full list:
EN ISO 186:2002 Paper and board - Sampling to determine average quality (ISO 186:2002)
EN ISO 216:2007 Writing paper and certain classes of printed matter - Trimmed sizes - A and B series, and indication of machine direction (ISO 216:2007)
EN ISO 217:2013 Paper - Untrimmed sizes - Designation and tolerances for primary and supplementary ranges, and indication of machine direction (ISO 217:2013)
EN ISO 287:2009 Paper and board - Determination of moisture content of a lot - Oven-drying method (ISO 287:2009)
EN ISO 534:2011 Paper and board - Determination of thickness, density and specific volume (ISO 534:2011)
EN ISO 535:2014 Paper and board - Determination of water absorptiveness - Cobb method (ISO 535:2014)
EN ISO 536:2012 Paper and board - Determination of grammage (ISO 536:2012)
EN ISO 638:2008 Paper, board and pulps - Determination of dry matter content - Oven-drying method (ISO 638:2008)
EN 643:2014 Paper and board - European list of standard grades of paper and board for recycling
EN 645:1993 Paper and board intended to come into contact with foodstuffs - Preparation of a cold water extract
EN 646:2006 Paper and board intended to come into contact with foodstuffs - Determination of colour fastness of dyed paper and board
EN 647:1993 Paper and board intended to come into contact with foodstuffs - Preparation of a hot water extract
EN 648:2006 Paper and board intended to come into contact with foodstuffs - Determination of the fastness of fluorescent whitened paper and board
EN ISO 801-1:1996 Pulps - Determination of saleable mass in lots - Part 1: Pulp baled in sheet form (ISO 8001-1:1994)
EN ISO 801-3:1996 Pulps - Determination of saleable mass in lots - Part 3: Unitized bales (ISO 801-3:1994)
EN 920:2000 Paper and board intended to come into contact with foodstuffs - Determination of dry matter content in an aqueous extract
EN 1104:2005 Paper and board intended to come into contact with foodstuffs - Determination of the transfer of antimicrobial constituents
EN 1230-1:2009 Paper and board intended to come into contact with foodstuffs - Sensory analysis - Part 1: Odour
EN 1230-2:2009 Paper and board intended to come into contact with foodstuffs - Sensory analysis - Part 2: Off-flavour (taint)
EN 1541:2001 Paper and board intended to come into contact with foodstuffs - Determination of formaldehyde in an aqueous extract
EN ISO 1924-2:2008 Paper and board - Determination of tensile properties - Part 2: Constant rate of elongation method (20 mm/min) (ISO 1924-2:2008)
EN ISO 1974:2012 Paper - Determination of tearing resistance - Elmendorf method (ISO 1974:2012)
EN ISO 2758:2014 Paper - Determination of bursting strength (ISO 2758:2014)
EN ISO 2759:2014 Board - Determination of bursting strength (ISO 2759:2014)
EN ISO 3035:2011 Corrugated fibreboard - Determination of flat crush resistance (ISO 3035:2011)
EN ISO 3037:2013 Corrugated fibreboard - Determination of edgewise crush resistance (unwaxed edge method) (ISO 3037:2013)
EN ISO 4119:1996 Pulps - Determination of stock concentration (ISO 4119:1995)
EN ISO 5263-1:2004 Pulps - Laboratory wet disintegration - Part 1: Disintegration of chemical pulps (ISO 5263-1:2004)
EN ISO 5263-2:2004 Pulps - Laboratory wet disintegration - Part 2: Disintegration of mechanical pulps at 20 degrees C (ISO 5263-2:2004)
EN ISO 5263-3:2004 Pulps - Laboratory wet disintegration - Part 3: Disintegration of mechanical pulps at > 85 degrees C (ISO 5263-3:2004)
EN ISO 5264-2:2011 Pulps - Laboratory beating - Part 2: PFI mill method (ISO 5264-2:2011)
EN ISO 5267-1:2000 Pulps - Determination of drainability - Part 1: Schopper-Riegler method (ISO 5267-1:1999)
EN ISO 5267-1:2000/AC:2002 Pulps - Determination of drainability - Part 1: Schopper-Riegler method (ISO 5267-1:1999/Cor.1:2001)
EN ISO 5269-1:2005 Pulps - Preparation of laboratory sheets for physical testing - Part 1: Conventional sheet-former method (ISO 5269-1:2005)
EN ISO 5269-2:2004 Pulps - Preparation of laboratory sheets for physical testing - Part 2: Rapid-Köthen method (ISO 5269-2:2004)
EN ISO 5270:2012 Pulps - Laboratory sheets - Determination of physical properties (ISO 5270:2012)
EN ISO 5350-1:2006 Pulps - Estimation of dirt and shives - Part 1: Inspection of laboratory sheets by transmitted light (ISO 5350-1:2006)
EN ISO 5350-2:2006 Pulps - Estimation of dirt and shives - Part 2: Inspection of mill sheeted pulp by transmitted light (ISO 5350-2:2006)
EN ISO 7263:2011 Corrugating medium - Determination of the flat crush resistance after laboratory fluting (ISO 7263:2011)
EN ISO 8254-1:2009 Paper and board - Measurement of specular gloss - Part 1: 75 degree gloss with a converging beam, TAPPI method (ISO 8254-1:2009)
EN ISO 8254-2:2003 Paper and board - Measurement of specular gloss - Part 2: 75° gloss with a parallel beam, DIN method (ISO 8254-2:2003)
EN ISO 9706:1998 Information and documentation - Paper for documents - Requirements for permanence (ISO 9706:1994)
EN 12281:2002 Printing and business paper - Requirements for copy paper for dry toner imaging processes
EN 12283:2002 Printing and business paper - Determination of toner adhesion
EN 12497:2005 Paper and board - Paper and board intended to come into contact with foodstuffs - Determination of mercury in an aqueous extract
EN 12498:2005 Paper and board - Paper and board intended to come into contact with foodstuffs - Determination of cadmium and lead in an aqueous extract
EN ISO 12625-1:2011 Tissue paper and tissue products - Part 1: General guidance on terms (ISO 12625-1:2011)
EN ISO 12625-3:2014 Tissue paper and tissue products - Part 3: Determination of thickness, bulking thickness and apparent bulk density and bulk (ISO 12625-3:2014)
EN ISO 12625-4:2005 Tissue paper and tissue products - Part 4: Determination of tensile strength, stretch at break and tensile energy absorption (ISO 12625-4:2005)
EN ISO 12625-5:2005 Tissue paper and tissue products - Part 5: Determination of wet tensile strength (ISO 12625-5:2005)
EN ISO 12625-6:2005 Tissue paper and tissue products - Part 6: Determination of grammage (ISO 12625-6:2005)
EN ISO 12625-7:2014 Tissue paper and tissue products - Part 7: Determination of optical properties - Measurement of brightness and colour with D65/10° (outdoor daylight) (ISO 12625-7:2014)
EN ISO 12625-8:2010 Tissue paper and tissue products - Part 8: Water-absorption time and water-absorption capacity, basket-immersion test method (ISO 12625-8:2010)
EN ISO 12625-9:2015 Tissue paper and tissue products - Part 9: Determination of ball burst strength (ISO 12625-9:2015)
EN ISO 12625-11:2012 Tissue paper and tissue products - Part 11: Determination of wet ball burst strength (ISO 12625-11:2012)
EN ISO 12625-12:2010 Tissue paper and tissue products - Part 12: Determination of tensile strength of perforated lines - Calculation of perforation efficiency (ISO 12625-12:2010)
EN ISO 12625-15:2015 Tissue paper and tissue products - Part 15: Determination of optical properties - Measurement of brightness and colour with C/2° (indoor daylight) illuminant (ISO 12625-15:2015)
EN ISO 12625-16:2015 Tissue paper and tissue products - Part 16: Determination of optical properties - Opacity (paper backing) - Diffuse reflectance method (ISO 12625-16:2015)
EN 12858:1999 Paper - Printing and business paper - Requirements for continuous stationery
EN 13676:2001 Polymer coated paper and board intended for food contact - Detection of pinholes
EN 14086:2003 Paper and board - Measurement of specular gloss - 45° gloss with a parallel beam, DIN method
EN 14338:2003 Paper and board intended to come into contact with foodstuffs - Conditions for determination of migration from paper and board using modified polyphenylene oxide (MPPO) as a simulant
EN ISO 14453:2014 Pulps - Determination of acetone-soluble matter (ISO 14453:2014)
EN 14719:2005 Pulp, paper and board - Determination of the Diisopropylnaphthalene (DIPN) content by solvent extraction
EN ISO 15318:1999 Pulp, paper and board - Determination of 7 specified polychlorinated biphenyls (PCB) (ISO 15318:1999)
EN ISO 15320:2011 Pulp, paper and board - Determination of pentachlorophenol in an aqueous extract (ISO 15320:2011)
EN 15519:2007 Paper and board intended to come into contact with foodstuffs - Preparation of an organic solvent extract
CEN/TR 15645-1:2008 Paper and board intended to come into contact with foodstuffs - Calibration of the odour test - Part 1: Odour
CEN/TR 15645-2:2008 Paper and board intended to come into contact with foodstuffs - Calibration of the off flavour test - Part 2: Fatty food
CEN/TR 15645-2:2008/AC:2008 Paper and board intended to come into contact with foodstuffs - Calibration of the off-flavour test - Part 2: Fatty food
CEN/TR 15645-3:2008 Paper and board intended to come into contact with foodstuffs - Calibration of the off-flavour test - Part 3: Dry food
CEN/TR 15645-3:2008/AC:2008 Paper and board intended to come into contact with foodstuffs - Calibration of the off-flavour test - Part 3: Dry food
EN ISO 15755:1999 Paper and board - Estimation of contraries (ISO 15755:1999)
EN 15845:2010 Paper and board - Determination of the cytotoxicity of aqueous extracts
EN 16418:2014 Paper and board - Determination of the cytotoxicity of aqueous extracts using a metabolically competent hepatoma cell line (HepG2)
EN 16453:2014 Pulp, paper and paperboard - Determination of phthalates in extracts from paper and paperboard
EN 20187:1993 Paper, board and pulps - Standard atmosphere for conditioning and testing and procedure for monitoring the atmosphere and conditioning of samples (ISO 187:1990)
EN 27213:1993 Pulps - Sampling for testing (ISO 7213:1981)
missing:
links:
or
