Results 1 to 10 of 10
Thread: CEN Standards Collection 134/370: CEN TC 51 - Cement & Building Limes
    full list:
    EN 196-1:2005 Methods of testing cement - Part 1: Determination of strength
    EN 196-2:2013 Method of testing cement - Part 2: Chemical analysis of cement
    EN 196-3:2005+A1:2008 Methods of testing cement - Part 3: Determination of setting times and soundness
    CEN/TR 196-4:2007 Methods of testing cement - Part 4: Quantitative determination of constituents
    EN 196-5:2011 Methods of testing cement - Part 5: Pozzolanicity test for pozzolanic cement
    EN 196-6:2010 Methods of testing cement - Part 6: Determination of fineness
    EN 196-7:2007 Methods of testing cement - Part 7: Methods of taking and preparing samples of cement
    EN 196-8:2010 Methods of testing cement - Part 8: Heat of hydration - Solution method
    EN 196-9:2010 Methods of testing cement - Part 9: Heat of hydration - Semi-adiabatic method
    EN 196-10:2006 Methods of testing cement - Part 10: Determination of the water-soluble chromium (VI) content of cement
    EN 197-1:2011 Cement - Part 1: Composition, specifications and conformity criteria for common cements
    EN 197-2:2014 Cement - Part 2: Conformity evaluation
    EN 413-1:2011 Masonry cement - Part 1: Composition, specifications and conformity criteria
    EN 413-2:2005 Masonry cement - Part 2: Test methods
    EN 459-1:2015 Building lime - Part 1: Definitions, specifications and conformity criteria
    EN 459-2:2010 Building lime - Part 2: Test methods
    EN 459-3:2015 Building lime - Part 3: Conformity evaluation
    CEN/TS 12390-9:2006 Testing hardened concrete - Part 9: Freeze-thaw resistance - Scaling
    CR 12793:1997 Measurement of the carbonation depth of hardened concrete
    EN 13282-1:2013 Hydraulic road binders - Part 1: Rapid hardening hydraulic road binders - Composition, specifications and conformity criteria
    EN 13282-2:2015 Hydraulic road binders - Part 2: Normal hardening hydraulic road binders - Composition, specifications and conformity criteria
    EN 13282-3:2015 Hydraulic road binders - Part 3: Conformity evaluation
    EN 13639:2002 Determination of total organic carbon in limestone
    EN 13639:2002/AC:2004 Determination of total organic carbon in limestone
    CR 13933:2000 Masonry cement - Testing for workability (cohesivity)
    EN 14216:2015 Cement - Composition, specifications and conformity criteria for very low heat special cements
    CEN/TR 14245:2014 Cement - Guidelines for the application of EN 197-2 Conformity Evaluation
    EN 14647:2005 Calcium aluminate cement - Composition, specifications and conformity criteria
    EN 14647:2005/AC:2006 Calcium aluminate cement - Composition, specifications and conformity criteria
    CEN/TR 15177:2006 Testing the freeze-thaw resistance of concrete - Internal structural damage
    EN 15368:2008+A1:2010 Hydraulic binder for non-structural applications - Definition, specifications and conformity criteria
    CEN/TR 15678:2008 Concrete - Release of regulated dangerous substances into soil, groundwater and surface water - Test method for new or unapproved constituents of concrete and for production concretes
    CEN/TR 15697:2008 Cement - Performance testing for sulfate resistance - State of the art report
    EN 15743:2010+A1:2015 Supersulfated cement - Composition, specifications and conformity criteria
    CEN/TR 16142:2011 Concrete - A study of the characteristic leaching behaviour of hardened concrete for use in the natural environment
    CEN/TR 16632:2014 Isothermal Conduction Calorimetry (ICC) for the determination of heat of hydration of cement: State of Art Report and Recommendations
    missing:
    EN 459-1:2015 Building lime - Part 1: Definitions, specifications and conformity criteria - missing VE
    EN 459-3:2015 Building lime - Part 3: Conformity evaluation - missing VE
    CR 12793:1997 Measurement of the carbonation depth of hardened concrete - missing
    EN 13282-2:2015 Hydraulic road binders - Part 2: Normal hardening hydraulic road binders - Composition, specifications and conformity criteria - missing VE
    EN 15743:2010+A1:2015 Supersulfated cement - Composition, specifications and conformity criteria - missing A1
    Aug 2015
    Dubai, UAE
    Blog Entries
    4
    Re: CEN standards collection 134/100: CEN TC 51 - Cement & Building Limes
    A small contribution for these missing standards!
    Re: CEN Standards Collection 134/300: CEN TC 51 - Cement & Building Limes
    update:
    EN 196-1:2016 Methods of testing cement - Part 1: Determination of strength - new 2016 version of standard
    EN 459-1:2015 Building lime - Part 1: Definitions, specifications and conformity criteria - added missing standard thanks to amjadmalik75
    EN 459-3:2015 Building lime - Part 3: Conformity evaluation - added missing standard thanks to amjadmalik75
    EN 13282-2:2015 Hydraulic road binders - Part 2: Normal hardening hydraulic road binders - Composition, specifications and conformity criteria - added missing standard thanks to amjadmalik75
    missing list:
    EN 196-10:2016 Methods of testing cement - Part 10: Determination of the water-soluble chromium (VI) content of cement
    CEN/TR 16912:2016 Guidelines for a procedure to support the European standardization of cements
    new links:
    or
    Re: CEN Standards Collection 134/340: CEN TC 51 - Cement & Building Limes
    Same still missing:
    update:
    EN 15743:2010+A1:2015 Supersulfated cement - Composition, specifications and conformity criteria - added missing standard
    missing are:
    new links:
    or
    Re: CEN Standards Collection 134/350: CEN TC 51 - Cement & Building Limes
    update:
    EN 196-10:2016 Methods of testing cement - Part 10: Determination of the water-soluble chromium (VI) content of cement - added missing standard thanx to Amjad Malik
    CEN/TR 16912:2016 Guidelines for a procedure to support the European standardization of cements - added missing standard thanx to Amjad Malik
    missing one now is:
    updated links:
    or
    update:
    added missing standard:
    EN 413-2:2016 Masonry cement - Part 2: Test methods
    the missing are now:
    EN 196-3:2016 Methods of testing cement - Part 3: Determination of setting times and soundness
    CEN/TS 12390-9:2016 Testing hardened concrete - Part 9: Freeze-thaw resistance with de-icing salts - Scaling
    new link:
    Re: CEN Standards Collection 134/370: CEN TC 51 - Cement & Building Limes
    update:
    added missing/new:
    EN 16908:2017 Cement and building lime - Environmental product declarations - Product category rules complementary to EN 15804
    still missing:
    new link:
    update....better quality or EN versions:
    EN 14216:2015 Cement - Composition* specifications and conformity criteria for very low heat special cements
    still missing:
  13. Re: CEN Standards Collection 134/370: CEN TC 51 - Cement & Building Limes
    Thank you very much for the contribution!
  1. Replies: 4
    Last Post: 07-11-2017, 09:02 AM
  2. Replies: 5
    Last Post: 06-08-2017, 06:54 PM
  3. Replies: 9
    Last Post: 06-04-2017, 04:17 AM
  4. Replies: 6
    Last Post: 05-30-2017, 04:18 AM
  5. Replies: 0
    Last Post: 12-23-2016, 03:36 PM
