Results 1 to 7 of 7
Thread: A.C interference: Please share EN 50443, CIGRE’s Technical Brochure No. 95 in 1995
  1. A.C interference: Please share EN 50443, CIGRE’s Technical Brochure No. 95 in 1995
    Hi everybody,
    I really need some standard and handbook for evaluating A.C interference and solution including calculation of induced voltage and A.C current density as EN 50443 and CIGRE’s Technical Brochure No. 95 in 1995. Should you have these documents, please share. Thanks so much!
    Re: A.C interference: Please share EN 50443, CIGRE’s Technical Brochure No. 95 in 199
    BS EN 50443-2011 Effects of electromagnetic interference on pipelines caused by high voltage a.c. electric traction systems and or high voltage a.c. power supply systems
  5. Re: A.C interference: Please share EN 50443, CIGRE’s Technical Brochure No. 95 in 199
    Thanks so much!
    Here are papers on AC interference...
    Guideline on the Electrical Co-ordination of Pipelines and Power Lines
    INGAA - Criteria for Pipelines Co-Existing with Electric Power Lines
    Calculation and analysis of inductive coupling effects for HV transmission lines on aerial pipelines
    AC Corrosion Induced by High Voltage Power Line on Cathodically Protected Pipeline
    AC interference on pipelines due to double circuit power lines; A detailed study
    Numerical Evaluation of Induced Voltags in the Metallic Underground Pipelines
    Inductive interference calculation on imperfect coated pipelines due to nearby faulted parallel transmission lines
    Calculation and Analysis of the Coupling Effects of High Voltage Transmission Lines in Joint-use Corridors Shared by Multi-systems
    Transmission Line EMF Interference with Buried Pipeline; Essential & Cautions
    Induced Voltages in Metallic Pipelines near Power Transmission Lines
    Guide - Influence of High Voltage DC Power Lines on Metallic Pipelines Oct. 2014
    Induced currents in gas pipelines due to nearby power lines
    Safety of Pipelines in Close Proximity to Electric Transmission Lines
  7. Re: A.C interference: Please share EN 50443, CIGRE’s Technical Brochure No. 95 in 199
    Thanks so much!
    Also if any one has NACE course manual for CP interference please upload
    thank you!
  1. CIGRE - Power Systems/transformers/modelling
    By user82 in forum Electrical & Power Engineering
    Last Post: 05-02-2019, 05:17 PM
  2. NACE CP interference course manual
    By brom in forum Materials Science &Corrosion
    Last Post: 03-25-2019, 01:18 PM
  3. Share useful papers from technical magazines
    By behnamhf in forum Engineering Spreadsheets & Presentations
    Last Post: 04-10-2017, 12:04 AM
  4. NACE CP interference manual
    Last Post: 01-28-2016, 06:55 PM
  5. Replies: 0
    Last Post: 05-07-2010, 05:55 AM
