full list:
EN ISO 1:2002 Geometrical Product Specifications (GPS) - Standard reference temperature for geometrical product specification and verification (ISO 1:2002)
EN ISO 286-1:2010 Geometrical product specifications (GPS) - ISO code system for tolerances on linear sizes - Part 1: Basis of tolerances, deviations and fits (ISO 286-1:2010)
EN ISO 286-1:2010/AC:2013 Geometrical product specifications (GPS) - ISO code system for tolerances on linear sizes - Part 1: Basis of tolerances, deviations and fits - Technical Corrigendum 1 (ISO 286-1:2010/Cor 1:2013)
EN ISO 286-2:2010 Geometrical product specifications (GPS) - ISO code system for tolerances on linear sizes - Part 2: Tables of standard tolerance classes and limit deviations for holes and shafts (ISO 286-2:2010)
EN ISO 286-2:2010/AC:2013 Geometrical product specifications (GPS) - ISO code system for tolerances on linear sizes - Part 2: Tables of standard tolerance classes and limit deviations for holes and shafts - Technical Corrigendum 1 (ISO 286-2:2010/Cor 1:2013)
EN ISO 463:2006 Geometrical Product Specifications (GPS) - Dimensional measuring equipment - Design and metrological characteristics of mechanical dial gauges (ISO 463:2006)
EN ISO 463:2006/AC:2009 Geometrical Product Specifications (GPS) - Dimensional measuring equipment - Design and metrological characteristics of mechanical dial gauges (ISO 463:2006/Cor 1:2007/Cor 2:2009)
EN ISO 1101:2013 Geometrical product specifications (GPS) - Geometrical tolerancing - Tolerances of form, orientation, location and run-out (ISO 1101:2012, including Cor 1:2013)
EN ISO 1119:2011 Geometrical product specifications (GPS) - Series of conical tapers and taper angles (ISO 1119:2011)
EN ISO 1302:2002 Geometrical Product Specifications (GPS) - Indication of surface texture in technical product documentation (ISO 1302:2002)
EN ISO 1660:1995 Technical drawings - Dimensioning and tolerancing of profiles (ISO 1660:1987)
EN ISO 1938-1:2015 Geometrical product specifications (GPS) - Dimensional measuring equipment - Part 1: Plain limit gauges of linear size (ISO 1938-1:2015)
EN ISO 2538-1:2014 Geometrical product specifications (GPS) - Wedges - Part 1: Series of angles and slopes (ISO 2538-1:2014)
EN ISO 2538-2:2014 Geometrical product specifications (GPS) - Wedges - Part 2: Dimensioning and tolerancing (ISO 2538-2:2014)
EN ISO 2692:2014 Geometrical product specifications (GPS) - Geometrical tolerancing - Maximum material requirement (MMR), least material requirement (LMR) and reciprocity requirement (RPR) (ISO 2692:2014)
EN ISO 3040:2012 Geometrical product specifications (GPS) - Dimensioning and tolerancing - Cones (ISO 3040:2009)
EN ISO 3274:1997 Geometrical product specifications (GPS) - Surface texture: Profile method - Nominal characteristics of contact (stylus) instruments (ISO 3274:1996)
EN ISO 3611:2010 Geometrical product specifications (GPS) - Dimensional measuring equipment: Micrometers for external measurements - Design and metrological characteristics (ISO 3611:2010)
EN ISO 3650:1998 Geometrical product specifications (GPS) - Length standards - Gauge blocks (ISO 3650:1998)
EN ISO 3650:1998/AC:2009 Geometrical product specifications (GPS) - Length standards - Gauge blocks (ISO 3650:1998/Cor 1:2008)
EN ISO 4287:1998 Geometrical product specifications (GPS) - Surface texture: Profile method - Terms, definitions and surface texture parameters (ISO 4287:1997)
EN ISO 4287:1998/AC:2008 Geometrical product specifications (GPS) - Surface texture: Profile method - Terms, definitions and surface texture parameters (ISO 4287:1997/Cor 1:1998/Cor 2:2005)
EN ISO 4287:1998/A1:2009 Geometrical Product Specifications (GPS) - Surface texture: Profile method - Terms, definitions and surface texture parameters - Amendment 1: Peak count number (ISO 4287:1997/Amd 1:2009)
EN ISO 4288:1997 Geometrical product specifications (GPS) - Surface texture: Profile method - Rules and procedures for the assessment of surface texture (ISO 4288:1996)
EN ISO 5436-1:2000 Geometrical Product Specifications (GPS) - Surface texture: Profile method; Measurement standards - Part 1: Material measures (ISO 5436-1:2000)
EN ISO 5436-2:2012 Geometrical product specifications (GPS) - Surface texture: Profile method; Measurement standards - Part 2: Software measurement standards (ISO 5436-2:2012)
EN ISO 5458:1998 Geometrical product specifications (GPS) - Geometrical tolerancing - Positional tolerancing (ISO 5458:1998)
EN ISO 5459:2011 Geometrical product specifications (GPS) - Geometrical tolerancing - Datums and datum systems (ISO 5459:2011)
EN ISO 8015:2011 Geometrical product specifications (GPS) - Fundamentals - Concepts, principles and rules (ISO 8015:2011)
EN ISO 8785:1999 Geometrical product specification (GPS) - Surface imperfections - Terms, definitions and parameters (ISO 8785:1998)
EN ISO 9493:2010 Geometrical product specifications (GPS) - Dimensional measuring equipment: Dial test indicators (lever type) - Design and metrological characteristics (ISO 9493:2010)
EN ISO 10360-1:2000 Geometrical Product Specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 1: Vocabulary (ISO 10360-1:2000)
EN ISO 10360-1:2000/AC:2002 Geometrical Product Specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 1: Vocabulary (ISO 10360-1:2000/Cor.1:2002)
EN ISO 10360-2:2009 Geometrical product specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 2: CMMs used for measuring linear dimensions (ISO 10360-2:2009)
EN ISO 10360-3:2000 Geometrical Product Specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 3: CMMs with the axis of a rotary table as the forth axis (ISO 10360-3:2000)
EN ISO 10360-4:2000 Geometrical Product Specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 4: CMMs used in scanning measuring mode (ISO 10360-4:2000)
EN ISO 10360-4:2000/AC:2002 Geometrical Product Specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 4: CMMs used in scanning measuring mode (ISO 10360-4:2000/Cor.1:2002)
EN ISO 10360-5:2010 Geometrical product specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 5: CMMs using single and multiple stylus contacting probing systems (ISO 10360-5:2010)
EN ISO 10360-6:2001 Geometrical Product Specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 6: Estimation of errors in computing Gaussian associated features (ISO 10360-6:2001)
EN ISO 10360-6:2001/AC:2008 Geometrical Product Specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 6: Estimation of errors in computing Gaussian associated features (ISO 10360-6:2001/Cor 1:2007)
EN ISO 10360-7:2011 Geometrical product specifications (GPS) - Acceptance and reverification tests for coordinate measuring machines (CMM) - Part 7: CMMs equipped with imaging probing systems (ISO 10360-7:2011)
EN ISO 10360-8:2013 Geometrical product specifications (GPS) - Acceptance and reverification tests for coordinate measuring systems (CMS) - Part 8: CMMs with optical distance sensors (ISO 10360-8:2013)
EN ISO 10360-9:2013 Geometrical product specifications (GPS) - Acceptance and reverification tests for coordinate measuring systems (CMS) - Part 9: CMMs with multiple probing systems (ISO 10360-9:2013)
EN ISO 10579:2013 Geometrical product specifications (GPS) - Dimensioning and tolerancing - Non-rigid parts (ISO 10579:2010 including Cor 1:2011)
EN ISO 12085:1997 Geometrical product specification (GPS) - Surface texture: Profile method - Motif parameters (ISO 12085:1996)
EN ISO 12085:1997/AC:2008 Geometrical product specification (GPS) - Surface texture: Profile method - Motif parameters (ISO 12085:1996/Cor 1:1998)
EN ISO 12179:2000 Geometrical Product Specifications (GPS) - Surface texture: Profile method - Calibration of contact (stylus) instruments (ISO 12179:2000)
EN ISO 12179:2000/AC:2008 Geometrical Product Specifications (GPS) - Surface texture: Profile method - Calibration of contact (stylus) instruments (ISO 12179:2000/Cor 1:2003)
EN ISO 12180-1:2011 Geometrical product specifications (GPS) - Cylindricity - Part 1: Vocabulary and parameters of cylindrical form (ISO 12180-1:2011)
EN ISO 12180-2:2011 Geometrical product specifications (GPS) - Cylindricity - Part 2: Specification operators (ISO 12180-2:2011)
EN ISO 12181-1:2011 Geometrical product specifications (GPS) - Roundness - Part 1: Vocabulary and parameters of roundness (ISO 12181-1:2011)
EN ISO 12181-2:2011 Geometrical product specifications (GPS) - Roundness - Part 2: Specification operators (ISO 12181-2:2011)
EN ISO 12780-1:2011 Geometrical product specifications (GPS) - Straightness - Part 1: Vocabulary and parameters of straightness (ISO 12780-1:2011)
EN ISO 12780-2:2011 Geometrical product specifications (GPS) - Straightness - Part 2: Specification operators (ISO 12780-2:2011)
EN ISO 12781-1:2011 Geometrical product specifications (GPS) - Flatness - Part 1: Vocabulary and parameters of flatness (ISO 12781-1:2011)
EN ISO 12781-2:2011 Geometrical product specifications (GPS) - Flatness - Part 2: Specification operators (ISO 12781-2:2011)
EN ISO 13102:2012 Geometrical product specifications (GPS) - Dimensional measuring equipment: Electronic digital-indicator gauge - Design and metrological characteristics (ISO 13102:2012)
EN ISO 13225:2012 Geometrical product specifications (GPS) - Dimensional measuring equipment; Height gauges - Design and metrological characteristics (ISO 13225:2012)
EN ISO 13385-1:2011 Geometrical product specifications (GPS) - Dimensional measuring equipment - Part 1: Callipers; Design and metrological characteristics (ISO 13385-1:2011)
EN ISO 13385-2:2011 Geometrical product specifications (GPS) - Dimensional measuring equipment - Part 2: Calliper depth gauges; Design and metrological characteristics (ISO 13385-2:2011)
EN ISO 13565-1:1997 Geometrical product specifications (GPS) - Surface texture: Profile method; surfaces having stratified functional properties - Part 1: Filtering and general measurement conditions (ISO 13565-1:1996)
EN ISO 13565-2:1997 Geometrical product specifications (GPS) - Surface texture: Profile method; surfaces having stratified functional properties - Part 2: Height characterization using the linear material ratio curve (ISO 13565-2:1996)
EN ISO 13565-3:2000 Geometrical Product Specifications (GPS) - Surface texture: Profile method; surfaces having stratified functional properties - Part 3: Height characterization using the material probability curve (ISO 13565-3:1998)
EN ISO 14253-1:2013 Geometrical product specifications (GPS) - Inspection by measurement of workpieces and measuring equipment - Part 1: Decision rules for proving conformity or nonconformity with specification (ISO 14253-1:2013)
EN ISO 14253-2:2011 Geometrical product specifications (GPS) - Inspection by measurement of workpieces and measuring equipment - Part 2: Guidance for the estimation of uncertainty in GPS measurement, in calibration of measuring equipment and in product verification (ISO 1425
EN ISO 14253-2:2011/AC:2013 Geometrical product specifications (GPS) - Inspection by measurement of workpieces and measuring equipment - Part 2: Guidance for the estimation of uncertainty in GPS measurement, in calibration of measuring equipment and in product verification - Technic
EN ISO 14253-3:2011 Geometrical product specifications (GPS) - Inspection by measurement of workpieces and measuring equipment - Part 3: Guidelines for achieving agreements on measurement uncertainty statements (ISO 14253-3:2011)
CEN ISO/TS 14253-4:2010 Geometrical product specifications (GPS) - Inspection by measurement of workpieces and measuring equipment - Part 4: Background on functional limits and specification limits in decision rules (ISO/TS 14253-4:2010)
EN ISO 14253-5:2015 Geometrical product specifications (GPS) - Inspection by measurement of workpieces and measuring equipment - Part 5: Uncertainty in verification testing of indicating measuring instruments (ISO 14253-5:2015)
EN ISO 14405-1:2010 Geometrical product specifications (GPS) - Dimensional tolerancing - Part 1: Linear sizes (ISO 14405-1:2010)
EN ISO 14405-2:2011 Geometrical product specifications (GPS) - Dimensional tolerancing - Part 2: Dimensions other than linear sizes (ISO 14405-2:2011)
EN ISO 14406:2010 Geometrical product specifications (GPS) - Extraction (ISO 14406:2010)
EN ISO 14638:2015 Geometrical product specifications (GPS) - Matrix model (ISO 14638:2015)
EN ISO 14660-2:1999 Geometrical Product Specifications (GPS) - Geometrical features - Part 2: Extracted median line of a cylinder and a cone, extracted median surface, local size of an extracted feature (ISO 14660-2:1999)
EN ISO 14978:2006 Geometrical Product Specifications (GPS) - General concepts and requirements for GPS measuring equipment (ISO 14978:2006)
EN ISO 14978:2006/AC:2008 Geometrical product specifications (GPS) - General concepts and requirements for GPS measuring equipment (ISO 14978:2006/Cor 1:2008)
CEN ISO/TS 15530-1:2013 Geometrical product specifications (GPS) - Coordinate measuring machines (CMM): Technique for determining the uncertainty of measurement - Part 1: Overview and metrological characteristics (ISO/TS 15530-1:2013)
EN ISO 15530-3:2011 Geometrical product specifications (GPS) - Coordinate measuring machines (CMM): Technique for determining the uncertainty of measurement - Part 3: Use of calibrated workpieces or measurement standards (ISO 15530-3:2011)
EN ISO 16610-1:2015 Geometrical product specifications (GPS) - Filtration - Part 1: Overview and basic concepts (ISO 16610-1:2015)
EN ISO 16610-20:2015 Geometrical product specifications (GPS) - Filtration - Part 20: Linear profile filters: Basic concepts (ISO 16610-20:2015)
EN ISO 16610-21:2012 Geometrical product specifications (GPS) - Filtration - Part 21: Linear profile filters: Gaussian filters (ISO 16610-21:2011)
EN ISO 16610-22:2015 Geometrical product specifications (GPS) - Filtration - Part 22: Linear profile filters: Spline filters (ISO 16610-22:2015)
EN ISO 16610-29:2015 Geometrical product specifications (GPS) - Filtration - Part 29: Linear profile filters: Spline wavelets (ISO 16610-29:2015)
EN ISO 16610-40:2015 Geometrical product specifications (GPS) - Filtration - Part 40: Morphological profile filters: Basic concepts (ISO 16610-40:2015)
EN ISO 16610-41:2015 Geometrical product specifications (GPS) - Filtration - Part 41: Morphological profile filters: Disk and horizontal line-segment filters (ISO 16610-41:2015)
EN ISO 16610-49:2015 Geometrical product specifications (GPS) - Filtration - Part 49: Morphological profile filters: Scale space techniques (ISO 16610-49:2015)
EN ISO 16610-60:2015 Geometrical Product Specification (GPS) - Filtration - Part 60: Linear areal filters: Basic concepts (ISO 16610-60:2015)
EN ISO 16610-61:2015 Geometrical product specification (GPS) - Filtration - Part 61: Linear areal filters - Gaussian filters (ISO 16610-61:2015)
EN ISO 16610-71:2014 Geometrical product specifications (GPS) - Filtration - Part 71: Robust areal filters: Gaussian regression filters (ISO 16610-71:2014)
EN ISO 16610-85:2013 Geometrical product specifications (GPS) - Filtration- Part 85: Morphological areal filters: Segmentation (ISO 16610-85:2013)
EN ISO 17450-1:2011 Geometrical product specifications (GPS) - General concepts - Part 1: Model for geometrical specification and verification (ISO 17450-1:2011)
EN ISO 17450-2:2012 Geometrical product specifications (GPS) - General concepts - Part 2: Basic tenets, specifications, operators, uncertainties and ambiguities (ISO 17450-2:2012)
EN ISO 22432:2011 Geometrical product specifications (GPS) - Features utilized in specification and verification (ISO 22432:2011)
EN ISO 25178-2:2012 Geometrical product specifications (GPS) - Surface texture: Areal - Part 2: Terms, definitions and surface texture parameters (ISO 25178-2:2012)
EN ISO 25178-3:2012 Geometrical product specifications (GPS) - Surface texture: Areal - Part 3: Specification operators (ISO 25178-3:2012)
EN ISO 25178-6:2010 Geometrical product specifications (GPS) - Surface texture: Areal - Part 6: Classification of methods for measuring surface texture (ISO 25178-6:2010)
EN ISO 25178-70:2014 Geometrical product specification (GPS) - Surface texture: Areal - Part 70: Material measures (ISO 25178-70:2014)
EN ISO 25178-71:2012 Geometrical product specifications (GPS) - Surface texture: Areal - Part 71: Software measurement standards (ISO 25178-71:2012)
EN ISO 25178-601:2010 Geometrical product specifications (GPS) - Surface texture: Areal - Part 601: Nominal characteristics of contact (stylus) instruments (ISO 25178-601:2010)
EN ISO 25178-602:2010 Geometrical product specifications (GPS) - Surface texture: Areal - Part 602: Nominal characteristics of non-contact (confocal chromatic probe) instruments (ISO 25178-602:2010)
EN ISO 25178-603:2013 Geometrical product specifications (GPS) - Surface texture: Areal - Part 603: Nominal characteristics of non-contact (phase-shifting interferometric microscopy) instruments (ISO 25178-603:2013)
EN ISO 25178-604:2013 Geometrical product specifications (GPS) - Surface texture: Areal - Part 604: Nominal characteristics of non-contact (coherence scanning interferometry) instruments (ISO 25178-604:2013)
EN ISO 25178-605:2014 Geometrical product specifications (GPS) - Surface texture: Areal - Part 605: Nominal characteristics of non-contact (point autofocus probe) instruments (ISO 25178-605:2014)
EN ISO 25178-606:2015 Geometrical product specification (GPS) - Surface texture: Areal - Part 606: Nominal characteristics of non-contact (focus variation) instruments (ISO 25178-606:2015)
EN ISO 25178-701:2010 Geometrical product specifications (GPS) - Surface texture: Areal - Part 701: Calibration and measurement standards for contact (stylus) instruments (ISO 25178-701:2010)
EN ISO 25378:2011 Geometrical product specifications (GPS) - Characteristics and conditions - Definitions (ISO 25378:2011)
missing AC:
or
