complete
EN 495-5:2013 Flexible sheets for waterproofing - Determination of foldability at low temperature - Part 5: Plastic and rubber sheets for roof waterproofing
EN 1107-1:1999 Flexible sheets for waterproofing - Part 1: Bitumen sheets for roof waterproofing - Determination of dimensional stability
EN 1107-2:2001 Flexible sheets for waterproofing - Determination of dimensional stability - Part 2: Plastic and rubber sheets for roof waterproofing
EN 1108:1999 Flexible sheets for waterproofing - Bitumen sheets for roof waterproofing - Determination of form stability under cyclical temperature changes
EN 1109:2013 Flexible sheets for waterproofing - Bitumen sheets for roof waterproofing - Determination of flexibility at low temperature
EN 1110:2010 Flexible sheets for waterproofing - Bitumen sheets for roof waterproofing - Determination of flow resistance at elevated temperature
EN 1296:2000 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roofing - Method of artificial ageing by long term exposure to elevated temperature
EN 1297:2004 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Method of artificial ageing by long term exposure to the combination of UV radiation, elevated temperature and water
EN 1548:2007 Flexible sheets for waterproofing - Plastic and rubber sheets for roof waterproofing - Method for exposure to bitumen
EN 1844:2013 Flexible sheets for waterproofing - Determination of resistance to ozone - Plastic and rubber sheets for roof waterproofing
EN 1847:2009 Flexible sheets for waterproofing - Plastics and rubber sheets for roof waterproofing - Methods for exposure to liquid chemicals, including water
EN 1848-1:1999 Flexible sheets for waterproofing - Determination of length, width and straightness - Part 1: Bitumen sheets for roof waterproofing
EN 1848-2:2001 Flexible sheets for waterproofing - Determination of length, width, straightness and flatness - Part 2: Plastic and rubber sheets for roof waterproofing
EN 1849-1:1999 Flexible sheets for waterproofing - Determination of thickness and mass per unit area - Part 1: Bitumen sheets for roof waterproofing
EN 1849-2:2009 Flexible sheets for waterproofing - Determination of thickness and mass per unit area - Part 2: Plastic and rubber sheets
EN 1850-1:1999 Flexible sheets for waterproofing - Determination of visible defects - Part 1: Bitumen sheets for roof waterproofing
EN 1850-2:2001 Flexible sheets for waterproofing - Determination of visible defects - Part 2: Plastic and rubber sheets for roof waterproofing
EN 1928:2000 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Determination of watertightness
EN 1931:2000 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Determination of water vapour transmission properties
EN 1931:2000/AC:2001 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Determination of water vapour transmission properties
EN 12039:1999 Flexible sheets for waterproofing - Bitumen sheets for roof waterproofing - Determination of adhesion of granules
EN 12310-1:1999 Flexible sheets for waterproofing - Part 1: Bitumen sheets for waterproofing - Determination of resistance to tearing (nail shank)
EN 12310-2:2000 Flexible sheets for waterproofing - Determination of resistance to tearing - Part 2: Plastic and rubber sheets for roof waterproofing
EN 12311-1:1999 Flexible sheets for waterproofing - Part 1: Bitumen sheets for roof waterproofing - Determination of tensile properties
EN 12311-2:2013 Flexible sheets for waterproofing - Determination of tensile properties - Part 2: Plastic and rubber sheets for roof waterproofing
EN 12316-1:1999 Flexible sheets for waterproofing - Part 1: Bitumen sheets for roof waterproofing - Determination of peel resistance of joints
EN 12316-2:2013 Flexible sheets for waterproofing - Determination of peel resistance of joints - Part 2: Plastic and rubber sheets for roof waterproofing
EN 12317-1:1999 Flexible sheets for waterproofing - Part 1: Bitumen sheets for roof waterproofing - Determination of shear resistance of joints
EN 12317-2:2010 Flexible sheets for waterproofing - Determination of shear resistance of joints - Part 2: Plastic and rubber sheets for roof waterproofing
EN 12691:2006 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Determination of resistance to impact
EN 12730:2015 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Determination of resistance to static loading
EN 13111:2010 Flexible sheets for waterproofing - Underlays for discontinuous roofing and walls - Determination of resistance to water penetration
EN 13375:2004 Flexible sheets for waterproofing - Waterproofing of concrete bridge decks and other concrete surfaces trafficable by vehicles - Specimen preparation
EN 13416:2001 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Rules for sampling
EN 13583:2012 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Determination of hail resistance
EN 13596:2004 Flexible sheets for waterproofing - Waterproofing of concrete bridge decks and other concrete surfaces trafficable by vehicles - Determination of bond strength
EN 13653:2004 Flexible sheets for waterproofing - Waterproofing of concrete bridge decks and other concrete surfaces trafficable by vehicles - Determination of shear strength
EN 13707:2013 Flexible sheets for waterproofing - Reinforced bitumen sheets for roof waterproofing - Definitions and characteristics
EN 13859-1:2014 Flexible sheets for waterproofing - Definitions and characteristics of underlays - Part 1: Underlays for discontinuous roofing
EN 13859-2:2014 Flexible sheets for waterproofing - Definitions and characteristics of underlays - Part 2: Underlays for walls
EN 13897:2004 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Determination of watertightness after stretching at low temperature
EN 13948:2007 Flexible sheets for waterproofing - Bitumen, plastic and rubber sheets for roof waterproofing - Determination of resistance to root penetration
EN 13956:2012 Flexible sheets for waterproofing - Plastic and rubber sheets for roof waterproofing - Definitions and characteristics
EN 13967:2012 Flexible sheets for waterproofing - Plastic and rubber damp proof sheets including plastic and rubber basement tanking sheet - Definitions and characteristics
EN 13969:2004 Flexible sheets for waterproofing - Bitumen damp proof sheets including bitumen basement tanking sheets - Definitions and characteristics
EN 13969:2004/A1:2006 Flexible sheets for waterproofing - Bitumen damp proof sheets including bitumen basement tanking sheets - Definitions and characteristics
EN 13970:2004 Flexible sheets for waterproofing - Bitumen water vapour control layers - Definitions and characteristics
EN 13970:2004/A1:2006 Flexible sheets for waterproofing - Bitumen water vapour control layers - Definitions and characteristics
EN 13984:2013 Flexible sheets for waterproofing - Plastic and rubber vapour control layers - Definitions and characteristics
EN 14223:2005 Flexible sheets for waterproofing - Waterproofing of concrete bridge decks and other concrete surfaces trafficable by vehicles - Determination of water absorption
EN 14224:2010 Flexible sheets for waterproofing - Waterproofing of concrete bridge decks and other concrete surfaces trafficable by vehicles - Determination of ***** bridging ability
EN 14691:2005 Flexible sheets for waterproofing - Waterproofing of concrete bridge decks and other concrete surfaces trafficable by vehicles - Compatibility by heat conditioning
EN 14692:2005 Flexible sheets for waterproofing - Waterproofing of concrete bridge decks and other concrete surfaces trafficable by vehicles - Determination of the resistance to compaction of an asphalt layer
EN 14693:2006 Flexible sheets for waterproofing - Waterproofing of concrete bridge decks and other concrete surfaces trafficable by vehicles - Determination of the behaviour of bitumen sheets during application of mastic asphalt
EN 14694:2005 Flexible sheets for waterproofing - Waterproofing of concrete bridge decks and other concrete surfaces trafficable by vehicles - Determination of resistance to dynamic water pressure after damage by pre-treatment
EN 14695:2010 Flexible sheets for waterproofing - Reinforced bitumen sheets for waterproofing of concrete bridge decks and other trafficked areas of concrete - Definitions and characteristics
EN 14909:2012 Flexible sheets for waterproofing - Plastic and rubber damp proof courses - Definitions and characteristics
EN 14967:2006 Flexible sheets for waterproofing - Bitumen damp proof courses - Definitions and characteristics
EN 15976:2011 Flexible sheets for waterproofing - Determination of emissivity
EN 16002:2010 Flexible sheets for waterproofing - Determination of the resistance to wind load of mechanically fastened flexible sheets for roof waterproofing
CEN/TR 16625:2013 Flexible sheets for waterproofing - Statistical definition of manufacturer's limiting value and declared value (MLV and MDV) - 95 % Statistic
or
