full list:
EN 58:2012 Bitumen and bituminous binders - Sampling bituminous binders
EN 1425:2012 Bitumen and bituminous binders - Characterization of perceptible properties
EN 1426:2015 Bitumen and bituminous binders - Determination of needle penetration
EN 1427:2015 Bitumen and bituminous binders - Determination of the softening point - Ring and Ball method
EN 1428:2012 Bitumen and bituminous binders - Determination of water content in bituminous emulsions - Azeotropic distillation method
EN 1429:2013 Bitumen and bituminous binders - Determination of residue on sieving of bituminous emulsions, and determination of storage stability by sieving
EN 1430:2009 Bitumen and bituminous binders - Determination of particle polarity of bituminous emulsions
EN 1431:2009 Bitumen and bituminous binders - Determination of residual binder and oil distillate from bitumen emulsions by distillation
EN 12591:2009 Bitumen and bituminous binders - Specifications for paving grade bitumens
EN 12592:2014 Bitumen and bituminous binders - Determination of solubility
EN 12593:2015 Bitumen and bituminous binders - Determination of the Fraass breaking point
EN 12594:2014 Bitumen and bituminous binders - Preparation of test samples
EN 12595:2014 Bitumen and bituminous binders - Determination of kinematic viscosity
EN 12596:2014 Bitumen and bituminous binders - Determination of dynamic viscosity by vacuum capillary
EN 12597:2014 Bitumen and bituminous binders - Terminology
EN 12606-1:2015 Bitumen and bituminous binders - Determination of the paraffin wax content - Part 1: Method by distillation
EN 12606-2:1999 Bitumen and bituminous binders - Determination of the paraffin wax content - Part 2: Method of extraction
EN 12607-1:2014 Bitumen and bituminous binders - Determination of the resistance to hardening under influence of heat and air - Part 1: RTFOT method
EN 12607-2:2014 Bitumen and bituminous binders - Determination of the resistance to hardening under influence of heat and air - Part 2: TFOT method
EN 12607-3:2014 Bitumen and bituminous binders - Determination of the resistance to hardening under influence of heat and air - Part 3: RFT method
EN 12846-1:2011 Bitumen and bituminous binders - Determination of efflux time by the efflux viscometer - Part 1: Bituminous emulsions
EN 12846-2:2011 Bitumen and bituminous binders - Determination of efflux time by the efflux viscometer - Part 2: Cut-back and fluxed bituminous binders
EN 12847:2009 Bitumen and bituminous binders - Determination of settling tendency of bituminous emulsions
EN 12848:2009 Bitumen and bituminous binders - Determination of mixing stability with cement of bituminous emulsions
EN 12849:2009 Bitumen and bituminous binders - Determination of penetration power of bituminous emulsions
EN 12850:2009 Bitumen and bituminous binders - Determination of the pH value of bituminous emulsions
EN 13074-1:2011 Bitumen and bituminous binders - Recovery of binder from bituminous emulsion or cut-back or fluxed bituminous binders - Part 1: Recovery by evaporation
EN 13074-2:2011 Bitumen and bituminous binders - Recovery of binder from bituminous emulsion or cut-back or fluxed bituminous binders - Part 2: Stabilisation after recovery by evaporation
EN 13075-1:2009 Bitumen and bituminous binders - Determination of breaking behaviour - Part 1: Determination of breaking value of cationic bituminous emulsions, mineral filler method
EN 13075-2:2009 Bitumen and bituminous binders - Determination of breaking behaviour - Part 2: Determination of fines mixing time of cationic bituminous emulsions
EN 13301:2010 Bitumen and bituminous binders - Determination of staining tendency of bitumen
EN 13302:2010 Bitumen and bituminous binders - Determination of dynamic viscosity of bituminous binder using a rotating spindle apparatus
EN 13303:2009 Bitumen and bituminous binders - Determination of the loss in mass after heating of industrial bitumen
EN 13304:2009 Bitumen and bituminous binders - Framework for specification of oxidised bitumens
EN 13305:2009 Bitumen and bituminous binders - Framework for specification of hard industrial bitumens
EN 13358:2010 Bitumen and bituminous binders - Determination of the distillation characteristics of cut-back and fluxed bituminous binders made with mineral fluxes
EN 13398:2010 Bitumen and bituminous binders - Determination of the elastic recovery of modified bitumen
EN 13399:2010 Bitumen and bituminous binders - Determination of storage stability of modified bitumen
EN 13587:2010 Bitumen and bituminous binders - Determination of the tensile properties of bituminous binders by the tensile test method
EN 13588:2008 Bitumen and bituminous binders - Determination of cohesion of bituminous binders with pendulum test
EN 13589:2008 Bitumen and bituminous binders - Determination of the tensile properties of modified bitumen by the force ductility method
EN 13614:2011 Bitumen and bituminous binders - Determination of adhesivity of bituminous emulsions by water immersion test
EN 13632:2010 Bitumen and bituminous binders - Visualisation of polymer dispersion in polymer modified bitumen
EN 13702:2010 Bitumen and bituminous binders - Determination of dynamic viscosity of modified bitumen by cone and plate method
EN 13703:2003 Bitumen and bituminous binders - Determination of deformation energy
EN 13808:2013 Bitumen and bituminous binders - Framework for specifying cationic bituminous emulsions
EN 13924-1:2015 Bitumen and bituminous binders - Specification framework for special paving grade bitumen - Part 1: Hard paving grade bitumens
EN 13924-2:2014 Bitumen and bituminous binders - Specification framework for special paving grade bitumen - Part 2: Multigrade paving grade bitumens
EN 14023:2010 Bitumen and bituminous binders - Specification framework for polymer modified bitumens
EN 14769:2012 Bitumen and bituminous binders - Accelerated long-term ageing conditioning by a Pressure Ageing Vessel (PAV)
EN 14770:2012 Bitumen and bituminous binders - Determination of complex shear modulus and phase angle - Dynamic Shear Rheometer (DSR)
EN 14771:2012 Bitumen and bituminous binders - Determination of the flexural creep stiffness - Bending Beam Rheometer (BBR)
EN 15322:2013 Bitumen and bituminous binders - Framework for specifying cut-back and fluxed bituminous binders
EN 15323:2007 Bitumen and bituminous binders - Accelerated long-term ageing/conditioning by the rotating cylinder method (RCAT)
CEN/TS 15324:2008 Bitumen and bituminous binders - Determination of equiviscous temperature based on Low Shear Viscosity using a Dynamic Shear Rheometer in low frequency oscillation mode
CEN/TS 15325:2008 Bitumen and bituminous binders - Determination of Zero-Shear Viscosity (ZSV) using a Shear Stress Rheometer in creep mode
EN 15326:2007+A1:2009 Bitumen and bituminous binders - Measurement of density and specific gravity - Capillary-stoppered pyknometer method
CEN/TR 15352:2006 Bitumen and bituminous binders - Development of performance-related specifications: status report 2005
EN 15626:2009 Bitumen and bituminous binders - Determination of adhesivity of cut-back and fluxed bituminous binders by water immersion test - Aggregate method
CEN/TS 15963:2014 Bitumen and bituminous binders - Determination of the fracture toughness temperature by a three point bending test on a notched specimen
EN 16345:2012 Bitumen and bituminous binders - Determination of efflux time of bituminous emulsions using the Redwood No. II Viscometer
CEN/TS 16346:2012 Bituminous binders - Determination of breaking behaviour and immediate adhesivity of cationic bituminous emulsions with 2/4 mm aggregate
EN 16659:2015 Bitumen and Bituminous Binders - Multiple Stress Creep and Recovery Test (MSCRT)
missing:
or
