[h=Examples of problems and solutions for calculation and selection of pipelines:]2[/h][h=Example No. 1]4[/h]What are the head losses for local resistances in horizontal pipeline having diameter of 20 x 4 mm, through which water is pumped from open reservoir to reactor with pressure of 1.8 bar? Distance between reservoir and reactor is 30 m. Water flow rate is 90 m3/h. Total head equals to 25 m. Friction coefficient is taken equal to 0.028.
Solution:
Water flow velocity in pipeline equals to:
w=(4·Q) / (Ï€·d2) = ((4·90) / (3,14·[0,012]2))·(1/3600) = 1,6 m/s
We find head friction losses in the pipeline:
HТ = (λ·l) / (dÑ·[w2/(2·g)]) = (0,028·30) / (0,012·[1,6]2) / ((2·9,81)) = 9,13 m
Total losses are:
hп = H - [(p2-p1)/(Ï·g)] - Hг = 25 - [(1,8-1)·105)/(1000·9,81)] - 0 = 16,85 m
Losses on local resistance fall within:
16,85-9,13=7,72 m
[h=Example No. 2]4[/h]Water is pumped by centrifugal pump across horizontal pipeline at velocity of 1.5 m/s. Total created head equals to 7 m. What is the pipeline maximal length, if water is taken from open reservoir, pumped across horizontal pipeline with one gate valve and two 90° elbows and flows out from pipe to another reservoir? Pipeline diameter equals to 100 mm. Relative roughness is taken equal to 4·10-5.
Solution:
For pipe with diameter of 100 mm coefficients of local resistances will equal to:
For 90° elbow – 1.1; gate valve – 4.1; pipe outlet – 1.
Then we determine value of velocity head:
w2 / (2·g) = 1,52 / (2·9,81) = 0,125 m
Head losses for local resistances will equal to:
∑ζМС · [w2/(2·g)] = (2·1,1+4,1+1) · 0,125 = 0,9125 m
We find total head losses for friction resistance and local resistances from the formula of the pump total head (geometrical lift head under these conditions equals to 0):
hп = H - (p2-p1)/(Ï·g) - Hг = 7 - ((1-1)·105)/(1000·9,81) - 0 = 7 m
Then friction head losses will amount to:
7-0,9125 = 6,0875 m
We calculate value of the Reynolds number for the flow in the pipeline (water dynamic viscosity is taken as 1·10-3 Pa·s, and density – 1,000 kg/m3):
Re = (w·dÐ*·Ï)/μ = (1,5·0,1·1000)/(1·10-3) = 150000
In accordance with this number using the table we calculate a friction coefficient (the arithmetic formula is selected on the principle that value Re falls within the range of 2,320<Re<10/e, corresponding to laminar flow):
λ = 0,316/Re0,25 = 0,316/1500000,25 = 0,016
We express and find a maximal pipeline length from the formula of head friction losses:
l = (Hоб·dÑ) / (λ·[w2/(2g)]) = (6,0875·0,1) / (0,016·0,125) = 304,375 m
[h=Example No. 3]4[/h]The pipeline with the inside diameter of 42 mm is given. It is connected to the water pump with flow rate of 10 m3/h and creating head of 12 m. Temperature of the pumped medium is 20° C. Pipeline configuration is given in the figure below. It is necessary to calculate the head losses and check whether this pump is capable of pumping water at pipeline set parameters. Absolute roughness of pipes is taken as equal to 0.15 mm.
Solution:
We calculate the velocity of the fluid flow in the pipeline:
w = (4·Q) / (Ï€·d2) = (4·10) / (3,14·0,0422)·1/3600 = 2 m/s
Velocity head corresponding to the found velocity will equal to:
w2/(2·g) = 22/(2·9,81) = 0,204 m
Friction coefficient should be found before the calculation of friction losses in pipes. In the first place we determine pipe relative roughness:
e = Δ/dÐ* = 0,15/42 = 3,57·10-3 mm
Reynolds criterion for water flow in the pipeline (water dynamic viscosity at 20° C is 1·10-3 Pa·s, and density is 998 kg/m3):
Re = (w·dÐ*·Ï) / μ = (2·0,042·998) / (1·10-3) = 83832
We find out the water flow mode:
10/e = 10/0,00357 = 2667560/e = 560/0,00357 = 156863
The found value of Reynolds criterion falls within the range of 2667<83,832<156,863 (10/e < Re < 560/e), hence, friction coefficient should be calculated by the following formula:
λ=0,11·(e+68/Re)0,25 = 0,11·(0,00375+68/83832)0,25 = 0,0283
Head friction losses in the pipeline will equal to:
HТ = (λ·l)/dÑ · [w2/(2·g)] = (0,0283·(15+6+2+1+6+5))/0,042 · 0,204 = 4,8 m
Then it is necessary to calculate head losses for local resistances. It is followed from the pipeline diagram that local resistances are represented by two gate valves, four rectangular elbows and one pipe outlet.
Tables do not contain values of coefficient of local resistances for normal gate valves and rectangular elbows with pipe diameter of 42 mm, so we will use one of the methods of approximate calculation of values we are interested in.
We take table values of coefficients of local resistances of normal gate valve for diameters of 40 and 80 mm. We assume that plot of values of coefficients represents straight line in this range. We set up and solve system of equations in order to find a plot of dependence of the local resistance coefficient on the pipe diameter:
[table] align="center" style="color: rgb(0, 0, 0); font-family: Verdana; font-size: 14px; line-height: 21px; background-color: rgb(180, 216, 210)"
| rowspan="2" style="line-height: 1.5" | {
| style="line-height: 1.5" | 4,9 = a·40+b
| rowspan="2" style="line-height: 1.5" | =
| style="line-height: 1.5" | a = -0,0225
| style="line-height: 1.5" | 4 = a·80+b
| style="line-height: 1.5" | b = 5,8
[/table]
Sought equation has the view:
ζ = -0,0225·d+5,8
With diameter of 42 mm local resistance coefficient will equal to:
ζ = -0,0225·42+5,8 = 4,855
Similarly we find the value of local resistance coefficient for rectangular elbow. We take table values for diameters of 37 and 50 mm and solve system of equations, making similar assumption on the nature of plot at this section:
| style="line-height: 1.5" | 1,6=a·37+b
| style="line-height: 1.5" | a = -0,039
| style="line-height: 1.5" | 1,1=a·50+b
| style="line-height: 1.5" | b = 3,03
[/table]
ζ = -0,039·d+3,03
ζ = -0,039·42+3,03 = 1,392
For pipe outlet local resistance coefficient is taken as equal to one.
∑ζМС · [w2/(2g)] = (2·4,855+4·1,394+1) · 0,204 = 3,3 m
Total head losses in the system will equal to:
4,8+3,3 = 8,1 m
According to the data obtained we conclude that this pump is suitable for water pumping through this pipeline, as the head, it creates, is larger than total head losses in the system, and fluid flow velocity stay within the optimum margin.
[h=Example No. 4]4[/h]Section of straight horizontal pipeline with inside diameter of 300 mm was subjected to repair by way of replacing 10 m long pipe section with the inside diameter of 215 mm. The total length of pipeline section under repair is 50 m. Section to be replaced is 18 m away from the beginning. Water flows at 20°C at velocity 1.5 m/s though the pipeline. I is necessary to find out how hydraulic resistance of the pipeline section under repair will change. Friction coefficients for pipes with diameter of 300 and 215 mm are taken equal to 0.01 and 0.012 correspondingly.
Solution:
Initial pipeline created head loss only for fluid friction with walls during pumping. Replacement of the pipe section resulted in occurrence of two local resistances (abrupt contraction and abrupt expansion of passage conduit), and section with changed pipe diameter, where friction losses will be different. The remaining pipeline section was not changed and, consequently, can not be considered as part of this problem.
We calculate the pipeline water flow rate:
Q = (Ï€·d²) / 4·w = (3,14·0,3²) / 4·1,5 = 0,106 m³/s
As the flow rate does not change throughout pipeline length, we can determine the flow velocity on the pipe section subjected to repair:
w = (4·Q) / (Ï€·d²) = (4·0,106) / (3,14·0,215²) = 2,92 m/s
The obtained value of the flow velocity in the pipe replaced section stay within the optimal range.
In order to determine the local resistance coefficient firstly we calculate Reynolds criterion for different diameters of pipes and ratio of cross-sectional areas of these pipes. Reynolds criterion for pipe with diameter of 300 mm (water dynamic viscosity at 20° C is 1·10-3 Pa·s, and density – 998 kg/m3):
e = (w·dÐ*·Ï) / μ = (1,5·0,3·1000) / (1·10-3) = 450000
Reynolds criterion for pipe with diameter of 215 mm (water dynamic viscosity at 20° C is 1·10-3 Pa·s, and density – 998 kg/m3):
Re = (w·dÐ*·Ï) / μ = (1,5·0,215·1000) / (1·10-3) = 322500
Ratio of pipe cross-sectional areas equals to:
((Ï€·d1²)/4) / ((Ï€·d2²)/4) = 0,215² / 0,3² =5,1
Using the tables we will find values of coefficients of local resistances, rounded the ratio of areas to 5. For sudden expansion it will equal to 0.25, and for sudden contraction will also equal to 0.25.
∑ζМС·[w²/(2g)] = 0,25·[1,5²/(2·9,81)] + 0,25·[2,92²/(2·9,81)] = 0,137 m
Now we calculate friction losses in replaced pipeline section for initial and new pipe sections. For pipe with diameter of 300 mm they will equal to:
HТ = (λ·l)/dÑ · [w²/(2g)] = (0,01·10)/0,3 · [1,5²/(2·9,81)] = 0,038 m
For pipe with diameter of 215 mm:
HТ = (λ·l)/dÑ · [w²/(2g)] = (0,012·10)/0,215 · 2,92²/(2·9,81) = 0,243 m
Therefrom we conclude that friction losses in the pipeline will increase by:
0,243-0,038 = 0,205 m
Total increase of friction losses in the pipeline will equal to:
0,205+0,137 = 0,342 m
