6 are missing:
EN 19:2002 Industrial valves - Marking of metallic valves
EN 558:2008+A1:2011 Industrial valves - Face-to-face and centre-to-face dimensions of metal valves for use in flanged pipe systems - PN and Class designated valves
EN 593:2009+A1:2011 Industrial valves - Metallic butterfly valves
EN 736-1:1995 Valves - Terminology - Part 1: Definition of types of valves
EN 736-2:1997 Valves - Terminology - Part 2: Definition of components of valves
EN 736-3:2008 Valves - Terminology - Part 3: Definition of terms
EN 1074-1:2000 Valves for water supply - Fitness for purpose requirements and appropriate verification tests - Part 1: General requirements
EN 1074-2:2000 Valves for water supply - Fitness for purpose requirements and appropriate verification tests - Part 2: Isolating valves
EN 1074-2:2000/A1:2004 Valves for water supply - Fitness for purpose requirements and appropriate verification tests - Part 2: Isolating valves
EN 1074-3:2000 Valves for water supply - Fitness for purpose requirements and appropriate verification tests - Part 3: Check valves
EN 1074-4:2000 Valves for water supply - Fitness for purpose requirements and appropriate verification tests - Part 4: Air valves
EN 1074-5:2001 Valves for water supply - Fitness for purpose requirements and appropriate verification tests - Part 5: Control valves
EN 1074-6:2008 Valves for water supply - Fitness for purpose requirements and appropriate verification tests - Part 6: Hydrants
EN 1171:2015 Industrial valves - Cast iron gate valves - missing VE
EN 1267:2012 Industrial valves - Test of flow resistance using water as test fluid
EN 1349:2009 Industrial process control valves
EN 1503-1:2000 Valves - Materials for bodies, bonnets and covers - Part 1: Steels specified in European Standards
EN 1503-2:2000 Valves - Materials for bodies, bonnets and covers - Part 2: Steels other than those specified in European Standards
EN 1503-3:2000 Valves - Materials for bodies, bonnets and covers - Part 3: Cast irons specified in European Standards
EN 1503-3:2000/AC:2001 Valves - Materials for bodies, bonnets and covers - Part 3: Cast irons specified in European Standards
EN 1503-4:2002 Valves - Materials for bodies, bonnets and covers - Part 4: Copper alloys specified in European Standards
EN 1983:2013 Industrial valves - Steel ball valves
EN 1984:2010 Industrial valves - Steel gate valves
EN ISO 4126-1:2013 Safety devices for protection against excessive pressure - Part 1: Safety valves (ISO 4126-1:2013)
EN ISO 4126-2:2003 Safety devices for protection against excessive pressure - Part 2: Bursting disc safety devices (ISO 4126-2:2003)
EN ISO 4126-2:2003/AC:2006 Safety devices for protection against excessive pressure - Part 2: Bursting disc safety devices (ISO 4126-2:2003)
EN ISO 4126-3:2006 Safety devices for protection against excessive pressure - Part 3: Safety valves and bursting disc safety devices in combination (ISO 4126-3:2006)
EN ISO 4126-4:2013 Safety devices for protection against excessive pressure - Part 4: Pilot-operated safety valves (ISO 4126-4:2013)
EN ISO 4126-5:2013 Safety devices for protection against excessive pressure - Part 5: Controlled safety pressure relief systems (CSPRS) (ISO 4126-5:2013)
EN ISO 4126-6:2014 Safety devices for protection against excessive pressure - Part 6: Application, selection and installation of bursting disc safety devices (ISO 4126-6:2014)
EN ISO 4126-7:2013 Safety devices for protection against excessive pressure - Part 7: Common data (ISO 4126-7:2013)
EN ISO 5210:1996 Industrial valves - Multi-turn valve actuator attachments (ISO 5210:1991)
EN ISO 5211:2001 Industrial valves - Part-turn actuator attachments (ISO 5211:2001)
EN ISO 10434:2004 Bolted bonnet steel gate valves for the petroleum, petrochemical and allied industries (ISO 10434:2004)
EN ISO 10497:2010 Testing of valves - Fire type-testing requirements (ISO 10497:2010)
EN 12266-1:2012 Industrial valves - Testing of metallic valves - Part 1: Pressure tests, test procedures and acceptance criteria - Mandatory requirements
EN 12266-2:2012 Industrial valves - Testing of metallic valves - Part 2: Tests, test procedures and acceptance criteria - Supplementary requirements
EN 12288:2010 Industrial valves - Copper alloy gate valves
EN 12334:2001 Industrial valves - Cast iron check valves
EN 12334:2001/A1:2004 Industrial valves - Cast iron check valves
EN 12334:2001/AC:2002 Industrial valves - Cast iron check valves
EN 12351:2010 Industrial valves - Protective caps for valves with flanged connections
EN 12516-1:2014 Industrial valves - Shell design strength - Part 1: Tabulation method for steel valve shells - missing VE
EN 12516-2:2014 Industrial valves - Shell design strength - Part 2: Calculation method for steel valve shells - missing VE
EN 12516-3:2002 Valves - Shell design strength - Part 3: Experimental method
EN 12516-3:2002/AC:2003 Valves - Shell design strength - Part 3: Experimental method
EN 12516-4:2014 Industrial valves - Shell design strength - Part 4: Calculation method for valve shells manufactured in metallic materials other than steel - missing VE
EN 12567:2000 Industrial valves - Isolating valves for LNG - Specification for suitability and appropriate verification tests
EN 12569:1999 Industrial valves - Valves for chemical and petrochemical process industry - Requirements and tests
EN 12569:1999/AC:2000 Industrial valves - Valves for chemical and petrochemical process industry - Requirements and tests
EN 12570:2000 Industrial valves - Method for sizing the operating element
EN 12627:1999 Industrial valves - Butt welding ends for steel valves
EN 12760:1999 Valves - Socket welding ends for steel valves
EN 12982:2009 Industrial valves - End-to-end and centre-to-end dimensions for butt welding end valves
EN 13397:2001 Industrial valves - Diaphragm valves made of metallic materials
EN 13547:2013 Industrial valves - Copper alloy ball valves
EN 13709:2010 Industrial valves - Steel globe and globe stop and check valves
EN 13774:2013 Valves for gas distribution systems with maximum operating pressure less than or equal to 16 bar - Performance requirements
EN 13789:2010 Industrial valves - Cast iron globe valves
EN 14141:2013 Valves for natural gas transportation in pipelines - Performance requirements and tests
EN 14341:2006 Industrial valves - Steel check valves
EN 15081:2007 Industrial valves - Mounting kits for part-turn valve actuator attachment
EN 15389:2008 Industrial valves - Performance characteristics of thermoplastic valves when used as construction products
EN 15714-1:2009 Industrial valves - Actuators - Part 1: Terminology and definitions
EN 15714-2:2009 Industrial valves - Actuators - Part 2: Electric actuators for industrial valves - Basic requirements
EN 15714-3:2009 Industrial valves - Actuators - Part 3: Pneumatic part-turn actuators for industrial valves - Basic requirements
EN 15714-4:2009 Industrial valves - Actuators - Part 4: Hydraulic part-turn actuators for industrial valves - Basic requirements
EN ISO 15848-1:2015 Industrial valves - Measurement, test and qualification procedures for fugitive emissions - Part 1: Classification system and qualification procedures for type testing of valves (ISO 15848-1:2006)
EN ISO 15848-2:2015 Industrial valves - Measurement, test and qualification procedures for fugitive emissions - Part 2: Production acceptance test of valves (ISO 15848-2:2006)
EN ISO 16135:2006 Industrial valves - Ball valves of thermoplastics materials (ISO 16135:2006)
EN ISO 16136:2006 Industrial valves - Butterfly valves of thermoplastics materials (ISO 16136:2006)
EN ISO 16137:2006 Industrial valves - Check valves of thermoplastics materials (ISO 16137:2006)
EN ISO 16138:2006 Industrial valves - Diaphragm valves of thermoplastics materials (ISO 16138:2006)
EN ISO 16139:2006 Industrial valves - Gate valves of thermoplastics materials (ISO 16139:2006)
EN 16722:2015 Industrial valves - End-to-end and centre-to-end dimensions for valves with threaded ends - missing
EN ISO 17292:2015 Metal ball valves for petroleum, petrochemical and allied industries (ISO 17292:2015) - missing VE
EN ISO 21787:2006 Industrial valves - Globe valves of thermoplastics materials (ISO 21787:2006)
EN 26553:1991 Automatic steam traps - Marking (ISO 6553:1980)
EN 26554:1991 Flanged automatic steam traps - Face-to-face dimensions (ISO 6554:1980)
EN 26704:1991 Automatic steam traps - Classification (ISO 6704:1982)
EN 26948:1991 Automatic steam traps - Production and performance characteristic tests (ISO 6948:1981)
EN 27841:1991 Automatic steam traps - Determination of steam loss - Test methods (ISO 7841:1988)
EN 27842:1991 Automatic steam traps - Determination of discharge capacity - Test methods (ISO 7842:1988)
EN 28233:1990 Thermoplastics valves - Torque - Test method (ISO 8233:1988)
EN 28659:1990 Thermoplastics valves - Fatigue strength - Test method (ISO 8659:1989)
or
