Please share for me the book Marine Painting Manual.
Thanks so much !
Thanks so much !
I can only guess that you are looking for the Marine Painting Manual - Berendsen 1989, put more exact info next time.
Also...
ABS - NACE - GUIDANCE NOTES ON The Inspection, Maintenance and Application of Marine Coating Systems 3rd 2007
ABS - Guidance Notes on the Application and Maintenance of Marine Coating Systems 2nd Ed. 2004
Thanks Marty.
The third Article "ABS - Guidance Notes on the Application and Maintenance of Marine Coating Systems." appears in error as connection to the url is not being established. Can this be uploaded on 4shared.
Terrific post
Thanks a lot indeed
Dear Marty.
The problem is resolved.
Article "ABS - Guidance Notes on the Application and Maintenance of Marine Coating Systems." is downloaded.
Please find link to EFC 55 "Corrosion Under Insulation (CUI) Guidelines" This is the 2016 revised edition from Woodhead Publishing. I just got it half an hour back.
thank for sharing
Please my friend* can you upload again? Please!!! Thanks in advanced!!
Hi Sajid Ali Khan,
could you please share the files again?
I get the error:
"The file link that you requested is not valid."
