Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
Thread: Rstreng
    Rstreng
    Hi, please if anyone has RSTRENG for pipeline corrosion defect assessment, please share.
    download toolbox
    search technical toolboxes in this website, in the software technical toolboxes exist one module for rstreng
    sorry for my bad english but I speak spanish
    IS THERE ANYONE WHO HAS THIS BOOK? PLEASE SHARE....
    Overview
    Based on some of his students most frequently asked questions, Antaki emphasizes the practical applications of this ASME recommended practice. With this book readers will understand and apply API 579 in their daily work. The material is based on the author’s course and presented in clear concise manor. The book demonstrates how the disciplines of stress analysis, materials engineering, and nondestructive inspection interact and apply to fitness-for-service assessment. These assessment methods apply to pressure vessels, piping, and tanks that are in service. This makes it the perfect companion book for Ellenberger’s, Pressure Vessels: ASME Code Simplified as well as Ellenberger’s Piping Systems and Pipeline: ASME B31 Code Simplified.
    Table of contents
    Chapter 1: Principles
    Chapter 2: Materials
    Chapter 3: Design
    Chapter 4: Fabrication
    Chapter 5: Degradation
    Chapter 6: Inspection
    Chapter 7: Thinning
    Chapter 8: Geometric Defects
    Chapter 9: -----s
    Chapter 10: Creep Damage
    Chapter 11: Overload
    Chapter 12: Failure Analysis
    Chapter 13: Repairs
    APPENDIX: WRC BULLETINS
    INDEX
    Biographical note
    George Antaki is a Fellow of the American Society of Mechanical Engineers. He is a member of the ASME B31 Mechanical Design Technical Committee, the ASME Post-Construction Subcommittee on Repairs and Testing, and the Joint API-ASME Task Group on Fitness-for-Service. Mr. Antaki has extensive field experience in design, inspection, integrity, and retrofit of vessels and piping systems and equipment. He resides in Aiken, South Carolina.
    Back cover copy
    Run-or-repair evaluations for tanks, vessels, piping, and pipelines
    ASME code for operating equipment and systems
    ASME and API rules for structural integrity of equipment and pipelines
    A Complete Guide to ASME Recommended Practices for Assessing, Monitoring, and Maintaining Pressure Vessels and Piping
    Fitness-for-Service and Integrity of Piping Vessels and Tanks provides instruction on the latest ASME recommended practices for inspecting, evaluating, and monitoring pressure vessels and Piping.
    This handy volume annotates and explains ASME code and API inspection and fitness-for-service practices. Presented in a clear, precise manner, this comprehensive guide meticulously explains how stress analysis, materials, engineering, and nondestructive inspection affect fitness-for-service.
    The tools needed to . . .
    Inspect and categorize damage, degradation, and corrosion mechanisms
    Evaluate wall thinning, pitting, -----ing, fatigue, mechanical damage, high-temperature corrosion, and creep
    Develop and implement programs for corrective and predictive maintenance of tanks, vessels, piping, and pipelines
    Select the right repair technique and avoid pitfalls in repair welding and joining
    A COMPREHENSIVE GUIDE TO ASME RECOMMENDED PRACTICES:
    What Causes Failures * Material Defects; Design Errors * Construction Flaws * Corrosion and Damage Mechanisms * Failures In-Service * Inspection Techniques; Maintenance and Risk-Based Inspection Strategies * Failure Margins and Prevention * Margins to Failure * Run-or-Repair Decisions * Repair Techniques
    Re: Rstreng
    Hi
    I just developp an excel spread sheet to calculate Rstreng. This file is in French, just time to translate it in english tjen I will publish it. For information, this is 3 excel sheets the first one is use to fill up pipe data and to calculate for single defect asme and modified asme pressure. The second file is use to fill up defect measurement data, using measurement step and corrosion. The third page is use to generate a repoirt with result and graph as in the Rstreng software. This file allow you to enter up to 700 dsefect meridian and each meridian can contain up to 65536 Points. In this file, I use only corrosion data and not remaining wall thickness. If you are interest to get it, just let me know it.
  7. Re: Rstreng
    i only have rstrength 2011 edition.....here's the link:
    [link Point to another website Only the registered members can access] 4shared)
    or you can use "griwrap excelsheet" from clockspring..
  9. Re: Rstreng
    with thanks
    could you please send me pirsiavash@gmail.com
  10. Re: Rstreng
    with thanks
    ÑÏ: Rstreng
    the link is dead pleas reupload
    Re: Rstreng
    [link Point to another website Only the registered members can access] es gratis, download KAPA software 2014,
  13. Re: Rstreng
    Por favor alguien que me pueda ayudar con el programa rstreng o kapa???? Graciasss
  14. #11
    Re: Rstreng
    amigo, solo ve a la pagina
  16. #12
    Re: Rstreng
    kiefner.com/resource-center/downloads/
