Thread: Crude oil/water mixture
  1. Crude oil/water mixture
    Hello all,
    I am trying to calculate the inside heat transfer coefficient for a 4 in diameter pipe transporting an crude oil/water mixture.
    The crude oil is API 20° and two mixtures are to be analyzed, one for a 50% water cut and the other for a 70% water cut.
    I don't know how to determine the viscosity and thermal properties of the mixture.
    Please help. Thanks!
    Re: Crude oil/water mixture
    Calculating emulsions physical/transport properties is not a straight forward subject. I advise you to use Hysys or Pro II.
  5. Re: Crude oil/water mixture
    Quote Originally Posted by mobek View Post
    Yes, i think using hysys will be good.
    you need data such as API and distillation of the crude.
    Use Oil manager for oil properties.
    Try to simulate using mixer to mix between oil and water.
    Thx
    Dani
  6. Re: Crude oil/water mixture
    I think what you're going to do is give him tips by reading what he's already read about
  1. Calculate composition of gas mixture
    By partiapressure in forum Laboratory Measurements
    Last Post: 03-02-2014, 07:11 AM
  2. Composition of mixture
    By chaker05 in forum Oil And Gas Process
    Last Post: 12-25-2012, 02:27 PM
  3. ASTM Standard Test Methods for Water in Crude Oil industry
    By ameer in forum Laboratory Measurements
    Last Post: 09-12-2011, 11:19 AM
  4. water and salt content in a crude oil
    By ali in forum Oil And Gas Process
    Last Post: 09-10-2008, 01:09 AM
