here are some BS (IEC/ISO) standards that are not part of CEN
full list:
BS EN 287-1:2011 Qualification test of welders. Fusion welding - Steels
BS 499-1:2009 Welding terms and symbols - Glossary for welding, brazing and thermal cutting
BS 499-1:Supplement:1992 Welding terms and symbols - Supplement. Definitions for electric welding equipment
BS 499-2C:1999 Welding terms and symbols - European arc welding symbols in chart form
BS 807:1955 Specification for spot welding electrodes
BS ISO 857-2:2005 Welding and allied processes. Vocabulary - Soldering and brazing processes and related terms
BS 1140:1993 Specification for resistance spot welding of uncoated and coated low carbon steel
BS 2633:1987 Specification for Class I arc welding of ferritic steel pipework for carrying fluids
BS 2971:1991 Specification for class II arc welding of carbon steel pipework for carrying fluids
BS 3065:2001 Resistance welding. Resistance welding equipment. Mechanical and electrical requirements
BS 4129:1990 Specification for welding primers and weld-through sealants, adhesives and waxes for resistance welding of sheet steel
BS 4204:1989 Specification for flash welding of steel tubes for pressure applications
BS 4215-2:1987 Resistance spot welding electrodes, electrode holders and ancillary equipment - Specification for straight resistance spot welding electrodes
BS 4215-6:1987 Resistance spot welding electrodes, electrode holders and ancillary equipment - Specification for electrode adaptors, female taper 1:10
BS 4215-7:1987 Resistance spot welding electrodes, electrode holders and ancillary equipment - Specification for male electrode caps
BS 4215-15:1990 Resistance spot welding electrodes, electrode holders and ancillary equipment - Specification for insulated pins for use in electrode back-ups
BS 4515-1:2009 Specification for welding of steel pipelines on land and offshore - Carbon and carbon manganese steel pipelines
BS 4515-2:1999 Specification for welding of steel pipelines on land and offshore - Duplex stainless steel pipelines
BS 4570:1985 Specification for fusion welding of steel castings
BS 4677:1984 Specification for arc welding of austenitic stainless steel pipework for carrying fluids
BS 4819-1:1989 Resistance welding water-cooled transformers of the press package and portable types. - Specification for press-package transformers
BS 4819-2:1989 Resistance welding water-cooled transformers of the press-package and portable types. - Specification for portable transformers
BS 4871-3:1985 Specification for approval testing of welders working to approved welding procedures - Arc welding of tube to tube-plate joints in metallic materials
BS 4872-1:1982 Specification for approval testing of welders when welding procedure approval is not required - Fusion welding of steel
BS 4872-2:1976 Specification for approval testing of welders when welding procedure approval is not required - TIG or MIG welding of aluminium and its alloys
BS 6942-2:1989 Design and construction of small kits for oxy-fuel gas welding and allied processes - Specification for kits using refillable gas containers for oxygen and fuel gas
BS 6944:1988 Specification for flash welding of butt joints in ferrous metals (excluding pressure piping applications)
BS 6990:1989 Code of practice for welding on steel pipes containing process fluids or their residuals
BS 7363:1990 Method for bead-on-plate (BOP) test for welds
BS 7608:2014+A1:2015 Guide to fatigue design and assessment of steel products
BS 7670-2:1997 Steel nuts and bolts for resistance projection welding - Specification for welding of weld nuts and weld bolts
BS 7910:2013+A1:2015 Guide to methods for assessing the acceptability of flaws in metallic structures
BS ISO 11745:2010+A1:2015 Brazing for aerospace applications. Qualification test for brazers and brazing operators. Brazing of metallic components
BS ISO 14347:2008 Fatigue. Design procedure for welded hollow-section joints. Recommendations
PD ISO/TR 13392:2014 Health and safety in welding and allied processes. Arc welding fume components
PD ISO/TR 14345:2012 Fatigue. Fatigue testing of welded components. Guidance
BS ISO 14346:2013 Static design procedure for welded hollow-section joints. Recommendations
BS ISO 16338:2013 Welding for aerospace applications. Resistance spot and seam welding
BS ISO 17533:2015 Welding for aerospace applications. Welding information in design documents
PD ISO/TR 18491:2015 Welding and allied processes. Guidelines for measurement of welding energies
PD ISO/TR 18786:2014 Health and safety in welding. Guidelines for risk assessment of welding fabrication activities
BS ISO 22826:2005 Destructive tests on welds in metallic materials. Hardness testing of narrow joints welded by laser and electron beam (Vickers and Knoop hardness tests)
BS ISO 24394:2008+A1:2012 Welding for aerospace applications. Qualification test for welders and welding operators. Fusion welding of metallic components
PD ISO/TR 28821:2012 Gas welding equipment. Hose connections for equipment for welding, cutting and allied processes. Listing of connections which are either standardised or in common use
BS EN 50444:2008 Basic standard for the evaluation of human exposure to electromagnetic fields from equipment for arc welding and allied processes
BS EN 50445:2008 Product family standard to demonstrate compliance of equipment for resistance welding, arc welding and allied processes with the basic restrictions related to human exposure to electromagnetic fields (0 Hz - 300 GHz)
BS EN 50504:2008 Validation of arc welding equipment
BS EN 50505:2008 Basic standard for the evaluation of human exposure to electromagnetic fields from equipment for resistance welding and allied processes
BS EN 60974-1:2012 Arc welding equipment - Welding power sources
BS EN 60974-2:2013 Arc welding equipment - Liquid cooling systems
BS EN 60974-3:2014 Arc welding equipment - Arc striking and stabilizing devices
BS EN 60974-4:2011 Arc welding equipment - Periodic inspection and testing
BS EN 60974-5:2013 Arc welding equipment - Wire feeders
BS EN 60974-6:2016 Arc welding equipment - Limited duty equipment
BS EN 60974-7:2013 Arc welding equipment - Torches
BS EN 60974-8:2009 Arc welding equipment - Gas consoles for welding and plasma cutting systems
BS EN 60974-9:2010 Arc welding equipment - Installation and use
BS EN 60974-10:2014+A1:2015 Arc welding equipment - Electromagnetic compatibility (EMC) requirements
BS EN 60974-11:2010 Arc welding equipment - Electrode holders
BS EN 60974-12:2011 Arc welding equipment - Coupling devices for welding cables
BS EN 60974-13:2011 Arc welding equipment - Welding clamp
BS EN 62135-1:2015 Resistance welding equipment - Safety requirements for design, manufacture and installation
BS EN 62135-2:2015 Resistance welding equipment - Electromagnetic compatibility (EMC) requirements
missing:
BS 807:1955 Specification for spot welding electrodes - missing
BS 4215-2:1987 Resistance spot welding electrodes, electrode holders and ancillary equipment - Specification for straight resistance spot welding electrodes - missing
BS 4677:1984 Specification for arc welding of austenitic stainless steel pipework for carrying fluids - missing
BS 4819-1:1989 Resistance welding water-cooled transformers of the press package and portable types. - Specification for press-package transformers - missing
BS 7608:2014+A1:2015 Guide to fatigue design and assessment of steel products - missing A1
BS ISO 11745:2010+A1:2015 Brazing for aerospace applications. Qualification test for brazers and brazing operators. Brazing of metallic components - missing A1
PD ISO/TR 18786:2014 Health and safety in welding. Guidelines for risk assessment of welding fabrication activities - missing
BS EN 60974-6:2016 Arc welding equipment - Limited duty equipment - missing valid edition
BS EN 60974-10:2014+A1:2015 Arc welding equipment - Electromagnetic compatibility (EMC) requirements - missing valid edition
BS EN 62135-2:2015 Resistance welding equipment - Electromagnetic compatibility (EMC) requirements - missing valid edition
or
