Results 1 to 11 of 11
Thread: CEN Standards Collection 216/370: CEN TC 112 - Wood Based Panels
    full list:
    CR 213:1984 Particle boards - Determination of formaldehyde emission under specified conditions - Method called: formaldehyde emission method
    EN 300:2006 Oriented Strand Boards (OSB) - Definitions, classification and specifications
    EN 309:2005 Particleboards - Definition and classification
    EN 310:1993 Wood-based panels - Determination of modulus of elasticity in bending and of bending strength
    EN 311:2002 Wood-based panels - Surface soundness - Test method
    EN 312:2010 Particleboards - Specifications
    EN 313-1:1996 Plywood - Classification and terminology - Part 1: Classification
    EN 313-2:1999 Plywood - Classification and terminology - Part 2: Terminology
    EN 314-1:2004 Plywood - Bonding quality - Part 1: Test methods
    EN 314-2:1993 Plywood - Bonding quality - Part 2: Requirements
    EN 315:2000 Plywood - Tolerances for dimensions
    EN 316:2009 Wood fibre boards - Definition, classification and symbols
    EN 317:1993 Particleboards and fibreboards - Determination of swelling in thickness after immersion in water
    EN 318:2002 Wood based panels - Determination of dimensional changes associated with changes in relative humidity
    EN 319:1993 Particleboards and fibreboards - Determination of tensile strength perpendicular to the plane of the board
    EN 320:2011 Particleboards and fibreboards - Determination of resistance to axial withdrawal of screws
    EN 321:2001 Wood-based panels - Determination of moisture resistance under cyclic test conditions
    EN 322:1993 Wood-based panels - Determination of moisture content
    EN 323:1993 Wood-based panels - Determination of density
    EN 324-1:1993 Wood-based panels - Determination of dimensions of boards - Part 1: Determination of thickness, width and length
    EN 324-2:1993 Wood-based panels - Determination of dimensions of boards - Part 2: Determination of squareness and edge straightness
    EN 325:2012 Wood-based panels - Determination of dimensions of test pieces
    EN 326-1:1994 Wood-based panels - Sampling, cutting and inspection - Part 1: Sampling and cutting of test pieces and expression of test results
    EN 326-2:2010+A1:2014 Wood-based panels - Sampling, cutting and inspection - Part 2: Initial type testing and factory production control
    EN 326-3:2003 Wood-based panels - Sampling, cutting and inspection - Part 3: Inspection of an isolated lot of panels
    EN 382-1:1993 Fibreboards - Determination of surface absorption - Part 1: Test method for dry process fibreboards
    EN 382-2:1993 Fibreboards - Determination of surface absorption - Part 2: Test method for hardboards
    EN 622-1:2003 Fibreboards - Specifications - Part 1: General requirements
    EN 622-2:2004 Fibreboards - Specifications - Part 2: Requirements for hardboards
    EN 622-2:2004/AC:2005 Fibreboards - Specifications - Part 2: Requirements for hardboards
    EN 622-3:2004 Fibreboards - Specifications - Part 3: Requirements for medium boards
    EN 622-4:2009 Fibreboards - Specifications - Part 4: Requirements for softboards
    EN 622-5:2009 Fibreboards - Specifications - Part 5: Requirements for dry process boards (MDF)
    EN 633:1993 Cement-bonded particleboards - Definition and classification
    EN 634-1:1995 Cement-bonded particleboards - Specification - Part 1: General requirements
    EN 634-2:2007 Cement-bonded particleboards - Specifications - Part 2: Requirements for OPC bonded particleboards for use in dry, humid and external conditions
    EN 635-1:1994 Plywood - Classification by surface appearance - Part 1: General
    EN 635-2:1995 Plywood - Classification by surface appearance - Part 2: Hardwood
    EN 635-3:1995 Plywood - Classification by surface appearance - Part 3: Softwood
    CEN/TS 635-4:2007 Plywood - Classification by surface appearance - Part 4: Parameters of ability for finishing, guideline
    EN 635-5:1999 Plywood - Classification by surface appearance - Part 5: Methods for measuring and expressing characteristics and defects
    EN 636:2012+A1:2015 Plywood - Specifications
    EN 717-1:2004 Wood-based panels - Determination of formaldehyde release - Part 1: Formaldehyde emission by the chamber method
    EN 717-3:1996 Wood-based panels - Determination of formaldehyde release - Part 3: Formaldehyde release by the flask method
    EN 1058:2009 Wood-based panels - Determination of characteristic 5-percentile values and characteristic mean values
    EN 1087-1:1995 Particleboards - Determination of moisture resistance - Part 1: Boil test
    CEN/TS 1099:2007 Plywood - Biological durability - Guidance for the assessment of plywood for use in different use classes
    EN 1128:1995 Cement-bonded particleboards - Determination of hard body impact resistance
    EN 1156:2013 Wood-based panels - Determination of duration of load and creep factors
    EN 1328:1996 Cement bonded particleboards - Determination of frost resistance
    EN 12369-1:2001 Wood-based panels - Characteristic values for structural design - Part 1: OSB, particleboards and fibreboards
    EN 12369-2:2011 Wood-based panels - Characteristic values for structural design - Part 2: Plywood
    EN 12369-3:2008 Wood-based panels - Characteristic values for structural design - Part 3: Solid-wood panels
    EN ISO 12460-3:2015 Wood-based panels - Determination of formaldehyde release - Part 3: Gas analysis method (ISO 12460-3:2015)
    EN ISO 12460-4:2016 Wood-based panels - Determination of formaldehyde release - Part 4: Desiccator method (ISO 12460-4:2016)
    EN ISO 12460-5:2015 Wood-based panels - Determination of formaldehyde release - Part 5: Extraction method (called the perforator method) (ISO 12460-5:2015)
    EN 12775:2001 Solid wood panels - Classification and terminology
    EN 12871:2013 Wood-based panels - Determination of performance characteristics for load bearing panels for use in floors, roofs and walls
    CEN/TR 12872:2014 Wood-based panels - Guidance on the use of load-bearing boards in floors, walls and roofs
    EN 13017-1:2000 Solid wood panels - Classification by surface appearance - Part 1: Softwood
    EN 13017-2:2000 Solid wood panels - Classification by surface appearance - Part 2: Hardwood
    EN 13353:2008+A1:2011 Solid wood panels (SWP) - Requirements
    EN 13354:2008 Solid wood panels (SWP) - Bonding quality - Test method
    EN 13446:2002 Wood-based panels - Determination of withdrawal capacity of fasteners
    EN 13810-1:2002 Wood-based panels - Floating floors - Part 1: Performance specifications and requirements
    CEN/TS 13810-2:2003 Wood-based panels - Floating floors - Part 2: Test methods
    EN 13879:2002 Wood-based panels - Determination of edgewise bending properties
    EN 13986:2004+A1:2015 Wood-based panels for use in construction - Characteristics, evaluation of conformity and marking
    EN 14272:2011 Plywood - Calculation method for some mechanical properties
    EN 14279:2004+A1:2009 Laminated Veneer Lumber (LVL) - Definitions, classification and specifications
    EN 14322:2004 Wood-based panels - Melamine faced boards for interior uses - Definition, requirements and classification
    EN 14323:2004 Wood-based panels - Melamine faced boards for interior uses - Test methods
    EN 14354:2004 Wood-based panels - Wood veneer floor covering
    EN 14354:2004/AC:2006 Wood-based panels - Wood veneer floor covering
    EN 14755:2005 Extruded particleboards - Specifications
    CEN/TS 14966:2005 Wood-based panels - Small scale indicative test methods for certain mechanical properties
    EN 15197:2007 Wood-based panels - Flaxboards - Specifications
    CEN/TS 16368:2014 Lightweight Particleboards - Specifications
    CEN/TS 16526:2013 Sandwich boards for furniture (SWB-F) - Factory made products - Definition, classification and test methods for determination of performance characteristics
    missing:
    Re: CEN Standards Collection 216/300: CEN TC 112 - Wood Based Panels
    This link :
    update:
    EN ISO 12460-4:2016 Wood-based panels - Determination of formaldehyde release - Part 4: Desiccator method (ISO 12460-4:2016) - added missing standard
    EN 636:2012+A1:2015 Plywood - Specifications - added missing standard
    missing list:
    fresh links:
    or
    Aug 2015
    Dubai, UAE
    Blog Entries
    4
    Thanks & Regards:
    Amjad Malik
    thank you
    Dear BornToSin, can you fresh the link of hugeflies?
    here it is:
    Re: CEN Standards Collection 216/340: CEN TC 112 - Wood Based Panels
    no updates, still missing:
    fresh links:
    or
    Re: CEN Standards Collection 216/350: CEN TC 112 - Wood Based Panels
    update:
    CR 213:1984 Particle boards - Determination of formaldehyde emission under specified conditions - Method called: formaldehyde emission method - added missing standard
    CEN/TS 13810-2:2003 Wood-based panels - Floating floors - Part 2: Test methods - added missing standard
    this sector also completed!
    links:
    or
    Re: CEN Standards Collection 216/370: CEN TC 112 - Wood Based Panels
    two new are missing:
    EN 14322:2017 Wood-based panels - Melamine faced board for interior uses - Definition* requirements and classification
    EN 14323:2017 Wood-based panels - Melamine faced boards for interior uses - Test methods
  14. #11
    update:
    bq or missing or en:
    EN 316:2009 Wood fibre boards - Definition* classification and symbols
    EN 14279:2004+A1:2009 Laminated Veneer Lumber (LVL) - Definitions* classification and specifications
    CEN/TS 16526:2013 Sandwich boards for furniture (SWB-F) - Factory made products - Definition* classification and test methods for determination of performance characteristics
    complete
  1. ISO Collection 96/300:ISO/TC 89 - Wood-based panels
    Last Post: 12-09-2017, 04:49 PM
  2. CEN Standards Collection 245/370: CEN TC 411-Bio-based Products
    Last Post: 07-03-2017, 02:52 AM
  3. Replies: 8
    Last Post: 06-29-2017, 07:52 AM
  4. Replies: 5
    Last Post: 06-02-2017, 04:51 AM
  5. Replies: 5
    Last Post: 06-02-2017, 04:42 AM
