Please, Could anyone share the following ASTM standards?
C165, C303, C552, C871, D696, D1621, D1622, D1623, D2842, D2856, D6226, E84, E96/E96M
Many thanks in advance
C165-07(2012) Standard Test Method for Measuring Compressive Properties of Thermal Insulations
C303-10 Standard Test Method for Dimensions and Density of Preformed Block and Board- Type Thermal Insulation
C552-15 Standard Specification for Cellular Glass Thermal Insulation
C871-11e1 Standard Test Methods for Chemical Analysis of Thermal Insulation Materials for Leachable Chloride, Fluoride, Silicate, and Sodium Ions
D696-08e1 Standard Test Method for Coefficient of Linear Thermal Expansion of Plastics Between −30°C and 30°C with a Vitreous Silica Dilatometer
D1621-10 Standard Test Method for Compressive Properties Of Rigid Cellular Plastics
D1622D1622M-14 Standard Test Method for Apparent Density of Rigid Cellular Plastics
D1623-09 Standard Test Method for Tensile and Tensile Adhesion Properties of Rigid Cellular Plastics
D2842-12 Standard Test Method for Water Absorption of Rigid Cellular Plastics
D2856-94(1998) Standard Test Method for Open-Cell Content of Rigid Cellular Plastics by the Air Pycnometer
D6226-15 Standard Test Method for Open Cell Content of Rigid Cellular Plastics
E84-15a Standard Test Method for Surface Burning Characteristics of Building Materials
E96E96M-15 Standard Test Methods for Water Vapor Transmission of Materials
Thank you very much Marty.
thanks a lot
ASTM (Insulation Issue) upload by Marty Thompson earlier in one folder
I am an Thermal Insulation Contractor by Profession.
Thank you very much.
