Page 1 of 2 1 2 LastLast
Results 1 to 12 of 17
Thread: CEN Standards Collection 194/370: CEN TC 191-Fixed Firefighting Systems
    full list:
    EN 615:2009 Fire protection - Fire extinguishing media - Specifications for powders (other than class D powders)
    EN 671-1:2012 Fixed firefighting systems - Hose systems - Part 1: Hose reels with semi-rigid hose
    EN 671-2:2012 Fixed firefighting systems - Hose systems - Part 2: Hose systems with lay-flat hose
    EN 671-3:2009 Fixed firefighting systems - Hose systems - Part 3: Maintenance of hose reels with semi-rigid hose and hose systems with lay-flat hose
    EN 1568-1:2008 Fire extinguishing media - Foam concentrates - Part 1: Specification for medium expansion foam concentrates for surface application to water-immiscible liquids
    EN 1568-1:2008/AC:2010 Fire extinguishing media - Foam concentrates - Part 1: Specification for medium expansion foam concentrates for surface application to water-immiscible liquids
    EN 1568-2:2008 Fire extinguishing media - Foam concentrates - Part 2: Specification for high expansion foam concentrates for surface application to water-immiscible liquids
    EN 1568-2:2008/AC:2010 Fire extinguishing media - Foam concentrates - Part 2: Specification for high expansion foam concentrates for surface application to water-immiscible liquids
    EN 1568-3:2008 Fire extinguishing media - Foam concentrates - Part 3: Specification for low expansion foam concentrates for surface application to water-immiscible liquids
    EN 1568-3:2008/AC:2010 Fire extinguishing media - Foam concentrates - Part 3: Specification for low expansion foam concentrates for surface application to water-immiscible liquids
    EN 1568-4:2008 Fire extinguishing media - Foam concentrates - Part 4: Specification for low expansion foam concentrates for surface application to water-miscible liquids
    EN 1568-4:2008/AC:2010 Fire extinguishing media - Foam concentrates - Part 4: Specification for low expansion foam concentrates for surface application to water-miscible liquids
    EN ISO 5923:2012 Equipment for fire protection and fire fighting - Fire extinguishing media - Carbon dioxide (ISO 5923:2012)
    EN 12094-1:2003 Fixed firefighting systems - Components for gas extinguishing systems - Part 1: Requirements and test methods for electrical automatic control and delay devices
    EN 12094-2:2003 Fixed firefighting systems - Components for gas extinguishing systems - Part 2: Requirements and test methods for non-electrical automatic control and delay devices
    EN 12094-3:2003 Fixed firefighting systems - Components for gas extinguishing systems - Part 3: Requirements and test methods for manual triggering and stop devices
    EN 12094-4:2004 Fixed firefighting systems - Components for gas extinguishing systems - Part 4: Requirements and test methods for container valve assemblies and their actuators
    EN 12094-5:2006 Fixed firefighting systems - Components for gas extinguishing systems - Part 5: Requirements and test methods for high and low pressure selector valves and their actuators
    EN 12094-6:2006 Fixed firefighting systems - Components for gas extinguishing systems - Part 6: Requirements and test methods for non-electrical disable devices
    EN 12094-7:2000 Fixed firefighting systems - Components for gas extinguishing systems - Part 7: Requirements and test methods for nozzles for CO2 systems
    EN 12094-7:2000/A1:2005 Fixed firefighting systems - Components for gas extinguishing systems - Part 7: Requirements and test methods for nozzles for CO2 systems
    EN 12094-8:2006 Fixed firefighting systems - Components for gas extinguishing systems - Part 8: Requirements and test methods for connectors
    EN 12094-9:2003 Fixed firefighting systems - Components for gas extinguishing systems - Part 9: Requirements and test methods for special fire detectors
    EN 12094-10:2003 Fixed firefighting systems - Components for gas extinguishing systems - Part 10: Requirements and test methods for pressure gauges and pressure switches
    EN 12094-11:2003 Fixed firefighting systems - Components for gas extinguishing systems - Part 11: Requirements and test methods for mechanical weighing devices
    EN 12094-12:2003 Fixed firefighting systems - Components for gas extinguishing systems - Part 12: Requirements and test methods for pneumatic alarm devices
    EN 12094-13:2001 Fixed firefighting systems - Components for gas extinguishing systems - Part 13: Requirements and test methods for check valves and non-return valves
    EN 12094-13:2001/AC:2002 Fixed firefighting systems - Components for gas extinguishing systems - Part 13: Requirements and test methods for check valves and non-return valves
    EN 12094-16:2003 Fixed firefighting systems - Components for gas extinguishing systems - Part 16: Requirements and test methods for odorizing devices for CO2 low pressure systems
    EN 12101-1:2005 Smoke and heat control systems - Part 1: Specification for smoke barriers
    EN 12101-1:2005/A1:2006 Smoke and heat control systems - Part 1: Specification for smoke barriers
    EN 12101-2:2003 Smoke and heat control systems - Part 2: Specification for natural smoke and heat exhaust ventilators
    EN 12101-3:2015 Smoke and heat control systems - Part 3: Specification for powered smoke and heat control ventilators (Fans)
    CEN/TR 12101-4:2009 Smoke and heat control systems - Part 4: Installed SHEVS systems for smoke and heat ventilation
    CEN/TR 12101-5:2005 Smoke and heat control systems - Part 5: Guidelines on functional recommendations and calculation methods for smoke and heat exhaust ventilation systems
    EN 12101-6:2005 Smoke and heat control systems - Part 6: Specification for pressure differential systems - Kits
    EN 12101-6:2005/AC:2006 Smoke and heat control systems - Part 6: Specification for pressure differential systems - Kits
    EN 12101-7:2011 Smoke and heat control systems - Part 7: Smoke duct sections
    EN 12101-8:2011 Smoke and heat control systems - Part 8: Smoke control dampers
    EN 12101-10:2005 Smoke and heat control systems - Part 10: Power supplies
    EN 12101-10:2005/AC:2007 Smoke and heat control systems - Part 10: Power supplies
    EN 12259-1:1999 + A1:2001 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 1: Sprinklers
    EN 12259-1:1999 + A1:2001/A2:2004 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 1: Sprinklers
    EN 12259-1:1999 + A1:2001/A3:2006 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 1: Sprinklers
    EN 12259-2:1999 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 2: Wet alarm valve assemblies
    EN 12259-2:1999/A1:2001 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 2: Wet alarm valve assemblies
    EN 12259-2:1999/AC:2002 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 2: Wet alarm valve assemblies
    EN 12259-2:1999/A2:2005 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 2: Wet alarm valve assemblies
    EN 12259-3:2000 Fixed firefighting systems - Components for automatic sprinkler and water spray systems - Part 3: Dry alarm valve assemblies
    EN 12259-3:2000/A1:2001 Fixed firefighting systems - Components for automatic sprinkler and water spray systems - Part 3: Dry alarm valve assemblies
    EN 12259-3:2000/A2:2005 Fixed firefighting systems - Components for automatic sprinkler and water spray systems - Part 3: Dry alarm valve assemblies
    EN 12259-4:2000 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 4: Water motor alarms
    EN 12259-4:2000/A1:2001 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 4: Water motor alarms
    EN 12259-5:2002 Fixed firefighting systems - Components for sprinkler and water spray systems - Part 5: Water flow detectors
    EN 12416-1:2001+A2:2007 Fixed firefighting systems - Powder systems - Part 1: Requirements and test methods for components
    EN 12416-2:2001+A1:2007 Fixed firefighting systems - Powder systems - Part 2: Design, construction and maintenance
    EN 12845:2015 Fixed firefighting systems - Automatic sprinkler systems - Design, installation and maintenance
    EN 12845:2015/AC:2016 Fixed firefighting systems - Automatic sprinkler systems - Design, installation and maintenance
    EN 13565-1:2003+A1:2007 Fixed firefighting systems - Foam systems - Part 1: Requirements and test methods for components
    EN 13565-2:2009 Fixed firefighting systems - Foam systems - Part 2: Design, construction and maintenance
    EN 13565-2:2009/AC:2010 Fixed firefighting systems - Foam systems - Part 2: Design, construction and maintenance
    CEN/TS 14816:2008 Fixed firefighting systems - Water spray systems - Design, installation and maintenance
    CEN/TS 14972:2011 Fixed firefighting systems - Watermist systems - Design and installation
    EN 15004-1:2008 Fixed firefighting systems - Gas extinguishing systems - Part 1: Design, installation and maintenance (ISO 14520-1:2006, modified)
    EN 15004-2:2008 Fixed firefighting systems - Gas extinguishing systems - Part 2: Physical properties and system design of gas extinguishing systems for FK-5-1-12 extinguishant (ISO 14520-5:2006, modified)
    EN 15004-3:2008 Fixed firefighting systems - Gas extinguishing systems - Part 3: Physical properties and system design of gas extinguishing systems for HCFC Blend A extinguishant (ISO 14520-6:2006, modified)
    EN 15004-4:2008 Fixed firefighting systems - Gas extinguishing systems - Part 4: Physical properties and system design of gas extinguishing systems for HFC 125 extinguishant (ISO 14520-8:2006, modified)
    EN 15004-5:2008 Fixed firefighting systems - Gas extinguishing systems - Part 5: Physical properties and system design of gas extinguishing systems for HFC 227ea extinguishant (ISO 14520-9:2006, modified)
    EN 15004-6:2008 Fixed firefighting systems - Gas extinguishing systems - Part 6: Physical properties and system design of gas extinguishing systems for HFC 23 extinguishant (ISO 14520-10:2005, modified)
    EN 15004-7:2008 Fixed firefighting systems - Gas extinguishing systems - Part 7: Physical properties and system design of gas extinguishing systems for IG-01 extinguishant (ISO 14520-12:2005, modified)
    EN 15004-8:2008 Fixed firefighting system - Gas extinguishing systems - Part 8: Physical properties and system design of gas extinguishing systems for IG-100 extinguishant (ISO 14520-13:2005, modified)
    EN 15004-9:2008 Fixed firefighting systems - Gas extinguishing systems - Part 9: Physical properties and system design of gas extinguishing systems for IG-55 extinguishant (ISO 14520-14:2005, modified)
    EN 15004-10:2008 Fixed firefighting systems - Gas extinguishing systems - Part 10: Physical properties and system design of gas extinguishing systems for IG-541 extinguishant (ISO 14520-15:2005, modified)
    CEN/TR 15276-2:2009 Fixed firefighting systems - Condensed aerosol extinguishing systems - Part 2: Design, installation and maintenance
    EN 27201-1:1994 Fire protection - Fire extinguishing media - Halogenated hydrocarbons - Part 1: Specifications for halon 1211 and halon 1301 (ISO 7201-1:1989)
    EN 27201-2:1994 Fire protection - Fire extinguishing media - Halogenated hydrocarbons - Part 2: Code of practice for safe handling and transfer procedures (ISO 7201-2:1991)
    what we missing is this standards:
    EN 12101-6:2005/AC:2006 Smoke and heat control systems - Part 6: Specification for pressure differential systems - Kits - just AC 2006 missing
    EN 12845:2015/AC:2016 Fixed firefighting systems - Automatic sprinkler systems - Design, installation and maintenance - missing AC 2016
    Re: CEN Standards Collection 194/300: CEN TC 191-Fixed Firefighting Systems
    CEN TR 12101-5-2005 Smoke and heat control systems - Part 5 Guidelines on functional recommendations and calculation methods for smoke and heat exhaust ventilation systems
    thanks for valuable share
    Can anybody share all latest editions of all part of BS EN-12101 for smoke control systems. Please
    dear BornToSin,
    Can you please share all standards collection for all types of Cables.
    thanks in advance
    12101 is shared here...at least what I have...Marty also helped you with some missing standard....take a look a the list of standards of this CEN sector
    I can help you with cables if you know which CEN sectors you looking for ?!
    Dear BornToSin,
    Request you to share BS EN-12101-Part-9 & Part-4, which is missing. Request you to share following sectors of standards:
    a) CEN/TC72 : Fire Detection and Alarm system
    b) CEN/TC127: Fire safety in buildings
    c) CEN/TC228: Heating systems & Water based cooing systems in buildings
    d) CEN/TC247: Building Automation, Controls & Building management
    e) CEN/TC332: Laboratory equipment
    f) CEN/CLC/TC2: Power engineering
    g) CEN/TC197: Pumps
    h) CEN/TC 156: Ventilation buildings
    I) CEN/TC 192: Fire and rescue service equipments
    j) CEN/TC 70: Manual means of fire fighting equipments
    thanks in advance
    Quote Originally Posted by virtech1 View Post
    Dear BornToSin,
    a) CEN/TC72 : Fire Detection and Alarm system -
    g) CEN/TC197: Pumps
    thanks in advance
    some of that sectors are already shared, just do the advanced search on egpet
    the rest will be shared I promise
    Dear Born To Sin,
    g) CEN/TC197: Pumps
    thanks in advance
    update:
    CEN/TR 12101-5:2005 Smoke and heat control systems - Part 5: Guidelines on functional recommendations and calculation methods for smoke and heat exhaust ventilation systems - added missing standard thanx to Marty Thompson
    EN 12845:2015/AC:2016 Fixed firefighting systems - Automatic sprinkler systems - Design, installation and maintenance - added missing AC
    missing list:
    new links:
    or
  14. Re: CEN Standards Collection 194/300: CEN TC 191-Fixed Firefighting Systems
    Dear BornToSin
    Please BS EN 12101-4 and BS EN 12101-9
    Greetings
    Abo Khaled
  16. #12
    CEN/TR 12101-4:2009 Smoke and heat control systems - Part 4: Installed SHEVS systems for smoke and heat ventilation is missing standard, I don't have it, if I do, I will share it
    EN 12101-9 is withdrawn long time ago, if I'm not wrong?
  1. Need BS EN 12259 - Fixed firefighting systems
    By upul in forum Safety And Environment
    Last Post: 09-07-2015, 04:01 PM
  2. Replies: 2
    Last Post: 01-03-2015, 11:05 PM
  3. Replies: 20
    Last Post: 11-13-2013, 12:48 PM
  4. Replies: 4
    Last Post: 02-01-2013, 02:15 PM
  5. Replies: 7
    Last Post: 01-24-2013, 06:49 AM
