Results 1 to 6 of 6
Thread: CEN Standards Collection 324/370: CEN TC 134-Resilient*Textile & Laminate Floor Cover
    full list:
    EN 424:2001 Resilient floor coverings - Determination of the effect of simulated movement of a furniture leg
    EN 425:2002 Resilient and laminate floor coverings - Castor chair test
    EN 432:1994 Resilient floor coverings - Determination of shear force
    EN 650:2012 Resilient floor coverings - Polyvinyl chloride floor coverings on jute backing or on polyester felt backing or on a polyester felt with a polyvinyl chloride backing - Specification
    EN 651:2011 Resilient floor coverings - Polyvinyl chloride floor coverings with foam layer - Specification
    EN 652:2011 Resilient floor coverings - Polyvinyl chloride floor coverings with cork-based backing - Specification
    EN 655:2011 Resilient floor coverings - Tiles of agglomerated composition cork with polyvinyl chloride wear layer - Specification
    EN 660-2:1999 Resilient floor coverings - Determination of wear resistance - Part 2: Frick-Taber test
    EN 660-2:1999/A1:2003 Resilient floor coverings - Determination of wear resistance - Part 2: Frick-Taber test
    EN 661:1994 Resilient floor coverings - Determination of the spreading of water
    EN 662:1994 Resilient floor coverings - Determination of curling exposure to moisture
    EN 663:1994 Resilient floor coverings - Determination of conventional pattern depth
    EN 665:1994 Resilient floor coverings - Determination of exudation of plasticizers
    EN 666:1994 Resilient floor coverings - Determination of gelling
    EN 669:1997 Resilient floor coverings - Determination of dimensional stability of linoleum tiles caused by changes in atmospheric humidity
    EN 672:1996 Resilient floor coverings - Determination of apparent density of agglomerated cork
    EN 684:1995 Resilient floor coverings - Determination of seam strength
    EN 686:2011 Resilient floor coverings - Specification for plain and decorative linoleum on a foam backing
    EN 687:2011 Resilient floor coverings - Specification for plain and decorative linoleum on a corkment backing
    EN 688:2011 Resilient floor coverings - Specification for corklinoleum
    EN 984:2001 Textile floor coverings - Determination of the mass per unit area of the use surface of needled floor coverings
    EN 985:2001 Textile floor coverings - Castor chair test
    EN 986:2005 Textile floor coverings - Tiles - Determination of dimensional changes due to the effects of varied water and heat conditions and distortion out of plane
    EN 994:2012 Textile floor coverings - Determination of the side length, squareness and straightness of tiles
    EN 995:1995 Textile floor coverings - Assessment of the creep of the backings
    EN 1081:1998 Resilient floor coverings - Determination of the electrical resistance
    EN 1269:2015 Textile floor coverings - Assessment of impregnations in needled floor coverings by means of a soiling test
    EN 1307:2014+A1:2016 Textile floor coverings - Classification
    EN 1318:2005 Textile floor coverings - Determination of the apparent effective thickness of the backing
    EN 1318:2005/AC:2007 Textile floor coverings - Determination of the apparent effective thickness of the backing
    EN 1399:1997 Resilient floor coverings - Determination of resistance to stubbed and burning cigarettes
    EN 1399:1997/AC:1998 Resilient floor coverings - Determination of resistance to stubbed and burning cigarettes
    EN 1471:1996 Textile floor coverings - Assessment of changes in appearance
    EN 1471:1996/A1:2003 Textile floor coverings - Assessment of changes in appearance
    EN 1814:2005 Textile floor coverings - Determination of resistance to damage at cut edges using the modified Vettermann drum test
    EN 1815:1997 Resilient and textile floor coverings - Assessment of static electrical propensity
    EN 1816:2010 Resilient floor coverings - Specification for homogeneous and heterogeneous smooth rubber floor coverings with foam backing
    EN 1817:2010 Resilient floor coverings - Specification for homogeneous and heterogeneous smooth rubber floor coverings
    EN ISO 10580:2012 Resilient, textile and laminate floor coverings - Test method for volatile organic compound (VOC) emissions (ISO 10580:2010)
    EN ISO 10581:2013 Resilient floor coverings - Homogeneous poly(vinyl chloride) floor covering - Specifications (ISO 10581:2011)
    EN ISO 10582:2012 Resilient floor coverings - Heterogeneous poly(vinyl chloride) floor coverings - Specification (ISO 10582:2010)
    EN ISO 10595:2012 Resilient floor coverings - Semi-flexible/vinylcomposition (VCT) poly(vinyl chloride) floor tiles - Specification (ISO 10595:2010)
    EN ISO 10595:2012/AC:2012 Resilient floor coverings - Semi-flexible/vinylcomposition (VCT) poly(vinyl chloride) floor tiles - Specification (ISO 10595:2010)
    EN ISO 10874:2012 Resilient, textile and laminate floor coverings - Classification (ISO 10874:2009)
    EN ISO 11378-2:2001 Textile floor coverings - Laboratory soiling tests - Part 2: Drum test (ISO 11378-2:2001)
    EN ISO 11857:2002 Textile floor coverings - Determination of resistance to delamination (ISO 11857:1999)
    EN 12103:1999 Resilient floor coverings - Agglomerated cork underlays - Specification
    EN 12104:2000 Resilient floor coverings - Cork floor tiles - Specification
    EN 12105:1998 Resilient floor coverings - Determination of moisture content of agglomerated composition cork
    EN 12199:2010 Resilient floor coverings - Specifications for homogeneous and heterogeneous relief rubber floor coverings
    EN 12455:1999 Resilient floor coverings - Specification for corkment underlay
    EN 12466:1998 Resilient floor coverings - Vocabulary
    EN ISO 12951:2015 Textile floor coverings - Determination of mass loss, fibre bind and stair nosing appearance change using the Lisson Tretrad machine (ISO 12951:2015)
    EN 13329:2016 Laminate floor coverings - Elements with a surface layer based on aminoplastic thermosetting resins - Specifications, requirements and test methods
    EN 13413:2001 Resilient floor coverings - Polyvinyl chloride floor coverings on a filled fibrous backing - Specification
    EN 13553:2015 Resilient floor coverings - Polyvinyl chloride floor coverings for use in special wet areas - Specification
    EN 13845:2005 Resilient floor coverings - Polyvinyl chloride floor coverings with particle based enhanced slip resistance - Specification
    EN 13893:2002 Resilient, laminate and textile floor coverings - Measurement of dynamic coefficient of friction on dry floor surfaces
    EN 14041:2004 Resilient, textile and laminate floor coverings - Essential characteristics
    EN 14041:2004/AC:2006 Resilient, textile and laminate floor coverings - Essential characteristics
    EN 14085:2010 Resilient floor coverings - Specification for floor panels for loose laying
    EN 14159:2014 Textile floor coverings - Requirements for tolerances on (linear) dimensions of rugs, runners, carpet tiles and wall-to-wall carpet and for tolerances on pattern repeat
    EN 14215:2013 Textile floor coverings - Classification of machine-made pile rugs and runners
    CEN/TS 14472-1:2003 Resilient, textile and laminate floor coverings - Design, preparation and installation - Part 1: General
    CEN/TS 14472-2:2003 Resilient, textile and laminate floor coverings - Design, preparation and installation - Part 2: Textile floor coverings
    CEN/TS 14472-3:2003 Resilient, textile and laminate floor coverings - Design, preparation and installation - Part 3: Laminate floor coverings
    CEN/TS 14472-4:2003 Resilient, textile and laminate floor coverings - Design, preparation and installation - Part 4: Resilient floor coverings
    EN 14499:2015 Textile floor coverings - Minimum requirements for carpet underlays
    EN 14521:2004 Resilient floor coverings - Specification for smooth rubber floor coverings with or without foam backing with a decorative layer
    EN 14565:2004 Resilient floor coverings - Floor coverings based upon synthetic thermoplastic polymers - Specification
    EN 14900:2006 Textile floor coverings - Determination of the density of the textile fleece backing
    EN 14978:2016 Laminate floor coverings - Elements with acrylic based surface layer, electron beam cured - Specifications, requirements and test methods
    EN 15115:2006 Textile floor coverings - Determination of sensitivity to spilled water
    CEN/TS 15398:2016 Resilient, textile and laminate floor coverings - Floor covering standard symbols - Complementary element
    EN 15468:2016 Laminate floor coverings - Elements with directly applied printing and resin surface layer - Specifications, requirements and test methods
    EN 15772:2012 Textile floor coverings - Minimum requirements for needled floor coverings for single usage in events of limited duration
    EN 16094:2012 Laminate floor coverings - Test method for the determination of micro-scratch resistance
    CEN/TS 16354:2013 Laminate floor coverings - Underlays - Specification, requirements and test methods
    EN 16511:2014 Loose-laid panels - Semi-rigid multilayer modular floor covering (MMF) panels with wear resistant top layer
    CEN/TS 16641:2014 Textile floor coverings - Guidelines for acceptable colour deviations
    EN 16776:2016 Resilient floor coverings - Heterogeneous polyurethane floor coverings - Specification
    EN ISO 23996:2012 Resilient floor coverings - Determination of density (ISO 23996:2007)
    EN ISO 23997:2012 Resilient floor coverings - Determination of mass per unit area (ISO 23997:2007)
    EN ISO 23999:2012 Resilient floor coverings - Determination of dimensional stability and curling after exposure to heat (ISO 23999:2008)
    EN ISO 24011:2012 Resilient floor coverings - Specification for plain and decorative linoleum (ISO 24011:2009)
    EN ISO 24340:2012 Resilient floor coverings - Determination of thickness of layers (ISO 24340:2006)
    EN ISO 24341:2012 Resilient and textile floor coverings - Determination of length, width and straightness of sheet (ISO 24341:2006)
    EN ISO 24342:2012 Resilient and textile floor-coverings - Determination of side length, edge, straightness and squareness of tiles (ISO 24342:2007)
    EN ISO 24342:2012/A1:2012 Resilient and textile floor-coverings - Determination of side length, edge straightness and squareness of tiles - Amendment 1 (ISO 24342:2007/Amd 1:2012)
    EN ISO 24343-1:2012 Resilient and laminate floor coverings - Determination of indentation and residual indentation - Part 1: Residual indentation (ISO 24343-1:2007)
    EN ISO 24344:2012 Resilient floor coverings - Determination of flexibility and deflection (ISO 24344:2008)
    EN ISO 24345:2012 Resilient floor coverings - Determination of peel resistance (ISO 24345:2006)
    EN ISO 24346:2012 Resilient floor coverings - Determination of overall thickness (ISO 24346:2006)
    EN ISO 26985:2012 Resilient floor coverings - Identification of linoleum and determination of cement content and ash residue (ISO 26985:2008)
    EN ISO 26986:2012 Resilient floor coverings - Expanded (cushioned) poly(vinyl chloride) floor covering - Specification (ISO 26986:2010)
    EN ISO 26986:2012/AC:2012 Resilient floor coverings - Expanded (cushioned) poly(vinyl chloride) floor covering - Specification (ISO 26986:2010)
    EN ISO 26987:2012 Resilient floor coverings - Determination of staining and resistance to chemicals (ISO 26987:2008)
    missing are:
    or
    Re: CEN Standards Collection 324/340: CEN TC 134-Resilient,Textile & Laminate Floor C
    tc 248
    update:
    EN 1307:2014+A1:2016 Textile floor coverings - Classification - added missing standard
    EN 14978:2016 Laminate floor coverings - Elements with acrylic based surface layer, electron beam cured - Specifications, requirements and test methods - added missing standard
    missing AC:
    new links:
    or
    Re: CEN Standards Collection 324/350: CEN TC 134-Resilient,Textile & Laminate Floor C
    update:
    EN 1399:1997/AC:1998 Resilient floor coverings - Determination of resistance to stubbed and burning cigarettes - added missing AC
    missing:
    EN 1815:2016 Resilient and laminate floor coverings - Assessment of static electrical propensity
    links:
    or
    Re: CEN Standards Collection 324/370: CEN TC 134-Resilient*Textile & Laminate Floor C
    update:
    added missing one:
    this sector complete too
    new link:
    update:
    EN* new* BQ_
    EN ISO 9405:2017 Textile floor coverings - Assessment of changes in appearance (ISO 9405:2015)
    EN 13329:2016 Laminate floor coverings - Elements with a surface layer based on aminoplastic thermosetting resins - Specifications* requirements and test methods
    CEN/TS 15398:2016 Resilient* textile and laminate floor coverings - Floor covering standard symbols - Complementary element
    EN 15468:2016 Laminate floor coverings - Elements with directly applied printing and resin surface layer - Specifications* requirements and test methods
    CEN/TS 16354:2013 Laminate floor coverings - Underlays - Specification* requirements and test methods
    EN 16810:2017 Resilient* textile and laminate floor coverings - Environmental product declarations - Product category rules
    EN ISO 24341:2012 Resilient and textile floor coverings - Determination of length* width and straightness of sheet (ISO 24341:2006)
    EN ISO 24342:2012 Resilient and textile floor-coverings - Determination of side length* edge* straightness and squareness of tiles (ISO 24342:2007)
    EN ISO 24342:2012/A1:2012 Resilient and textile floor-coverings - Determination of side length* edge straightness and squareness of tiles - Amendment 1 (ISO 24342:2007/Amd 1:2012)
    the missing list:
    EN ISO 11378-2:2011/A1:2017 Textile floor coverings - Laboratory soiling tests - Part 2: Drum test - Amendment 1 (ISO 11378-2:2001/Amd 1:2017)
    EN 13553:2017 Resilient floor coverings - Polyvinyl chloride floor coverings for use in special wet areas - Specification
    EN 13845:2017 Resilient floor coverings - Polyvinyl chloride floor coverings with particle based enhanced slip resistance - Specification
  1. Replies: 5
    Last Post: 09-11-2017, 11:18 PM
  2. Replies: 2
    Last Post: 07-29-2017, 03:33 AM
  3. Replies: 6
    Last Post: 07-07-2017, 03:06 AM
  4. Replies: 4
    Last Post: 07-06-2017, 03:47 AM
  5. Replies: 0
    Last Post: 12-31-2016, 04:12 AM
