full list:
EN 678:1993 Determination of the dry density of autoclaved aerated concrete
EN 679:2005 Determination of the compressive strength of autoclaved aerated concrete
EN 680:2005 Determination of the drying shrinkage of autoclaved aerated concrete
EN 989:1995 Determination of the bond behaviour between reinforcing bars and autoclaved aerated concrete by the the "Push-Out" test
EN 990:2002 Test methods for verification of corrosion protection of reinforcement in autoclaved aerated concrete and lightweight aggregate concrete with open structure
EN 991:1995 Determination of the dimension of prefabricated reinforced components made of autoclaved aerated concrete or lightweight aggregate concrete with open structure
EN 992:1995 Determination of the dry density of lightweight aggregate concrete with open structure
EN 1351:1997 Determination of flexural strength of autoclaved aerated concrete
EN 1352:1996 Determination of static modulus of elasticity under compression of autoclaved aerated concrete or lightweight aggregate concrete with open structure
EN 1353:1996 Determination of moisture content of autoclaved aerated concrete
EN 1354:2005 Determination of compressive strength of lightweight aggregate concrete with open structure
EN 1355:1996 Determination of creep strains under compression of autoclaved aerated concrete or lightweight aggregate concrete with open structure
EN 1356:1996 Performance test for prefabricated reinforced components of autoclaved aerated concrete or lightweight aggregate concrete with open structure under transverse load
EN 1520:2011 Prefabricated reinforced components of lightweight aggregate concrete with open structure with structural or non-structural reinforcement
EN 1521:1996 Determination of flexural strength of lightweight aggregate concrete with open structure
EN 1737:1998 Determination of shear strength of welded joints of reinforcement mats or cages for prefabricated components made of autoclaved aerated concrete or lightweight aggregate concrete with open structure
EN 1738:1998 Determination of steel stresses in unloaded reinforced components made of autoclaved aerated concrete
EN 1739:2007 Determination of shear strength for in-plane forces of joints between prefabricated components of autoclaved aerated concrete or lightweight aggregate concrete with open structure
EN 1740:1998 Performance test for prefabricated reinforced components made of autoclaved aerated concrete or lightweight aggregate concrete with open structure under predominantly longitudinal load (vertical components)
EN 1741:1998 Determination of shear strength for out-of-plane forces of joints between prefabricated components made of autoclaved aerated concrete or lightweight aggregate concrete with open structure
EN 1742:1998 Determination of shear strength between different layers of multilayer components made of autoclaved aerated concrete or lightweight aggregate concrete with open structure
EN 12269-1:2000 Determination of the bond behaviour between reinforcing steel and autoclaved aerated concrete by the "beam test" - Part 1: Short term test
EN 12269-2:2010 Determination of the bond behaviour between reinforcing steel and autoclaved aerated concrete by the beam test - Part 2: Long term test
EN 12602:2008+A1:2013 Prefabricated reinforced components of autoclaved aerated concrete
CR 13962:2000 Guidelines for the application of LAC-components in structures
EN 15304:2010 Determination of the freeze-thaw resistance of autoclaved aerated concrete
EN 15361:2007 Determination of the influence of the corrosion protection coating on the anchorage capacity of the transverse anchorage bars in prefabricated reinforced components of autoclaved aerated concrete
missing one:
links:
or
