air Carbon Arc Gouging and Cutting
    C5.10/C5.10M :2003 Recommended Practices for Shielding Gases for Welding and Cutting
    C7.2:2010 Recommended Practices for Laser Beam Welding, Cutting, and Allied Processes
    F4.1:2007 Safe Practices for the Preparation of Containers and Piping for Welding and Cutting
    DESIGN
    DPW:1997 Design and Planning Manual for Cost-Effective Welding
    FWSH:1997 Design Handbook for Calculating Fillet Weld Sizes
    EDUCATION AND TRAINING
    API-M:2008 Study Guide for API Standard 1104
    CCRM:2015 Code Clinic–Structural Welding Code – Steel
    EG2.0:2008 Guide for Training and Qualification of Welding Personnel: Entry Welder
    EG3.0:2006 Guide for the Training and Qualification of Welding Personnel: Level II – Advanced Welders
    GWF:1998 Guide for Setting Up a Welder Training Facility
    WIT-T:2008 Welding Inspection Technology
    WIT-W:2008 Welding Inspection Technology Workbook
    ELECTROGAS AND ELECTROSLAG WELDING
    C5.7:2000 (R2006) Recommended Practices for Electrogas Welding
    ELECTRON BEAM WELDING
    C7.1M/C7.1:2013 Recommended Practices for Electron Beam Welding and Allied Processes
    C7.3:2016 Process Specification for Electron Beam Welding
    FILLER METALS AND FLUXES
    A4.2M (ISO 8429 MOD):2006 (R2014) Standard Procedures for Calibrating Magnetic Instruments to Measure the Delta Ferrite Content of Austenitic and Duplex Ferritic-Austenitic Stainless Steel Weld Metal
    A4.3:1993 (R2006) Standard Methods for Determination of the Diffusible Hydrogen Content of Martensitic,Bainitic, and Ferritic Steel Weld Metal Produced by Arc Welding
    A4.4M:2001 (R2006) Standard Procedures for Determination of Moisture Content of Welding Fluxes and Welding Electrode Flux Coverings
    A4.5M/A4.5 (ISO 15792-3 MOD):2012 Standard Methods for Classification Testing of Positional Capacity and Root Penetration of Welding Consumables in a Fillet Weld
    A5.01M/A5.01 (ISO 14344 MOD):2013 Welding Consumables–Procurement of Filler Metals and Fluxes
    A5.02/A5.02M:2007 Specification for Filler Metal Standard Sizes, Packaging, and Physical Attributes
    A5.4/A5.4M:2012 Specification for Stainless Steel Electrodes for Shielded Metal Arc Welding
    A5.5/A5.5M:2014 Specification for Low-Alloy Steel Electrodes for Shielded Metal Arc Welding
    A5.6/A5.6M:2008 Specification for Copper and Copper-Alloy Electrodes for Shielded Metal Arc Welding
    A5.7/A5.7M:2007 Specification for Copper and Copper-Alloy Bare Welding Rods and Electrodes
    A5.11/A5.11M:2010 Specification for Nickel and Nickel-Alloy Welding Electrodes for Shielded Metal Arc Welding
    A5.13/A5.13M:2010 Specification for Surfacing Electrodes for Shielded Metal Arc Welding
    A5.14/A5.14M:2011 Specification for Nickel and Nickel-Alloy Bare Welding Electrodes and Rods
    A5.16/A5.16M (ISO 24034 MOD):2013 Specification for Titanium and Titanium-Alloy Welding Electrodes and Rods
    g
    A5.19:1992 (R2016) Specification for Magnesium Alloy Welding Electrodes and Rods
    A5.21/A5.21M:2011 Specification for Bare Electrodes and Rods for Surfacing
    A5.22/A5.22M:2012 Specification for Stainless Steel Flux Cored and Metal Cored Welding Electrodes and Rods
    A5.23/A5.23M:2011 Specification for Low-Alloy Steel Electrodes and Fluxes for Submerged Arc Welding
    A5.24/A5.24M:2014 Specification for Zirconium and Zirconium-Alloy Welding Electrodes and Rods
    A5.28/A5.28M:2005 (R2015) Specification for Low-Alloy Steel Electrodes and Rods for Gas Shielded Metal Arc Welding
    A5.29/A5.29M:2010 Specification for Low-Alloy Steel Electrodes for Flux Cored Arc Welding
    A5.30/A5.30M:2007 Specification for Consumable Inserts
    A5.34/A5.34M:2013 Specification for Nickel-Alloy Electrodes for Flux Cored Arc Welding
    A5.35/A5.35M:2016 Specification for Covered Electrodes for Underwater Wet Shielded Metal Arc Welding
    UGFM:2010 User’s Guide to Filler Metals
    FOOD PROCESSING SYSTEMS
    D18.1:2009 Specification for Welding of Austenitic Stainless Steel Tube and Pipe Systems in Sanitary (Hygienic) Applications
    D18.3/D18.3M:2015 Specification for Welding of Tanks, Vessels, and Other Equipment in Sanitary (Hygienic) Applications
    FRICTION WELDING
    C6.1:1989 (R2009) Recommended Practices for Friction Welding
    C6.2/C6.2M:2006 Specification for Friction Welding of Metals
    GAS METAL ARC WELDING
    PHB-4 Everyday Pocket Handbook for Gas Metal Arc Welding (GMAW) and Flux Cored Arc Welding (FCAW)
    PHB-8 Everyday Pocket Handbook for Gas Metal Arc Welding (GMAW) of Aluminum
    GAS TUNGSTEN ARC WELDING
    A5.22/A5.22M:2012 Specification for Stainless Steel Flux Cored and Metal Cored Welding Electrodes and Rods for Gas Tungsten Arc Welding
    C5.5/C5.5M:2003 Recommended Practices for Gas Tungsten Arc Welding
    D10.6/D10.6M:2000 Recommended Practices for Gas Tungsten Arc Welding of Titanium Piping and Tubing
    INSPECTION
    B1.10M/B1.10:2009 Guide for the Nondestructive Examination of Welds
    B1.11:2015 Guide for the Visual Examination of Welds
    B4.0/B4.0M:2007 Standard Methods for Mechanical Testing of Welds
    G1.2M/G1.2:1999 (R2010) Specification for Standardized Ultrasonic Welding Test Specimen for Thermoplastics
    G1.6:2006 Specification for the Qualification of Plastics Welding Inspectors for Hot Gas, Hot Gas Extrusion, and Heated Tool Butt Thermoplastic Welds
    PHB-2 Everyday Pocket Handbook for Visual Inspection and Weld Discontinuities —Causes and Remedies
    PHB-6 Everyday Pocket Handbook for Visual Inspection of AWS D1.1 Structural Welding Code’s Fabrication and Welding Requirements
    WI:2015 Welding Inspection Handbook
    LASER BEAM WELDING
    C7.2M:2010 Recommended Practices for Laser Beam Welding, Cutting, and Allied Processes
    C7.4/C7.4M:2008 Process Specification and Operator Qualification for Laser Beam Welding
    MACHINERY AND EQUIPMENT
    C2.19/C2.19M:2013 Specification for the Application of Thermal Spray Coatings to Machine Elements for OEM & Repair
    D14.1/D14.1M:2005 Specification for Welding of Industrial and Mill Cranes and Other Material Handling Equipment
    D14.3/D14.3M:2010-AMD1 Specification for Welding Earthmoving, Construction, and Agricultural Equipment
    D14.4/D14.4M:2012 Specification for Welded Joints in Machinery and Equipment
    D14.5/D14.5M:2009 Specification for Welding of Presses and Press Components
    D14.6/D14.6M:2012 Specification for Welding of Rotating Elements of Equipment
    D14.7/D14.7M:2005 Recommended Practices for Surfacing and Reconditioning of Industrial Mill Rolls
    D14.8M (ISO/TR 17844 IDT): 2009 Standard Methods for the Avoidance of Cold *****s
    D14.9/D14.9M:2013 Specification for Welding of Hydraulic Cylinders
    MANAGEMENT AND ECONOMICS
    DPW Design and Planning Manual for Cost-Effective Welding
    TIH-H The Industrial Hobarts
    TWM Total Welding Management
    MARINE
    D3.5:1993 Guide for Steel Hull Welding
    D3.6M:2010 Underwater Welding Code
    D3.9:2010 Specification for Classification of Weld-Through Paint Primers
    METALLURGY
    PRGWM The Practical Reference Guide to Welding Metallurgy: Key Concepts for Weldability
    WM1.4 Welding Metallurgy, Carbon and Alloy Steels, Volume 1, Fundamentals
    NICKEL
    G2.1M/G2.1:2012 Guide for the Joining of Wrought Nickel-Based Alloys
    OXYFUEL WELDING AND CUTTING
    C4.1:1977 (R2010) Criteria for Describing Oxygen-Cut Surfaces, and Oxygen Cutting Surface Roughness Gauge
    C4.2/C4.2M:2009 Recommended Practices for Safe Oxyfuel Gas Cutting Torch Operation
    C4.3/C4.3M:2007 Recommended Practices for Safe Oxyfuel Gas Heating Torch Operation
    C4.4/C4.4M:2007 Recommended Practices for Heat Shaping and Straightening with Oxyfuel Gas Heating Torches
    C4.5M:2012 Uniform Designation System for Oxyfuel Nozzles
    C4.6M:2006 (R2012) Thermal Cutting – Classification of Thermal Cuts – Geometric Product Specification and Quality Tolerances
    PIPING AND TUBING
    D10.4:1986 Recommended Practices for Welding Austenitic Chromium-Nickel Stainless Steel Piping and Tubing
    D10.8:1996 Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and Tubing
    D10.10/D10.10M:1999 (R2009) Recommended Practices for Local Heating of Welds in Piping and Tubing
    D10.11M/D10.11:2007 Guide for Root Pass Welding of Pipe Without Backing
    D10.12M/D10.12:2000 Guide for Welding Mild Steel Pipe
    D10.14M/D10.14:2010 Guide for Multipass Orbital Machine Pipe Groove Welding
    D10.18M/D10.18:2008 Guide for Welding Ferritic/Austenitic Duplex Stainless Steel Piping and Tubing
    PLASTICS
    B2.4:2012 Specification for Welding Procedure and Performance Qualification for Thermoplastics
    G1.1M/G1.1:2006 Guide to Ultrasonic Assembly of Thermoplastics
    G1.10M:2016 Guide for the Evaluation of Hot Gas, Hot Gas Extrusion, and Heated Tool Butt Thermoplastic Welds
    QUALITY PROCEDURES AND PERSONNEL
    B2.1/B2.1M:2014 Specification for Welding Procedure and Performance Qualification
    B2.1/B2.1M-BMG:2014 Base Metal Grouping for Welding Procedure and Performance Qualification
    B2.3/B2.3M:2012 Specification for Soldering Procedure and Performance Qualification
    B5.1:2013 Specification for the Qualification of Welding Inspectors
    B5.2:2001 Specification for the Qualification of Welding Inspector Specialists and Welding Inspector Assistants
    B5.4:2005 Specification for the Qualification of Welder Test Facilities
    B5.5:2011 Specification for the Qualification of Welding Educators
    B5.9:2006 Specification for the Qualification of Welding Supervisors
    B5.14:2009 Specification for the Qualification of Welding Sales Representatives
    B5.15:2010 Specification for the Qualification of Radiographic Interpreters
    B5.16:2006 Specification for the Qualification of Welding Engineers
    B5.17:2014 Specification for the Qualification of Welding Fabricators
    C1.5:2015 Specification for the Qualification of Resistance Welding Technicians
    C2.16/C2.16M:2002 Guide for Thermal-Spray Operator Qualification
    D16.4M/D16.4:2015 Specification for the Qualification of Robotic Arc Welding Personnel
    PAPQV The Professional’s Advisor on Procedure Qualification Variables
    RADIOGRAPHY
    RAILROADS
    D15.1/D15.1M:2012-AMD1 Railroad Welding Specification for Cars and Locomotives
    D15.2/D15.2M:2013 Recommended Practices for the Welding of Rails and Related Rail Components for Use by Rail Vehicles
    REFERENCE
    A1.1:2001 Metric Practice Guide for the Welding Industry
    A2.4:2012 Standard Symbols for Welding, Brazing, and Nondestructive Examination
    A3.0M/A3.0:2010 Standard Welding Terms and Definitions
    JWE Jefferson’s Welding Encyclopedia
    PHB-5 The Everyday Pocket Handbook on Metric Practices for the Welding Industry
    PRGP Practical Reference Guide to Positioning
    WHB-1-9 Welding Handbook Ninth Edition, Volume 1, Welding Science and Technology
    WHB-2-9 Welding Handbook Ninth Edition, Volume 2, Welding Processes, Part 1
    WHB-3-9 Welding Handbook Ninth Edition, Volume 3, Welding Processes, Part 2
    WHB-4-9 Welding Handbook Ninth Edition, Volume 4, Materials and Applications, Part 1
    WHB-5-9 Welding Handbook Ninth Edition, Volume 5, Materials and Applications, Part 2
    RESISTANCE WELDING
    A1.10M:2007 Specification for Calibration and Performance testing of Secondary Current Sensing Coils and Weld Monitors used in Single-Phase AC Resistance Welding
    C1.1M/C1.1:2012 Recommended Practices for Resistance Welding
    C1.4M/C1.4:2009 Specification for Resistance Welding of Carbon and Low-Alloy Steels
    J1.1M/J1.1:2013 Specification for Resistance Welding Controls
    RWM Resistance Welding Manual
    RWPH Resistance Welding Pocket Handbook
    ROBOTIC WELDING
    D16.1M/D16.1:2004 Specification for Robotic Arc Welding Safety
    D16.2M/16.2:2007 Guide for Components of Robotic and Automatic Arc Welding Installations
    D16.3M/ D16.3:2009 Risk Assessment Guide for Robotic Arc Welding
    HEALTH AND SAFETY
    EWH-1 thru 14 Effects of Welding on Health, Vol. I through XIV
    F1.1M:2006 Method for Sampling Airborne Particulates Generated by Welding and Allied Processes
    F1.2:2013 Laboratory Method for Measuring Fume Generation Rates and Total Fume Emission of Welding and Allied Processes
    F1.3:2006 A Sampling Strategy Guide for Evaluating Contaminants in the Welding Environment
    F1.6:2003 Guide for Estimating Welding Emissions for EPA and Ventilation Permit Reporting
    F2.3M:2011 Specification for Use and Performance of Transparent Welding Curtains and Screens
    F3.2M/F3.2:2001 Ventilation Guide for Weld Fume
    FUMES AND GASES Fumes and Gases in the Welding Environment
    Z49.1:2012 Safety in Welding, Cutting, and Allied Processes
    SHEET METAL
    D1.3/D1.3M:2008 Structural Welding Code—Sheet Steel
    D9.1M/D9.1:2012 Sheet Metal Welding Code
    SHIELDED METAL ARC WELDING
    PHB-7 The Everyday Pocket Handbook for Shielded Metal Arc Welding (SMAW)
    SHIELDING GASES
    A5.32M/A5.32 (ISO 14175 MOD):2011 Welding Consumables – Gases & Gas Mixtures for Fusion Welding and Allied Processes
    SOLDERING
    SHB Soldering Handbook
    GHSP Guideline for Hand Soldering Practices
    C3.11M/C3.11:2011 Specification for Torch Soldering
    STAINLESS STEEL
    A5.9/A5.9M:2012 Specification for Bare Stainless Steel Welding Electrodes and Rods
    D1.6/D1.6M:2007 Structural Welding Code—Stainless Steel
    G2.3M/G2.3:2012 Guide for the Joining of Solid Solution Austenitic Stainless Steels
    PASS The Professional’s Advisor on Welding of Stainless Steels
    WQS Welding Stainless Steel—Questions and Answers
    STEEL
    D1.1/D1.1M:2015 Structural Welding Code-Steel
    PHB-1 The Everyday Pocket Handbook for Arc Welding Steel
    STRUCTURAL WELDING
    D1.1 CCRM:2015 Code Clinic for Study of AWS D1.1 Structural Welding Code—Steel, Reference Manual
    D1.4/D1.4M:2011 Structural Welding Code—Reinforcing Steel
    D1.5M/D1.5:2015 Bridge Welding Code
    D1.7/D1.7M:2010 Guide to Repair and Strengthening of Existing Structures
    D1.8/D1.8M:2009 Structural Welding Code—Seismic Supplement
    D1.9/D1.9M:2015 Structural Welding Code—Titanium
    PHB-3 The Everyday Pocket Handbook on Welded Joint Details for Structural Applications
    PHB-6 The Everyday Pocket Handbook for Visual Inspection of D1.1 Structural Welding Code’s Fabrication & Welding Requirements
    STUD WELDING
    SURFACING
    SYMBOLS
    TERMINOLOGY
    THERMAL SPRAYING
    C2.18:1993 Guide for the Protection of Steel with Thermal Sprayed Coatings of Aluminum and Zinc and Their Alloys and Composites
    C2.21M/C2.21:2015 Specification for Thermal Spray Equipment Acceptance Inspection
    C2.25/C2.25M:2012 Specification for Thermal Spray Feedstock — Wire and Rods
    TSM Thermal Spray Manual
    TSS Thermal Spraying Practice, Theory and Application
    TST ASM Handbook Volume 5A: Thermal Spray Technology
    THERMITE WELDING
    TITANIUM
    G2.4/G2.4M:2014 Guide for the Fusion Welding of Titanium and Titanium Alloys
    WELDING CURTAINS AND SCREENS
    ZINC COATINGS
    WZC Welding Zinc-Coated Steels
    ZIRCONIUM
    G2.5/G2.5M:2012 Guide for the Fusion Welding of Zirconium and Zirconium Alloys
    If someone have missing codes, please share it...let's make AWS complete
    links:
    or
  3. Re: AWS Codes, Publications....
    I'm looking for AWS D16.4 Robotic Welding, the 2015 edition. In this list it is not bolded, but in the files it is the 2005 version. Does anyone have the updated 2015 code that they could share please?
    Dear BornToSin Bro,
    Many thanks for shared
    Mar 2011
    Portugal
    Great work!!!
    THX!!!
    AWS Supplement to above, remember, you do not need the Reaffirmed if you have the original document. There are no changes when reaffirmed. Here are 27 additional files.
    thank you for useful update
    Thank for shared useful material.
  11. Re: AWS Codes, Publications....
    thanks!!
    will do update during 2nite...
    ok, thanx to Marty Thompson...
    bolded are here, unbolded are missing either in total either current valid edition:
    AEROSPACE
    ALUMINIUM
    AUTOMOTIVE
    BRIDGES
    CARBON STEEL
    CAST IRON
    CERTIFICATION
    CHARTS
    COMPUTERIZATION
    CUTTING
    DESIGN
    FRICTION WELDING
    INSPECTION
    LASER BEAM WELDING
    MARINE
    METALLURGY
    NICKEL
    PIPING AND TUBING
    PLASTICS
    RADIOGRAPHY
    RAILROADS
    REFERENCE
    RESISTANCE WELDING
    ROBOTIC WELDING
    HEALTH AND SAFETY
    SHEET METAL
    SHIELDING GASES
    SOLDERING
    STAINLESS STEEL
    STEEL
    STRUCTURAL WELDING
    STUD WELDING
    SURFACING
    SYMBOLS
    TERMINOLOGY
    THERMAL SPRAYING
    THERMITE WELDING
    TITANIUM
    ZINC COATINGS
    ZIRCONIUM
    updated links:
    or
  14. #11
    Wit-w welding inspection technology workbook - fifth edition 2008
  16. #12
    AWS - WZC D19.0-72 Welding Zinc-Coated Steel
  1. Publications Required
    By mdjaved91 in forum Safety And Environment
    Last Post: 08-12-2015, 04:35 AM
  2. EEMUA Publications
    By Guniawala in forum Safety And Environment
    Last Post: 05-31-2015, 04:06 AM
  3. API New Standard Publications
    By Shabbir2009 in forum Pipeline And Fluid Flow
    Last Post: 03-10-2015, 08:06 AM
  4. Energy institue publications model codes related to electrical safety required
    By ANANDAN4172 in forum Electrical & Power Engineering
    Last Post: 04-01-2014, 10:56 AM
  5. Replies: 50
    Last Post: 06-30-2011, 05:22 AM
