Results 1 to 5 of 5
Thread: PVT help
    PVT help
    Please advise me
    when i prepare fluid model by usiing PVTi , is the input data take as it is from the PVT report or should I adjust the pvt report (Bo,Rs,den,results to the surface conditions used in the separator Thank you in advance.
  3. Re: PVT help
    No. you should take it directly form PVT report without any correction.
    Re: PVT help
    Dear abdulghaffar thank you so much for your help.
  6. Re: PVT help
    You're welcome anytime
    Re: PVT help
    i think you should try to match measured data (as per report) provided it is within quality limits. then for your eclipse (etc) deck you may want to generate pvt tables as per expected surface conditions.
    i would be interested to hear from other people on what experiments they use for generating tables for black oils, volatile oils, condensates etc. would it depend on GOR, presence of gas cap etc. thanks in advance!
    i realise my 0.5 cents probably too late, anyways good luck...
