full list:
EN 932-1:1996 Tests for general properties of aggregates - Part 1: Methods for sampling
EN 932-2:1999 Tests for general properties of aggregates - Part 2: Methods for reducing laboratory samples
EN 932-3:1996 Tests for general properties of aggregates - Part 3: Procedure and terminology for simplified petrographic description
EN 932-3:1996/A1:2003 Tests for general properties of aggregates - Part 3: Procedure and terminology for simplified petrographic description
EN 932-5:2012 Tests for general properties of aggregates - Part 5: Common equipment and calibration
EN 932-5:2012/AC:2014 Tests for general properties of aggregates - Part 5: Common equipment and calibration
EN 932-6:1999 Tests for general properties of aggregates - Part 6: Definitions of repeatability and reproducibility
EN 933-1:2012 Tests for geometrical properties of aggregates - Part 1: Determination of particle size distribution - Sieving method
EN 933-2:1995 Tests for geometrical properties of aggregates - Part 2: Determination of particle size distribution - Test sieves, nominal size of apertures
EN 933-3:2012 Tests for geometrical properties of aggregates - Part 3: Determination of particle shape - Flakiness index
EN 933-4:2008 Tests for geometrical properties of aggregates - Part 4: Determination of particle shape - Shape index
EN 933-5:1998 Tests for geometrical properties of aggregates - Part 5: Determination of percentage of crushed and broken surfaces in coarse aggregate particles
EN 933-5:1998/A1:2004 Tests for geometrical properties of aggregates - Part 5: Determination of percentage of crushed and broken surfaces in coarse aggregate particles
EN 933-6:2014 Tests for geometrical properties of aggregates - Part 6: Assessment of surface characteristics - Flow coefficient of aggregates
EN 933-7:1998 Tests for geometrical properties of aggregates - Part 7: Determination of shell content - Percentage of shells in coarse aggregates
EN 933-8:2012+A1:2015 Tests for geometrical properties of aggregates - Part 8: Assessment of fines - Sand equivalent test
EN 933-9:2009+A1:2013 Tests for geometrical properties of aggregates - Part 9: Assessment of fines - Methylene blue test
EN 933-10:2009 Tests for geometrical properties of aggregates - Part 10: Assessment of fines - Grading of filler aggregates (air jet sieving)
EN 933-11:2009 Tests for geometrical properties of aggregates - Part 11: Classification test for the constituents of coarse recycled aggregate
EN 933-11:2009/AC:2009 Tests for geometrical properties of aggregates - Part 11: Classification test for the constituents of coarse recycled aggregate
EN 1097-1:2011 Tests for mechanical and physical properties of aggregates - Part 1: Determination of the resistance to wear (micro-Deval)
EN 1097-2:2010 Tests for mechanical and physical properties of aggregates - Part 2: Methods for the determination of resistance to fragmentation
EN 1097-3:1998 Tests for mechanical and physical properties of aggregates - Part 3: Determination of loose bulk density and voids
EN 1097-4:2008 Tests for mechanical and physical properties of aggregates - Part 4: Determination of the voids of dry compacted filler
EN 1097-5:2008 Tests for mechanical and physical properties of aggregates - Part 5: Determination of the water content by drying in a ventilated oven
EN 1097-6:2013 Tests for mechanical and physical properties of aggregates - Part 6: Determination of particle density and water absorption
EN 1097-7:2008 Tests for mechanical and physical properties of aggregates - Part 7: Determination of the particle density of filler - Pyknometer method
EN 1097-8:2009 Tests for mechanical and physical properties of aggregates - Part 8: Determination of the polished stone value
EN 1097-9:2014 Tests for mechanical and physical properties of aggregates - Part 9: Determination of the resistance to wear by abrasion from studded tyres - Nordic test
EN 1097-10:2014 Tests for mechanical and physical properties of aggregates - Part 10: Determination of water suction height
EN 1097-11:2013 Tests for mechanical and physical properties of aggregates - Part 11: Determination of compressibility and confined compressive strength of lightweight aggregates
EN 1367-1:2007 Tests for thermal and weathering properties of aggregates - Part 1: Determination of resistance to freezing and thawing
EN 1367-2:2009 Tests for thermal and weathering properties of aggregates - Part 2: Magnesium sulfate test
EN 1367-3:2001 Tests for thermal and weathering properties of aggregates - Part 3 : Boiling test for "Sonnenbrand basalt"
EN 1367-3:2001/AC:2004 Tests for thermal and weathering properties of aggregates - Part 3 : Boiling test for "Sonnenbrand basalt"
EN 1367-4:2008 Tests for thermal and weathering properties of aggregates - Part 4: Determination of drying shrinkage
EN 1367-5:2011 Tests for thermal and weathering properties of aggregates - Part 5: Determination of resistance to thermal shock
EN 1367-6:2008 Tests for thermal and weathering properties of aggregates - Part 6: Determination of resistance to freezing and thawing in the presence of salt (NaCl)
EN 1367-7:2014 Tests for thermal and weathering properties of aggregates - Part 7: Determination of resistance to freezing and thawing of Lightweight aggregates
EN 1367-8:2014 Tests for thermal and weathering properties of aggregates - Part 8: Determination of resistance to disintegration of Lightweight Aggregates
EN 1744-1:2009+A1:2012 Tests for chemical properties of aggregates - Part 1: Chemical analysis
EN 1744-3:2002 Tests for chemical properties of aggregates - Part 3: Preparation of eluates by leaching of aggregates
EN 1744-4:2005 Tests for chemical properties of aggregates - Part 4: Determination of water susceptibility of fillers for bituminous mixtures
EN 1744-5:2006 Tests for chemical properties of aggregates - Part 5: Determination of acid soluble chloride salts
EN 1744-6:2006 Tests for chemical properties of aggregates - Part 6: Determination of the influence of recycled aggregate extract on the initial setting time of cement
EN 1744-7:2012 Tests for chemical properties of aggregates - Part 7: Determination of loss of ignition of Municipal Incinerator Bottom Ash Aggregate (MIBA Aggregate)
EN 1744-8:2012 Tests for chemical properties of aggregates - Part 8: Sorting test to determine metal content of Municipal Incinerator Bottom Ash (MIBA) Aggregates
EN 12620:2002+A1:2008 Aggregates for concrete
EN 13043:2002 Aggregates for bituminous mixtures and surface treatments for roads, airfields and other trafficked areas
EN 13043:2002/AC:2004 Aggregates for bituminous mixtures and surface treatments for roads, airfields and other trafficked areas
EN 13055-1:2002 Lightweight aggregates - Part 1: Lightweight aggregates for concrete, mortar and grout
EN 13055-1:2002/AC:2004 Lightweight aggregates - Part 1: Lightweight aggregates for concrete, mortar and grout
EN 13055-2:2004 Lightweight aggregates - Part 2: Lightweight aggregates for bituminous mixtures and surface treatments and for unbound and bound applications
EN 13139:2002 Aggregates for mortar
EN 13139:2002/AC:2004 Aggregates for mortar
EN 13179-1:2013 Tests for filler aggregate used in bituminous mixtures - Part 1: Delta ring and ball test
EN 13179-2:2000 Tests for filler aggregate used in bituminous mixtures - Part 2: Bitumen number
EN 13242:2002+A1:2007 Aggregates for unbound and hydraulically bound materials for use in civil engineering work and road construction
EN 13383-1:2002 Armourstone - Part 1: Specification
EN 13383-1:2002/AC:2004 Armourstone - Part 1: Specification
EN 13383-2:2002 Armourstone - Part 2: Test methods
EN 13450:2002 Aggregates for railway ballast
EN 13450:2002/AC:2004 Aggregates for railway ballast
missing:
EN 933-8:2012+A1:2015 Tests for geometrical properties of aggregates - Part 8: Assessment of fines - Sand equivalent test - missing A1:2015
or
