Results 1 to 11 of 11
Thread: Help- how to calculate the rate of vaporation capacity of lpg ?
    Dear
    I have seek a few documents about calculating the rate of vaporation of LPG, but no more useful answer. It only show the rate of vaporation of propane in various temperature- various volumes. I think it doesnt match to LPG, so anyone have some ideas about this, please help!
    My email: ohman2025.OH@gmail.com ( in case you have more documents, and you can share without boring, please share with me)
    Thanks and Best regard!
    See More: Help- how to calculate the rate of vaporation capacity of lpg ?
    Re: Help- how to calculate the rate of vaporation capacity of lpg ?
    Help!
  5. Re: Help- how to calculate the rate of vaporation capacity of lpg ?
    What operating pressure do you expect?
    What do you want with rate of vaporization of LPG?
    My threads; daniwibowo :
    Quote Originally Posted by daniwibowo View Post
    thanks for your reply.
    LPG's compressed at 5-8 bar, I want to compare among various temperature and caculate the vaporization of LPG in 100lbs cylinder.
    If you have any document about this or you can solve completely, please help me?
  7. Re: Help- how to calculate the rate of vaporation capacity of lpg ?
    Hi...
    I think you able to use hysys:
    1. Use your LPG component
    2. Set pressure 5 barg
    3. Set flow 100 lb/hr
    4. Use case study with pressure 5 bar g and range temperature you want (i.e 20-100 deg C)
    5. You will get vapor fraction of LPG at that pressure.
    6. If you need any other opinions pls let me know.
    If other member have other answer will be good for all of us
    Hi...
    I think hysys only show the result not completly usefull in this case.
    And in this case I want to caculate the capacity of vaporization of LPG in 100lbs cylinder, not for the flow 100lb/hr.
    First we have to find the heat exchange from the environment to the liquid phase through the cylinder. Then according to the three phase and latent heat of LPG we can find the answer. I just seek a liitle bit
    If you have any opinion, we can discuss more about this.
    Thanks so much..
  10. Re: Help- how to calculate the rate of vaporation capacity of lpg ?
    Hi Ohman,
    i saw the same at:
    use hysys for make P-H diargam basis of your LPG composition.
    or use prode if dont have access to hysys
    Ohman,
    yes, you have to estimate heat transfer but for this case you may simply assume a constant value (see Perry or some standard as GPSA for detailed discussion)
    then you solve a P-H flash (or use a diagram as suggested by others)
    solving a P-H flash (where dH is the heat added at each interval) at regular intervals allows to simulate the vaporization vs. time (dynamic),
    you may use your simulator or another tool depending from preferred interface,
    for Excel I recommend this
    Dear daniwibowo
    I have thought about using hysys but it just show the result when you chose a devices. I know about hysys just a little bit. It's my pleasure if you can show me how to to that.
    Thanks so mucn
    Dear carlo
    In hornetly, i want to know how to caculate that.
    May be the problem is not clearly. In this case, i want to caculate the flow of LPG flew out the environment from the cylinder 100lbs by natuaral vaporizing among various volumes. Can you discuss more this with us?
    Thanks so much
  14. #11
    given composition and initial conditions (P,T)
    1) solve a isothermal flash (P.T) to verify initial phase fractions and compositions
    2) start dynamic simulation in n time steps
    3) estimate heat transfer for liquid phase and calculate dH heat absorbed in time step (dW*area*time step)
    3) solve a P-H flash (in some cases, as alternative. you can solve a V-H flash, see 'http://prodesoftwareapplications.blogspot.de/2013/05/how-to-calculate-fluid-conditions.html' )
    4) extract vaporized fluid and redefine compoaitions
    5) repeat step 3
    I solve these problems in Excel with Prode Properties, see
    'http://www.egpet.net/vb/threads/27092-Excel-library-for-process-calc-s-including-distillation'
    but you can apply the same methodolgy with a different software
  1. How to calculate Anulus bleed leakage rate
    By raj67 in forum Oil And Gas Process
    Last Post: 03-10-2014, 07:50 PM
  2. calculate rate of drainage
    By arjal in forum Mechanical Engineering
    Last Post: 05-30-2013, 07:39 PM
  3. How to calculate the hook load capacity?
    By wjw_1980 in forum Drilling And Workover
    Last Post: 01-30-2013, 03:37 PM
  4. Replies: 1
    Last Post: 07-15-2010, 05:47 PM
