Results 1 to 6 of 6
Thread: CEN Standards Collection 335/370: CEN TC 184-Advanced Technical Ceramics
    full list:
    EN 623-1:2006 Advanced technical ceramics - Monolithic ceramics - General and textural properties - Part 1: Determination of the presence of defects by dye penetration
    EN 623-2:1993 Advanced technical ceramics - Monolithic ceramics - General and textural properties - Part 2: Determination of density and porosity
    EN 623-4:2004 Advanced technical ceramics - Monolithic ceramics - General and textural properties - Part 4: Determination of surface roughness
    EN 658-1:1998 Advanced technical ceramics - Mechanical properties of ceramic composites at room temperature - Part 1: Determination of tensile properties
    EN 658-3:2002 Advanced technical ceramics - Mechanical properties of ceramic composites at room temperature - Part 3: Determination of flexural strength
    EN 658-4:2003 Advanced technical ceramics - Mechanical properties of ceramic composites at room temperature - Part 4: Determination of interlaminar shear strength by compression loading of notched test specimens
    EN 658-5:2002 Advanced technical ceramics - Mechanical properties of ceramic composites at room temperature - Part 5: Determination of interlaminar shear strength by short span bend test (three points)
    EN 725-1:2007 Advanced technical ceramics - Methods of test for ceramic powders - Part 1: Determination of impurities in alumina
    EN 725-2:2007 Advanced technical ceramics - Methods of test for ceramic powders - Part 2: Determination of impurities in barium titanate
    EN 725-3:2007 Advanced technical ceramics - Methods of test for ceramic powders - Part 3: Determination of the oxygen content of non-oxides by thermal extraction with a carrier gas
    EN 725-4:2006 Advanced technical ceramics - Methods of test for ceramic powders - Part 4: Determination of oxygen content in aluminium nitride by XRF analysis
    EN 725-5:2007 Advanced technical ceramics - Methods of test for ceramic powders - Part 5: Determination of particle size distribution
    EN 725-5:2007/AC:2007 Advanced technical ceramics - Methods of test for ceramic powders - Part 5: Determination of particle size distribution
    EN 725-10:2007 Advanced technical ceramics - Methods of test for ceramic powders - Part 10: Determination of compaction properties
    EN 725-11:2006 Advanced technical ceramics - Methods of test for ceramic powders - Part 11: Determination of densification on natural sintering
    EN 725-12:2001 Advanced technical ceramics - Methods of test for ceramic powders - Part 12: Chemical analysis of zirconia
    EN 820-1:2002 Advanced technical ceramics - Methods of testing monolithic ceramics - Thermonechanical properties - Part 1: Determination of flexural strength at elevated temperatures
    EN 820-2:2003 Advanced technical ceramics - Methods of testing monolithic ceramics - Thermo-mechanical properties - Part 2: Determination of self-loaded deformation
    EN 820-3:2004 Advanced technical ceramics - Methods of testing monolithic ceramics - Thermomechanical properties - Part 3: Determination of resistance to thermal shock by water quenching
    EN 820-4:2009 Advanced technical ceramics - Thermomechanical properties of monolithic ceramics - Part 4: Determination of flexural creep deformation at elevated temperatures
    EN 820-5:2009 Advanced technical ceramics - Thermomechanical properties of monolithic ceramics - Part 5: Determination of elastic moduli at elevated temperatures
    EN 821-1:1995 Advanced technical ceramics - Monolithic ceramics - Thermo-physical properties - Part 1: Determination of thermal expansion
    EN 821-2:1997 Advanced technical ceramics - Monolithic ceramics - Thermo-physical properties - Part 2: Determination of thermal diffusivity by the laser flash (or heat pulse) method
    EN 821-3:2005 Advanced technical ceramics - Monolithic ceramics. Thermo-physical properties - Part 3: Determination of specific heat capacity
    EN 843-1:2006 Advanced technical ceramics - Mechanical properties of monolithic ceramics at room temperature - Part 1: Determination of flexural strength
    EN 843-2:2006 Advanced technical ceramics - Mechanical properties of monolithic ceramics at room temperature - Part 2: Determination of Young's modulus, shear modulus and Poisson's ratio
    EN 843-3:2005 Advanced technical ceramics - Mechanical properties of monolithic ceramics at room temperature - Part 3: Determination of subcritical ***** growth parameters from constant stressing rate flexural strength tests
    EN 843-4:2005 Advanced technical ceramics - Mechanical properties of monolithic ceramics at room temperature - Part 4: Vickers, Knoop and Rockwell superficial hardness
    EN 843-5:2006 Advanced technical ceramics - Mechanical properties of monolithic ceramics at room temperature - Part 5: Statistical analysis
    EN 843-6:2009 Advanced technical ceramics - Mechanical properties of monolithic ceramics at room temperature - Part 6: Guidance for fractographic investigation
    EN 843-7:2010 Advanced technical ceramics - Mechanical properties of monolithic ceramics at room temperature - Part 7: C-ring tests
    EN 843-8:2010 Advanced technical ceramics - Mechanical properties of monolithic ceramics at room temperature - Part 8: Guidelines for conducting proof tests
    CEN/TS 843-9:2010 Advanced technical ceramics - Mechanical properties of monolithic ceramics at room temperature - Part 9: Method of test for edge-chip resistance
    EN 1006:2009 Advanced technical ceramics - Monolithic ceramics - Guidance on the selection of test pieces for the evaluation of properties
    EN 1007-1:2002 Advanced technical ceramics - Ceramic composites - Methods of test for reinforcement - Part 1: Determination of size content
    EN 1007-2:2002 Advanced technical ceramics - Ceramics composites - Methods of test for reinforcement - Part 2: Determination of linear density
    EN 1007-3:2002 Advanced technical ceramics - Ceramic composites - Methods of test for reinforcement - Part 3: Determination of filament diameter and cross-section area
    EN 1007-4:2004 Advanced technical ceramics - Ceramic composites - Methods of test for reinforcement - Part 4: Determination of tensile properties of filaments at ambient temperature
    EN 1007-4:2004/AC:2007 Advanced technical ceramics - Ceramic composites - Methods of test for reinforcement - Part 4: Determination of tensile properties of filaments at ambient temperature
    EN 1007-5:2010 Advanced technical ceramics - Ceramic composites - Methods of test for reinforcements - Part 5: Determination of distribution of tensile strength and of tensile strain to failure of filaments within a multifilament tow at ambient temperature
    EN 1007-6:2007 Advanced technical ceramic - Ceramic composites - Methods of test for reinforcements - Part 6: Determination of tensile properties of filaments at high temperature
    EN 1007-7:2010 Advanced technical ceramics - Ceramic composites - Methods of test for reinforcements - Part 7: Determination of the distribution of tensile strength and of tensile strain to failure of filaments within a multifilament tow at high temperature
    EN 1071-4:2006 Advanced technical ceramics - Methods of test for ceramic coatings - Part 4: Determination of chemical composition by electron probe microanalysis (EPMA)
    EN 1071-10:2009 Advanced technical ceramics - Methods of test for ceramic coatings - Part 10: Determination of coating thickness by cross sectioning
    CEN/TS 1071-11:2005 Advanced technical ceramics - Methods of test for ceramic coatings - Part 11: Determination of internal stress by the Stoney formula
    EN 1071-12:2010 Advanced technical ceramics - Methods of test for ceramic coatings - Part 12: Reciprocating wear test
    EN 1071-13:2010 Advanced technical ceramics - Methods of test for ceramic coatings - Part 13: Determination of wear rate by the pin-on-disk method
    EN 1159-1:2003 Advanced technical ceramics - Ceramic composites - Thermophysical properties - Part 1: Determination of thermal expansion
    EN 1159-1:2003/AC:2007 Advanced technical ceramics - Ceramic composites - Thermophysical properties - Part 1: Determination of thermal expansion
    EN 1159-2:2003 Advanced technical ceramics - Ceramic composites - Thermophysical properties - Part 2: Determination of thermal diffusivity
    EN 1159-3:2003 Advanced technical ceramics - Ceramic composites, thermophysical properties - Part 3: Determination of specific heat capacity
    EN 1159-3:2003/AC:2008 Advanced technical ceramics - Ceramic composites, thermophysical properties - Part 3: Determination of specific heat capacity
    CEN/TS 1159-4:2004 Advanced technical ceramics - Ceramic composites - Thermophysical properties - Part 4: Determination of thermal conductivity
    EN 1389:2003 Advanced technical ceramics - Ceramic composites - Physical properties - Determination of density and apparent porosity
    EN 1894:2005 Advanced technical ceramics - Mechanical properties of ceramic composites at high temperature under inert atmosphere - Determination of shear strength by compression loading of notched specimens
    EN 12289:2005 Advanced technical ceramics - Mechanical properties of ceramic composites at ambient temperature - Determination of in-plane shear properties
    EN 12788:2005 Advanced technical ceramics - Mechanical properties of ceramic composites at high temperature under inert atmosphere - Determination of flexural strength
    EN 12789:2002 Advanced technical ceramics - Mechanical properties of ceramic composites at high temperature under air at atmospheric pressure - Determination of flexural strength
    EN 12923-1:2006 Advanced technical ceramics - Monolithic ceramics - Part 1: General practice for undertaking corrosion tests
    ENV 12923-2:2001 Advanced technical ceramics - Monolithic ceramics - Part 2: Oxidation test
    CEN/TR 13233:2007 Advanced technical ceramics - Notations and symbols
    CEN/TR 13233:2007/AC:2007 Advanced technical ceramics - Notations and symbols
    EN 13234:2006 Advanced technical ceramics - Mechanical properties of ceramic composites at ambient temperature - Evaluation of the resistance to ***** propagation by notch sensitivity testing
    EN 13235:2006 Advanced technical ceramics - Mechanical properties of ceramic composites at high temperature under inert atmosphere - Determination of creep behaviour
    EN ISO 13383-1:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Microstructural characterization - Part 1: Determination of grain size and size distribution (ISO 13383-1:2012)
    EN ISO 13383-2:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Microstructural characterization - Part 2: Determination of phase volume fraction by evaluation of micrographs (ISO 13383-2:2012)
    EN 14186:2007 Advanced technical ceramics - Mechanical properties of ceramic composites at room temperature - Determination of elastic properties by an ultrasonic technique
    ENV 14226:2002 Advanced technical ceramics - Test methods for ceramic powders - Determination of calcium, magnesium, iron and aluminium in silicon nitride by using flame atomic absorption spectroscopy (FAAS) or inductively coupled plasma atomic emission spectroscopy (IC
    EN 14232:2009 Advanced technical ceramics - Terms, definitions and abbreviations
    ENV 14273:2002 Advanced technical ceramics - Ceramic powders - Determination of crystalline phases in zirconia
    CEN/TS 14425-1:2003 Advanced technical ceramics - Test methods for determination of fracture toughness of monolithic ceramics - Part 1:Guide to test method selection
    EN 14425-3:2010 Advanced technical ceramics - Test methods for determination of fracture toughness of monolithic ceramics - Part 3: Chevron notched beam (CNB) method
    EN ISO 14544:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Mechanical properties of ceramic composites at high temperature - Determination of compression properties (ISO 14544:2013)
    EN ISO 14574:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Mechanical properties of ceramic composites at high temperature - Determination of tensile properties (ISO 14574:2013)
    EN ISO 14604:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Methods of test for ceramic coatings - Determination of fracture strain (ISO 14604:2012)
    EN ISO 14629:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of flowability of ceramic powders (ISO 14629:2012)
    EN 15158:2006 Advanced technical ceramics - Mechanical properties of ceramic composites at high temperature under inert atmosphere - Determination of fatigue properties at constant amplitude
    EN 15335:2007 Advanced technical ceramics - Ceramic composites - Determination of elastic properties by resonant beam method up to 2 000 °C
    EN 15365:2010 Advanced technical ceramics - Mechanical properties of ceramic fibres at high temperature in a non-reactive environment - Determination of creep behaviour by the cold end method
    CEN/TS 15658:2007 Advanced technical ceramics - Mechanical properties of ceramic fibres at high temperature under non-reactive environment - Determination of creep behaviour by the hot end method
    EN ISO 15732:2005 Fine ceramics (advanced ceramics, advanced technical ceramics) - Test method for fracture toughness of monolithic ceramics at room temperature by single edge pre*****ed beam (SEPB) method (ISO 15732:2003)
    CEN/TS 15866:2009 Advanced technical ceramics - Ceramic composites - Determination of the thermal diffusivity of ceramic fibres
    CEN/TS 15880:2009 Advanced technical ceramics - Ceramic composites - Determination of the fibre/matrix interfacial frictional shear stress at room temperature by a single fibre push-out method
    CEN/TS 15881:2009 Advanced technical ceramics - Ceramic composites - Determination of the fibre/matrix interfacial frictional shear stress at room temperature by tensile tests on mini-composites
    EN ISO 17140:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Mechanical properties of ceramic composites at room temperature - Determination of fatigue properties at constant amplitude (ISO 17140:2014)
    EN ISO 17142:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Mechanical properties of ceramic composites at high temperature in air at atmospheric pressure - Determination of fatigue properties at constant amplitude (ISO 17142:2014)
    EN ISO 17161:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Ceramic composites - Determination of the degree of misalignment in uniaxial mechanical tests (ISO 17161:2014)
    EN ISO 18452:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of thickness of ceramic films by contact-probe profilometer (ISO 18452:2005)
    EN ISO 18753:2005 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of absolute density of ceramic powders by pyknometer (ISO 18753:2004)
    EN ISO 18756:2005 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of fracture toughness of monolithic ceramics at room temperature by the surface ***** in flexure (SCF) method (ISO 18756:2003)
    EN ISO 18757:2005 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of specific surface area of ceramic powders by gas adsorption using the BET method (ISO 18757:2003)
    EN ISO 20502:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of adhesion of ceramic coatings by scratch testing (ISO 20502:2005 including Cor 1:2009)
    EN ISO 20504:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Test method for compressive behaviour of continuous fibre-reinforced composites at room temperature (ISO 20504:2006)
    EN ISO 23145-1:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of bulk density of ceramic powders - Part 1: Tap density (ISO 23145-1:2007)
    EN ISO 23145-2:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of bulk density of ceramic powders - Part 2: Untapped density (ISO 23145-2:2012)
    EN ISO 23146:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Test methods for fracture toughness of monolithic ceramics - Single-edge V-notch beam (SEVNB) method (ISO 23146:2012)
    EN ISO 26423:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of coating thickness by crater-grinding method (ISO 26423:2009)
    EN ISO 26424:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of the abrasion resistance of coatings by a micro-scale abrasion test (ISO 26424:2008)
    EN ISO 26443:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Rockwell indentation test for evaluation of adhesion of ceramic coatings (ISO 26443:2008)
    missing a lot:
    links:
    Re: CEN Standards Collection 335/340: CEN TC 184-Advanced Tecnical Ceramics
    update:
    CEN/TR 13233:2007 Advanced technical ceramics - Notations and symbols - added missing standard
    CEN/TS 15658:2007 Advanced technical ceramics - Mechanical properties of ceramic fibres at high temperature under non-reactive environment - Determination of creep behaviour by the hot end method - added missing standard
    EN ISO 17140:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Mechanical properties of ceramic composites at room temperature - Determination of fatigue properties at constant amplitude (ISO 17140:2014) - added missing standard
    EN ISO 17142:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Mechanical properties of ceramic composites at high temperature in air at atmospheric pressure - Determination of fatigue properties at constant amplitude (ISO 17142:2014) - added missing standard
    missing list:
    links:
    or
    Re: CEN Standards Collection 335/350: CEN TC 184-Advanced Tecnical Ceramics
    update:
    EN ISO 18452:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of thickness of ceramic films by contact-probe profilometer (ISO 18452:2005) - added missing standard thanks to Amjad Malik
    EN ISO 20502:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of adhesion of ceramic coatings by scratch testing (ISO 20502:2005 including Cor 1:2009) - added missing standard thanks to Amjad Malik
    EN ISO 20504:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Test method for compressive behaviour of continuous fibre-reinforced composites at room temperature (ISO 20504:2006) - added missing standard
    EN ISO 23145-1:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Determination of bulk density of ceramic powders - Part 1: Tap density (ISO 23145-1:2007) - added missing standard
    EN ISO 23146:2016 Fine ceramics (advanced ceramics, advanced technical ceramics) - Test methods for fracture toughness of monolithic ceramics - Single-edge V-notch beam (SEVNB) method (ISO 23146:2012) - added missing standard thanks to Amjad Malik
    missing list:
    new links:
    or
    Re: CEN Standards Collection 335/370: CEN TC 184-Advanced Technical Ceramics
    update:
    added missing standards:
    EN ISO 26424:2016 Fine ceramics (advanced ceramics* advanced technical ceramics) - Determination of the abrasion resistance of coatings by a micro-scale abrasion test (ISO 26424:2008)
    EN ISO 26443:2016 Fine ceramics (advanced ceramics* advanced technical ceramics) - Rockwell indentation test for evaluation of adhesion of ceramic coatings (ISO 26443:2008)
    still missing:
    new link:
    update:
    EN or BQ
    ENV 14226:2002 Advanced technical ceramics - Test methods for ceramic powders - Determination of calcium* magnesium* iron and aluminium in silicon nitride by using flame atomic absorption spectroscopy (FAAS) or inductively coupled plasma atomic emission spectroscopy (IC
    EN ISO 15732:2005 Fine ceramics (advanced ceramics* advanced technical ceramics) - Test method for fracture toughness of monolithic ceramics at room temperature by single edge pre*****ed beam (SEPB) method (ISO 15732:2003)
    EN ISO 18753:2005 Fine ceramics (advanced ceramics* advanced technical ceramics) - Determination of absolute density of ceramic powders by pyknometer (ISO 18753:2004)
    EN ISO 18756:2005 Fine ceramics (advanced ceramics* advanced technical ceramics) - Determination of fracture toughness of monolithic ceramics at room temperature by the surface ***** in flexure (SCF) method (ISO 18756:2003)
    EN ISO 18757:2005 Fine ceramics (advanced ceramics* advanced technical ceramics) - Determination of specific surface area of ceramic powders by gas adsorption using the BET method (ISO 18757:2003)
    EN ISO 20504:2016 Fine ceramics (advanced ceramics* advanced technical ceramics) - Test method for compressive behaviour of continuous fibre-reinforced composites at room temperature (ISO 20504:2006)
    EN ISO 23145-1:2016 Fine ceramics (advanced ceramics* advanced technical ceramics) - Determination of bulk density of ceramic powders - Part 1: Tap density (ISO 23145-1:2007)
    the missing:
  9. Re: CEN Standards Collection 335/370: CEN TC 184-Advanced Technical Ceramics
    OOOOH Yeesss* Thanks a lot BornToSin !!
    I hope Missing:
    COMMING SOON!
  1. CEN Standards Collection 29/370: CEN SS F01 - Technical Drawings
    Last Post: 11-21-2017, 03:10 AM
  2. Replies: 3
    Last Post: 08-28-2017, 05:32 AM
  3. Materials Literature Collection 115/200 - Ceramics
    Last Post: 12-06-2016, 04:24 PM
  4. Replies: 0
    Last Post: 09-09-2011, 02:20 PM
  5. Handbook of Advanced Ceramics Machining
    By Abdel fatah in forum Mechanical Engineering
    Last Post: 01-22-2009, 10:05 PM
