full list:
EN ISO 542:1995 Oilseeds - Sampling (ISO 542:1990)
EN ISO 658:2002 Oilseeds - Determination of content of impurities (ISO 658:2002)
EN ISO 660:2009 Animal and vegetable fats and oils - Determination of acid value and acidity (ISO 660:2009)
EN ISO 661:2005 Animal and vegetable fats and oils - Preparation of test sample (ISO 661:2003)
EN ISO 661:2005/AC:2006 Animal and vegetable fats and oils - Preparation of test sample (ISO 661:2003)
EN ISO 662:2016 Animal and vegetable fats and oils - Determination of moisture and volatile matter content (ISO 662:2016)
EN ISO 663:2008 Animal and vegetable fats and oils - Determination of insoluble impurities content (ISO 663:2007)
EN ISO 664:2008 Oilseeds - Reduction of laboratory sample to test sample (ISO 664:2008)
EN ISO 665:2000 Oilseeds - Determination of moisture and volatile matter content (ISO 665:2000)
EN ISO 659:2009 Oilseeds - Determination of oil content (Reference method) (ISO 659:2009)
EN ISO 734:2015 Oilseed meals - Determination of oil content - Extraction method with hexane (or light petroleum) (ISO 734:2015)
EN ISO 3596:2001 Animal and vegetable fats and oils - Determination of unsaponifiable matter - Method using diethyl ether extraction
EN ISO 3656:2011 Animal and vegetable fats and oils - Determination of ultraviolet absorbance expressed as specific UV extinction (ISO 3656:2011)
EN ISO 3657:2013 Animal and vegetable fats and oils - Determination of saponification value (ISO 3657:2013)
EN ISO 3960:2010 Animal and vegetable fats and oils - Determination of peroxide value - Iodometric (visual) endpoint determination (ISO 3960:2007, corrected version 2009-05-15)
EN ISO 3961:2013 Animal and vegetable fats and oils - Determination of iodine value (ISO 3961:2013)
EN ISO 5511:1996 Oilseeds - Determination of oil content - Method using continuous-wave low-resolution nuclear magnetic resonance spectrometry (Rapid method) (ISO 5511:1992)
EN ISO 5511:1996/AC:1997 Oilseeds - Determination of oil content - Method using continuous-wave low-resolution nuclear magnetic resonance spectrometry (Rapid method)
EN ISO 5555:2001 Animal and vegetable fats and oils - Sampling (ISO 5555:2001)
EN ISO 5555:2001/A1:2014 Animal and vegetable fats and oils - Sampling - Amendment 1: Flexitanks (ISO 5555:2001/Amd 1:2014)
EN ISO 6320:2000 Animal and vegetable fats and oils - Determination of refractive index (ISO 6320:2000)
EN ISO 6320:2000/AC:2006 Animal and vegetable fats and oils - Determination of refractive index (ISO 6320:2000/Cor.1:2006)
EN ISO 6321:2002 Animal and vegetable fats and oils - Determination of melting point in open capillary tubes (slip point) (ISO 6321:2002)
EN ISO 6800:1997 Animal and vegetable fats and oils - Determination of the composition of fatty acids in the 2-position of the triglycerides molecules (ISO 6800:1997)
EN ISO 6883:2014 Animal and vegetable fats and oils - Determination of conventional mass per volume (litre weight in air) (ISO 6883:2007)
EN ISO 6885:2016 Animal and vegetable fats and oils - Determination of anisidine value (ISO 6885:2016)
EN ISO 6886:2016 Animal and vegetable fats and oils - Determination of oxidative stability (accelerated oxidation test) (ISO 6886:2016)
EN ISO 8292-1:2010 Animal and vegetable fats and oils - Determination of solid fat content by pulsed NMR - Part 1: Direct method (ISO 8292-1:2008)
EN ISO 8292-2:2010 Animal and vegetable fats and oils - Determination of solid fat content by pulsed NMR - Part 2: Indirect method (ISO 8292-2:2008)
EN ISO 8294:1999 Animal and vegatable fats and oils - Determination of copper, iron and nickel contents - Graphite furnace atomic absorption method (ISO 8294:1994)
EN ISO 8420:2002 Animal and vegetable fats and oils - Determination of content of polar compounds (ISO 8420:2002)
EN ISO 8420:2002/AC:2008 Animal and vegetable fats and oils - Determination of content of polar compounds (ISO 8420:2002/Cor 1:2004)
EN ISO 8534:2008 Animal and vegetable fats and oils - Determination of water content - Karl Fischer method (pyridine free) (ISO 8534:2008)
EN ISO 8892:1995 Oilseed residues - Determination of total residual hexane (ISO 8892:1987)
EN ISO 9167-1:1995 Rapeseed - Determination of glucosinolates content - Part 1: Method using high-performance liquid chromatography (ISO 9167-1:1992)
EN ISO 9167-1:1995/A1:2013 Rapeseed - Determination of glucosinolates content - Part 1: Method using high-performance liquid chromatography - Amendment 1 (ISO 9167-1:1992/Amd 1:2013)
EN ISO 9289:1995 Oilseed residues - Determination of free residual hexane (ISO 9289:1991)
EN ISO 9832:2003 Animal and vegetable fats and oils - Determination of residual technical hexane content (ISO 9832:2002)
EN ISO 9936:2016 Animal and vegetable fats and oils - Determination of tocopherol and tocotrienol contents by high-performance liquid chromatography (ISO 9936:2016)
EN ISO 10519:2015 Rapeseed - Determination of chlorophyll content - Spectrometric method (ISO 10519:2015)
EN ISO 10539:2002 Animal and vegetable fats and oils - Determination of alkalinity (ISO 10539:2002)
EN ISO 10565:1998 Oilseeds - Simultaneous determination of oil and water contents - Method using pulsed nuclear magnetic resonance spectrometry (ISO 10565:1998)
EN ISO 11701:2009 Vegetable fats and oils - Determination of phospholipids content in lecithins by HPLC using a light-scattering detector (ISO 11701:2009)
EN ISO 11702:2009 Animal and vegetable fats and oils - Enzymatic determination of total sterols content (ISO 11702:2009)
EN ISO 12193:2004 Animal and vegetable fats and oils - Determination of lead by direct graphite furnace atomic absorption spectroscopy (ISO 12193:2004)
EN ISO 12228-1:2014 Determination of individual and total sterols contents - Gas chromatographic method - Part 1: Animal and vegetable fats and oils (ISO 12228-1:2014)
EN ISO 12228-2:2014 Determination of individual and total sterols contents - Gas chromatographic method - Part 2: Olive and olive pomace oils (ISO 12228-2:2014)
EN ISO 12872:2014 Olive oils and olive-pomace oils - Determination of the 2-glyceryl monopalmitate content (ISO 12872:2010)
EN ISO 12873:2014 Olive oils and olive-pomace oils - Determination of wax content by capillary gas chromatography (ISO 12873:2010)
EN ISO 12966-1:2014 Animal and vegetable fats and oils - Gas chromatography of fatty acid methyl esters - Part 1: Guidelines on modern gas chromatography of fatty acid methyl esters (ISO 12966-1:2014)
EN ISO 12966-1:2014/AC:2015 Animal and vegetable fats and oils - Gas chromatography of fatty acid methyl esters - Part 1: Guidelines on modern gas chromatography of fatty acid methyl esters (ISO 12966-1:2014)
EN ISO 12966-2:2011 Animal and vegetable fats and oils - Gas chromatography of fatty acid methyl esters - Part 2: Preparation of methyl esters of fatty acids (ISO 12966-2:2011)
EN ISO 12966-3:2009 Animal and vegetable fats and oils - Gas chromatography of fatty acid methyl esters - Part 3: Preparation of methyl esters using trimethylsulfonium hydroxide (TMSH) (ISO 12966-3:2009)
EN ISO 12966-4:2015 Animal and vegetable fats and oils - Gas chromatography of fatty acid methyl esters - Part 4: Determination by capillary gas chromatography (ISO 12966-4:2015)
EN ISO 13884:2005 Animal and vegetable fats and oils - Determination of isolated trans isomers by infrared spectrometry (ISO 13884:2003)
EN 14103:2011 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of ester and linolenic acid methyl ester contents
EN 14104:2003 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of acid value
EN 14105:2011 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of free and total glycerol and mono-, di-, triglyceride contents
EN 14106:2003 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of free glycerol content
EN 14107:2003 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of phosphorus content by inductively coupled plasma (ICP) emission spectrometry
EN 14108:2003 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of sodium content by atomic absorption spectrometry
EN 14109:2003 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of potassium content by atomic absorption spectrometry
EN 14110:2003 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of methanol content
EN 14111:2003 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of iodine value
EN 14112:2003 Fat and oil derivatives - Fatty Acid Methyl Esters (FAME) - Determination of oxidation stability (accelerated oxidation test)
EN ISO 15301:2001 Animal and vegetable fats and oils - Determination of sediment in crude fats and oils - Centrifuge method (ISO 15301:2001)
EN ISO 15301:2001/AC:2007 Animal and vegetable fats and oils - Determination of sediment in crude fats and oils - Centrifuge method (ISO 15301:2001/Cor 1:2007)
EN ISO 15302:2010 Animal and vegetable fats and oils - Determination of benzo[a]pyrene - Reverse-phase high performance liquid chromatography method (ISO 15302:2007)
EN ISO 15303:2008 Animal and vegetable fats and oils - Detection and identification of a volatile organic contaminant by GC/MS (ISO 15303:2001)
EN ISO 15753:2016 Animal and vegetable fats and oils - Determination of polycyclic aromatic hydrocarbons (ISO 15753:2016)
EN ISO 15774:2001 Animal and vegetable fats and oils - Determination of cadmium content by direct graphite furnace atomic absorption spectrometry (ISO 15774:2000)
EN ISO 15788-1:2001 Animal and vegetable fats and oils - Determination of stigmastadienes in vegetable oils - Part 1: Method using capillary-column gas chromatography (Reference method) (ISO 15788-1:1999)
EN ISO 15788-2:2004 Animal and vegetable fats and oils - Determination of stigmastadienes in vegetable oils - Part 2: Method using high-performance liquid chromatography (HPLC) (ISO 15788-2:2003)
EN ISO 16035:2005 Animal and vegetable fats and oils - Determination of low-boiling halogenated hydrocarbons in edible oils (ISO 16035:2003)
EN ISO 16931:2009 Animal and vegetable fats and oils - Determination of polymerized triacylglycerols by high-performance size-exclusion chromatography (HPSEC) (ISO 16931:2009)
EN ISO 17059:2009 Oilseeds - Extraction of oil and preparation of methyl esters of triglyceride fatty acids for analysis by gas chromatography (Rapid method) (ISO 17059:2007)
EN ISO 17932:2011 Palm oil - Determination of the deterioration of bleachability index (DOBI) and carotene content (ISO 17932:2011)
EN ISO 18395:2007 Animal and vegetable fats and oils - Determination of monoacylglycerols, diacylglycerols, triacylglycerols and glycerol by high-performance size-exclusion chromatography (HPSEC) (ISO 18395:2005)
EN ISO 18609:2001 Animal and vegetable fats and oils - Determination of unsaponifiable matter - Method using hexane extraction
EN ISO 19219:2003 Animal and vegetable fats and oils - Determination of visible foots in crude fats and oils (ISO 19219:2002)
EN ISO 22630:2015 Oilseed meals - Determination of oil content - Rapid extraction method (ISO 22630:2015)
EN ISO 22959:2009 Animal and vegetable fats and oils - Determination of polycyclic aromatic hydrocarbons by on-line donor-acceptor complex chromatography and HPLC with fluorescence detection (ISO 22959:2009)
EN ISO 23275-1:2008 Animal and vegetable fats and oils - Cocoa butter equivalents in cocoa butter and plain chocolate - Part 1: Determination of the presence of cocoa butter equivalents (ISO 23275-1:2006)
EN ISO 23275-2:2008 Animal and vegetable fats and oils - Cocoa butter equivalents in cocoa butter and plain chocolate - Part 2: Quantification of cocoa butter equivalents (ISO 23275-2:2006)
EN ISO 27107:2010 Animal and vegetable fats and oils - Determination of peroxide value - Potentiometric end-point determination (ISO 27107:2008, corrected version 2009-05-15 )
EN ISO 29822:2014 Vegetable fats and oils - Isomeric diacylglycerols - Determination of relative amounts of 1,2- and 1,3-diacylglycerols (ISO 29822:2009)
EN ISO 29841:2014 Vegetable fats and oils - Determination of the degradation products of chlorophylls a and a' (pheophytins a, a' and pyropheophytins) (ISO 29841:2009)
EN ISO 29841:2014/A1:2016 Vegetable fats and oils - Determination of the degradation products of chlorophylls a and a' (pheophytins a, a' and pyropheophytins) (ISO 29841:2009/AMD 1:2016)
missing:
or
