Thread: Piping Material Classes EUROPEAN NORMATIVE
  1. Piping Material Classes EUROPEAN NORMATIVE
    Hello,
    please can anyone of you upload some piping classes in european normative? I need to develop some of these classes but I just need a reference, a place where to start (I developed hundreds in ASTM/ASME but no experience in CEN normative).
    Thank you very much. Regards,
    EStill
    Jun 2013
    D-59227 Ahlen , Germany
    Re: Piping Material Classes EUROPEAN NORMATIVE
    Looking for CEN will not be very successfull. You should have a look to DIN , EN, ISO and DIN-EN-ISO standards. DIN means Deutsche Industrie Norm ; EN means European Norm ; ISO means International Organization for Standardisation. The German DIN are leading all over Europe and more for industrial standards. Step by step the other European Countries have taken over the German DIN norms and so after a while, when all agreed, it becomes a DIN-EN. In the next step, when more countries out of Europe also haven taken over these standards, it becomes a DIN-EN-ISO. New Standards, which are developed by the experts of all involved countries together, will be an ISO from the beginning. What are you looking for in detail?
    Greetings QA-Inspector
  5. Re: Piping Material Classes EUROPEAN NORMATIVE
    I search for piping material classes developed accordingly to EN 13480 (equivalent to ASME B31.3) with materials according to CEN standards (EN 10216, EN 10217, ...) instead of the most common ASTM. Thank you for who could share such a material.
    Oct 2008
    The Netherlands
    Blog Entries
    14
    The piping Code in Europe is EN 13480 (several volumes: Materials / design/ testing/ etc..)
    I believe you can find it in this site.
    Part one of this standard: Title: General. Deals also with PED ( Pressure European Directive)matters, with which you must comply within Europe.
    With PED, and depending on the Nominal diameter + the design pressure and type of fluid (Liquid or gas) then you make some classification which defines the type calculations , inspection , etc...
    Again you can find on intern free software for making this type of classification
    You have always to work with a NOBO (notified body) which is approved to conduct checking as per PED.
    For instance in Holland or UK, the NOBO is Lloyds, in Germany is TUV, in Belgium Vincotte, in France DNV or Service des mines, etc..you may also have several NOBOs working in one country
    In each part of EN 13480 you have at the end appendices , I believe termed Z, mandatory , which tells how compliant you are with PED.
    I disagree a but ( and my apologies) DIN is not leading , that is why we have EN ..it is endorsed by every one in Europe. EN was st up to break the monopoly of one country...and to keep the market open and get rid of nationalism and national preference, all suppliers and manufactures must be equally treated providing compliance with PED.
    For instance Shell in Holland and UK , have all their materials according to ASTM , and piping and flange sizes are in in inches which are according to B31.3 and B31.1 ( thus in inches and ASTM), etc..they do not comply with DIN, and the DIN flanges ( rated in PN, ex. PN 16 )are somewhat thinner than the ones in B16.5 ( which are rated in Pounds (ex. 300 #) ..still Shell uses now the whole PED procedures.
    Same for BP, Total. And it foolish to imagine those major oil company changing all their assets , stock and existing systems to DIN
    Above is also valid for vessels/ columns/ heat exchangers ...but the code is then EN 13445
  1. European standards for piping
    By vvvv in forum Pipeline And Fluid Flow
    Last Post: 10-28-2015, 10:41 PM
  2. Piping classes-Basis of design (Petronas)
    By lserpach in forum Mechanical Engineering
    Last Post: 07-06-2013, 08:56 AM
  3. European standards for piping & instrumentation
    By eddiem in forum Petroleum Refining
    Last Post: 05-23-2013, 09:09 AM
  4. European or DIN standards for Plastic Piping
    By alavi1364 in forum Pipeline And Fluid Flow
    Last Post: 03-05-2012, 11:12 AM
