Page 1 of 2 1 2 LastLast
Results 1 to 12 of 15
Thread: need serial number for SPI 2013
  1. need serial number for SPI 2013
    Hi friends,
    I need the serial number for Smartplant instrumentation 2013. please ,if any one have this serial, share it. I need it urgently
    waitnig for your positive answer mate.
    regards
  3. Re: need serial number for SPI 2013
    Please respond
    Quote Originally Posted by z_sofiene View Post
    Hi friends,
    regards
    i hope it is use full to you.
    Hi mrbeen,
    Did you download the software from the Lavteam website and were able to install & activate the software? I'd imagine you didn't. This is because that download does not really contain all the necessary files (such as SN); go there and read for yourself what is written.
    Best wishes,
    Quote Originally Posted by mrbeen View Post
  7. Re: need serial number for SPI 2013
    friend , till now I didn't find the serial number for installation of SPI2013, this is the one thing missing, could you please advice and help us ???
    I need it for my end of studies project, Please i need your help
  9. Re: need serial number for SPI 2013
    [link Point to another website Only the registered members can access] Hi all , this the serial which I'am talking about.
    Please helps friend.
    waiting for positive answer
    Have you tried LAVTEAM downloads?
    In it, it says Install apps with the serials:
    a) SPI: 00098601401160
    b) DDP Export Utility: 99999970401194
    I installed SPI2013 successfully. But the "instrument index - Table" doesn't work, only very few items are available.
    I have no idea of resolving this issue.
  11. Re: need serial number for SPI 2013
    Quote Originally Posted by yilizhang View Post
    In it* it says Install apps with the serials:
    I installed SPI2013 successfully. But the "instrument index - Table" doesn't work* only very few items are available.
    Could you please guide me on how to install and configure a compatible oracle version for smartplant instrumentation 2013
    Thank you
    Logon on the Administration module using using your Domain password. open the domain, click on the access rights, open the 'Instrumentation' Group that you created earlier, click on Domain level and change the access for Instr. Index Supporting Tables to "Modify(Add/Update)". Click save and click close. Log on to SPI as a user and open instrument index, go to the menu and click Tables, Hola, all the items will be active. enjoy
  13. Re: need serial number for SPI 2013
    how to access process and calculation module in smart plant instrumentation 2013
    Read more:
  14. Re: need serial number for SPI 2013
    Please help me
  16. #12
    I am looking for trial or full version of this unique software.
    Those who are in PV design field since 2005 might have seen this software. The software developer stopped its production after 2010. Anybody who have full or trial version of this software please share.
    This was the best PV software in my view.
    Please check out your old data , your old pc, your old hard drives or old softwares of 2007 to 2009 and if you find it please contact me.
    This is the same case of trial version of codeware compress which was available in 2007 -2008 but not available now.
  1. AFT Impulse 4.0 Serial Number?
    By neocracker in forum Pipeline And Fluid Flow
    Last Post: 05-17-2014, 08:54 AM
