Results 1 to 5 of 5
Thread: CEN Standards Collection 264/370: CEN TC 321-Explosives For Civil Uses
    complete
    EN 13630-1:2003 Explosives for civil uses - Detonating cords and safety fuses - Part 1: Requirements
    EN 13630-2:2002 Explosives for civil uses - Detonating cords and safety fuses - Part 2: Determination of thermal stability of detonating cords and safety fuses
    EN 13630-3:2002 Explosives for civil uses - Detonating cords and safety fuses - Part 3: Determination of sensitiveness to friction of the core of detonating cords
    EN 13630-4:2002 Explosives for civil uses - Detonating cords and safety fuses - Part 4: Determination of sensitiveness to impact of detonating cords
    EN 13630-5:2003 Explosives for civil uses - Detonating cords and safety fuses - Part 5: Determination of resistance to abrasion of detonating cords
    EN 13630-6:2002 Explosives for civil uses - Detonating cords and safety fuses - Part 6: Determination of resistance to tension of detonating cords
    EN 13630-7:2002 Explosives for civil uses - Detonating cords and safety fuses - Part 7: Determination of reliability of initiation of detonating cords
    EN 13630-8:2002 Explosives for civil uses - Detonating cords and safety fuses - Part 8: Determination of resistance to water of detonating cords and safety fuses
    EN 13630-9:2004 Explosives for civil uses - Detonating cords and safety fuses - Part 9: Determination of transmission of detonation from detonating cord to detonating cord
    EN 13630-10:2005 Explosives for civil uses - Detonating cords and safety fuses - Part 10: Determination of initiating capability of detonating cords
    EN 13630-11:2002 Explosives for civil uses - Detonating cords and safety fuses - Part 11: Determination of velocity of detonation of detonating cords
    EN 13630-12:2002 Explosives for civil uses - Detonating cords and safety fuses - Part 12: Determination of burning duration of safety fuses
    EN 13631-1:2005 Explosives for civil uses - High explosives - Part 1: Requirements
    EN 13631-2:2002 Explosives for civil uses - High explosives - Part 2: Determination of thermal stability of explosives
    EN 13631-3:2004 Explosives for civil uses - High explosives - Part 3: Determination of sensitiveness to friction of explosives
    EN 13631-4:2002 Explosives for civil uses - High explosives - Part 4: Determination of sensitiveness to impact of explosives
    EN 13631-5:2002 Explosives for civil uses - High explosives - Part 5: Determination of resistance to water
    EN 13631-6:2002 Explosives for civil uses - High explosives - Part 6: Determination of resistance to hydrostatic pressure
    EN 13631-7:2003 Explosives for civil uses - High explosives - Part 7: Determination of safety and reliability at extreme temperatures
    EN 13631-10:2003 Explosives for civil uses - High explosives - Part 10: Method for the verification of the means of initiation
    EN 13631-11:2003 Explosives for civil uses - High explosives - Part 11: Determination of transmission of detonation
    EN 13631-12:2004 Explosives for civil uses - High explosives - Part 12: Specifications of boosters with different initiating capability
    EN 13631-13:2003 Explosives for civil uses - High explosives - Part 13: Determination of density
    EN 13631-14:2003 Explosives for civil uses - High explosives - Part 14: Determination of velocity of detonation
    EN 13631-15:2005 Explosives for civil uses - High explosives - Part 15: Calculation of thermodynamic properties
    EN 13631-16:2004 Explosives for civil uses - High explosives - Part 16: Detection and measurement of toxic gases
    EN 13763-1:2004 Explosives for civil uses - Detonators and relays - Part 1: Requirements
    EN 13763-2:2002 Explosives for civil uses - Detonators and relays - Part 2: Determination of thermal stability
    EN 13763-3:2002 Explosives for civil uses - Detonators and relays - Part 3: Determination of sensitiveness to impact
    EN 13763-4:2003 Explosives for civil uses - Detonators and relays - Part 4: Determination of resistance to abrasion of leading wires and shock tubes
    EN 13763-5:2003 Explosives for civil uses - Detonators and relays - Part 5: Determination of resistance to cutting damage of leading wires and shock tubes
    EN 13763-6:2003 Explosives for civil uses - Detonators and relays - Part 6: Determination of resistance to *****ing in low temperatures of leading wires
    EN 13763-7:2003 Explosives for civil uses - Detonators and relays - Part 7: Determination of the mechanical strength of leading wires, shock tubes, connections, crimps and closures
    EN 13763-8:2003 Explosives for civil uses - Detonators and relays - Part 8: Determination of the resistance to vibration of plain detonators
    EN 13763-9:2003 Explosives for civil uses - Detonators and relays - Part 9: Determination of resistance to bending of detonators
    EN 13763-11:2003 Explosives for civil uses - Detonators and relays - Part 11: Determination of resistance to damage by dropping of detonators and relays
    EN 13763-12:2003 Explosives for civil uses - Detonators and relays - Part 12etermination of resistance to hydrostatic pressure
    EN 13763-13:2004 Explosives for civil uses - Detonators and relays - Part 13: Determination of resistance of electric detonators to electrostatic discharge
    EN 13763-15:2004 Explosives for civil uses - Detonators and relays - Part 15: Determination of equivalent initiating capability
    EN 13763-16:2003 Explosives for civil uses - Detonators and relays - Part 16: Determination of delay accuracy
    EN 13763-17:2003 Explosives for civil uses - Detonators and relays - Part 17: Determination of no-fire current of electric detonators
    EN 13763-18:2003 Explosives for civil uses - Detonators and relays - Part 18: Determination of series firing current of electric detonators
    EN 13763-19:2003 Explosives for civil uses - Detonators and relays - Part 19: Determination of firing impulse of electric detonators
    EN 13763-20:2003 Explosives for civil uses - Detonators and relays - Part 20: Determination of total electrical resistance of electric detonators
    EN 13763-21:2003 Explosives for civil uses - Detonators and relays - Part 21: Determination of flash-over voltage of electric detonators
    EN 13763-22:2003 Explosives for civil uses - Detonators and relays - Part 22: Determination of capacitance, insulation resistance and insulation breakdown of leading wires
    EN 13763-23:2002 Explosives for civil uses - Detonators and relays - Part 23: Determination of the shock-wave velocity of shock tube
    EN 13763-24:2002 Explosives for civil uses - Detonators and relays - Part 24: Determination of the electrical non-conductivity of shock tube
    EN 13763-25:2004 Explosives for civil uses - Detonators and relays - Part 25: Determination of transfer capability of surface connectors, relays and coupling accessories
    EN 13763-26:2004 Explosives for civil uses - Detonators and relays - Part 26: Definitions, methods, and requirements for devices and accessories for reliable and safe function of detonators and relays
    CEN/TS 13763-27:2003 Explosives for civil uses - Detonators and relays - Part 27: Definitions, methods and requirements for electronic initiation systems
    EN 13857-1:2003 Explosives for civil uses - Part 1: Terminology
    EN 13857-3:2002 Explosives for civil uses - Part 3: Information to be provided by the manufacturer or his authorised representative to the user
    EN 13938-1:2004 Explosives for civil uses - Propellants and rocket propellants - Part 1: Requirements
    EN 13938-1:2004/AC:2006 Explosives for civil uses - Propellants and rocket propellants - Part 1: Requirements
    EN 13938-2:2004 Explosives for civil uses - Propellants and rocket propellants - Part 2: Determination of resistance to electrostatic energy
    EN 13938-3:2003 Explosives for civil uses - Propellants and rocket propellants - Part 3: Determination of deflagration to detonation transition
    EN 13938-4:2003 Explosives for civil uses - Propellants and rocket propellants - Part 4: Determination of burning rate under ambient conditions
    EN 13938-5:2004 Explosives for civil uses - Propellants and rocket propellants - Part 5: Determination of voids and fissures
    EN 13938-6:2004 Explosives for civil uses - Propellants and rocket propellants - Part 6: Solid rocket propellants - Guide for the determination of integrity of inhibitor coatings
    EN 13938-7:2004 Explosives for civil uses - Propellants and rocket propellants - Part 7: Determination of properties of black powder
    Re: CEN Standards Collection 264/300: CEN TC 321-Explosives For Civil Uses
    nothing changed, fresh links:
    or
    Re: CEN Standards Collection 264/340: CEN TC 321-Explosives For Civil Uses
    everything still here, new links:
    or
    Re: CEN Standards Collection 264/350: CEN TC 321-Explosives For Civil Uses
    everything the same:
    or
    Re: CEN Standards Collection 264/370: CEN TC 321-Explosives For Civil Uses
    no changes here
  1. Civil Engineering Book Collection
    By Gard in forum Civil & Structural Engineering
    Last Post: 01-11-2018, 07:12 AM
  2. CEN Standards Collection 163/370: CEN SS C20-Explosives & Firework
    Last Post: 05-30-2017, 12:50 AM
  3. Replies: 0
    Last Post: 12-31-2016, 04:12 AM
  4. AS/NZS Standards: for Civil & Structural
    By Mr Welder in forum Civil & Structural Engineering
    Last Post: 01-27-2016, 10:44 AM
  5. many civil books and standards
    By vikaschaurasia in forum Civil & Structural Engineering
    Last Post: 10-10-2013, 09:37 PM
