Results 1 to 5 of 5
Thread: Organizing huge eclipse simulation runs
  1. Organizing huge eclipse simulation runs
    Hi all, I am about to start writing my thesis and it involves Eclipse 100. I have base case and probably another hundred runs.
    I am wondering if there is efficient way of keeping all the runs in way that is easy to retrieve and manage them.
    Thanks in advance
    Hi teddy the trick starts by naming them a proper way using underscores and right taxonomy HM for history match INIT for initialization run etc. then brief 4/6 letters for run conditions CONS for constrained run for instance. ..
    Then keep an excel spreadsheet with a table when you report in one column the file name i.e. data deck and on the other column a brief description.
    Hope that's what you were looking for.
    Kader
    Envoy&#233; de mon SM-A500F en utilisant Tapatalk
    Run_00_INIT
    RUN_00_INIT_UNCONS RUN_01_HM_FLTMOD if you modified some faults RUN_01_HM_PERMOD if you modified permeability etc actually the name has to guide you to the content.
  7. Re: Organizing huge eclipse simulation runs
    Thanks Kader
  1. ECLIPSE batch file to creat queue runs
    By MohamedL in forum Reservoir
    Last Post: 06-05-2014, 09:26 AM
  2. Organizing SP3D Project Team
    By hbili in forum Planning & Project Management
    Last Post: 04-18-2014, 10:13 AM
  3. ECLIPSE simulation
    By cwmhafiz in forum Reservoir
    Last Post: 02-25-2013, 01:05 PM
  4. DST simulation in Eclipse
    By arm in forum Reservoir
    Last Post: 02-05-2013, 01:08 PM
