full list:
EN 733:1995 End-suction centrifugal pumps, rating with 10 bar with bearing bracket - Nominal duty point, main dimensions, designation system
EN 734:1995 Side channel pumps PN 40 - Nominal duty point, main dimensions, designation system
EN 735:1995 Overall dimensions of rotodynamic pumps - Tolerances
EN 809:1998+A1:2009 Pumps and pump units for liquids - Common safety requirements
EN 809:1998+A1:2009/AC:2010 Pumps and pump units for liquids - Common safety requirements
EN 1829-1:2010 High pressure water jet machines - Safety requirements - Part 1: Machines
EN 1829-2:2008 High-pressure water jet machines - Safety requirements - Part 2: Hoses, hose lines and connectors
EN 1829-2:2008/AC:2011 High-pressure water jet machines - Safety requirements - Part 2: Hoses, hose lines and connectors
EN ISO 2858:2010 End-suction centrifugal pumps (rating 16 bar) - Designation, nominal duty point and dimensions (ISO 2858:1975)
EN ISO 3661:2010 End-suction centrifugal pumps - Baseplate and installation dimensions (ISO 3661:1977)
EN ISO 5198:1998 Centrifugal, mixed flow and axial pumps - Code for hydraulic performance tests - Precision class (ISO 5198:1987)
EN ISO 5199:2002 Technical specifications for centrifugal pumps - Class II (ISO 5199:2002)
EN ISO 9905:1997 Technical specifications for centrifugal pumps - Class I (ISO 9905:1994)
EN ISO 9905:1997/AC:2006 Technical specifications for centrifugal pumps - Class I (ISO 9905:1994)
EN ISO 9905:1997/A1:2011 Technical specifications for centrifugal pumps - Class I - Amendment 1 (ISO 9905:1994/AMD 1:2011)
EN ISO 9906:2012 Rotodynamic pumps - Hydraulic performance acceptance tests - Grades 1, 2 and 3 (ISO 9906:2012)
EN ISO 9908:1997 Technical specifications for centrifugal pumps - Class III (ISO 9908:1993)
EN ISO 9908:1997/A1:2011 Technical specifications for centrifugal pumps - Class III - Amendment 1 (ISO 9908:1993/AMD 1:2011)
EN 12157:1999 Rotodynamic pumps - Coolant pumps units for machine tools - Nominal flow rate, dimensions
EN 12162:2001+A1:2009 Liquid pumps - Safety requirements - Procedure for hydrostatic testing
EN 12262:1998 Rotodynamic pumps - Technical documents - Terms, delivery range, layout
EN 12483:1999 Liquid pumps - Pump units with frequency inverters - Guarantee and compatibility tests
EN 12756:2000 Mechanical seals - Principal dimensions, designation and material codes
CEN/TR 13930:2009 Rotodynamic pumps - Design of pump intakes - Recommendations for installation of pumps
CEN/TR 13930:2009/AC:2010 Rotodynamic pumps - Design of pump intakes - Recommendation for installation of pumps
CEN/TR 13931:2009 Rotodynamic pumps - Forces and moments on flanges - Centrifugal, mixed flow and axial flow horizontal and vertical shafts pumps
CEN/TR 13931:2009/AC:2010 Rotodynamic pumps - Forces and moments on flanges - Centrifugal, mixed flow and axial flow horizontal and vertical shafts pumps
CEN/TR 13932:2009 Rotodynamic pumps - Recommendations for fitting of inlet and outlet on piping
EN 13951:2012 Liquid pumps - Safety requirements - Agrifoodstuffs equipment; Design rules to ensure hygiene in use
EN 14343:2005 Rotary positive displacement pumps - Performance tests for acceptance
EN 14343:2005/AC:2008 Rotary positive displacement pumps - Performance tests for acceptance
EN ISO 14414:2015 Pump system energy assessment (ISO/ASME 14414:2015)
EN ISO 14847:1999 Rotary positive displacement pumps - Technical requirements (ISO 14847:1999)
EN ISO 15783:2003 Seal-less rotodynamic pumps - Class II - Specification (ISO 15783:2002)
EN ISO 15783:2003/A1:2008 Seal-less rotodynamic pumps - Class II - Specification - Amendment 1 (ISO 15783:2003/Amd 1:2008)
EN 16297-1:2012 Pumps - Rotodynamic pumps - Glandless circulators - Part 1: General requirements and procedures for testing and calculation of energy efficiency index (EEI)
EN 16297-2:2012 Pumps - Rotodynamic pumps - Glandless circulators - Part 2: Calculation of energy efficiency index (EEI) for standalone circulators
EN 16297-3:2012 Pumps - Rotodynamic pumps - Glandless circulators - Part 3: Energy efficiency index (EEI) for circulators integrated in products
EN ISO 16330:2003 Reciprocating positive displacement pumps and pump units - Technical requirements (ISO 16330:2003)
EN 16644:2014 Pumps - Rotodynamic pumps - Glandless circulators having a rated power input not exceeding 200 W for heating installations and domestic hot water installations - Noise test code (vibro-acoustics) for measuring structure- and fluid-borne noise
EN 16752:2015 Centrifugal pumps - Test procedure for seal packings
EN ISO 17769-1:2012 Liquid pumps and installation - General terms, definitions, quantities, letter symbols and units - Part 1: Liquid pumps (ISO 17769-1:2012)
EN ISO 17769-2:2012 Liquid pumps and installation - General terms, definitions, quantities, letter symbols and units - Part 2: Pumping System (ISO 17769-2:2012)
EN ISO 20361:2015 Liquid pumps and pump units - Noise test code - Grades 2 and 3 of accuracy (ISO 20361:2015)
we missing these ones:
CEN/TR 13930:2009/AC:2010 Rotodynamic pumps - Design of pump intakes - Recommendation for installation of pumps - missing AC
CEN/TR 13931:2009/AC:2010 Rotodynamic pumps - Forces and moments on flanges - Centrifugal, mixed flow and axial flow horizontal and vertical shafts pumps - missing AC
EN 16644:2014 Pumps - Rotodynamic pumps - Glandless circulators having a rated power input not exceeding 200 W for heating installations and domestic hot water installations - Noise test code (vibro-acoustics) for measuring structure- and fluid-borne noise - missing valid edition
or
