Thread: Piping for oil system, should be instaled above or under ground?
  1. Piping for oil system, should be instaled above or under ground?
    hi guys,
    i've a quite pain in the neck discussion with my co-partner about the above subject.
    anyone please give some suggestion?
    my understanding is piping should be instaled above ground, for maintenance purpose.
    Jonas
  3. Re: Piping for oil system, should be instaled above or under ground?
    pipeline shall be installed above ground for easy mainteance, but if the area is prone for fire/explosion then pipeline shall laid underground!
    hope this helps
  5. Re: Piping for oil system, should be instaled above or under ground?
    Quote Originally Posted by rrkumar50 View Post
    hope this helps
    You mean that all piping system for oil at oil plant should be installed underground?
  1. Replies: 3
    Last Post: 04-09-2016, 05:50 AM
  2. Piping System Fundamentals
    By mamacint1980 in forum Mechanical Engineering
    Last Post: 06-17-2013, 05:26 AM
  3. Analisis piping system
    By masp in forum Pipeline And Fluid Flow
    Last Post: 11-17-2010, 10:25 PM
  4. Piping System Manual
    By d_kushwah in forum Pipeline And Fluid Flow
    Last Post: 02-14-2010, 01:01 PM
