Several times I tried to find API 613 2003 (R2007), Special Purpose Gear Units for Petroleum, Chemical and Gas Industry Services, Fifth Edition.
I failed to identify it in this forum or in other place. Would somebody post it?
Thank you!
Thank you!
API 613 5th
Thank you so much, Marty Thomson.
I wish I could help others as you do.
Dear Marty
You have the API 550, I need the latest edition or if is obsolete.
Thanks in advance.
duplicate, see below
550 is a historical doc only - these were the sections
From the API Publications Catalog 2015 in the Historical List
550 Installation of Refinery Instruments and Control Systems, 1st ed.– 4th ed.
Part I–Process Instrumentation and Control
Section 1, Flow, 3rd ed. 1974, 4th ed. 1986
Section 2, Level, 4th ed. 1980
Section 3, Temperature, 3rd ed. 1965, 4th ed. 1980
Section 4, Pressure, 3rd ed. 1974, 4th ed. 1980
Section 5, Controllers and Control Systems, 3rd ed. 1977, 4th ed. 1985
Section 6, Control Valves and Accessories, 3rd ed. 1976, 4th ed. 1985
Section 7, Transmissions Systems, 3rd ed. 1974
Section 8, Seals, Purges, and Winterizing, 3rd ed. 1974, 4th ed. 1980
Section 9, Air Supply Systems, 3rd ed. 1974, 4th ed. 1980
Section 10, Hydraulic Systems, 3rd ed. 1974, 4th ed. 1980
Section 11, Electrical Power Supply, 3rd ed. 1981
Section 12, Control Centers, 3rd ed. 1977
Section 13, Alarms and Protective Devices, 3rd ed. 1976, 4th ed. 1985
Section 14, Process Computer Systems, 1st ed. 1982
550 Part II–Process Stream Analyzers 3rd ed. is 1977 with old sections 14-21, I do not have any 4th ed.
Section 1, Analyzers, 4th ed. 1985
Section 2, Process Chromatographs, 4th ed. 1981
Section 4, Moisture Analyzers, 4th ed. 1983
Section 5, Oxygen Analyzers, 4th ed. 1983
Section 6, Analyzers for the Measurement of Sulfur and Its Components, 4th ed. 1984
Section 7, Electrochemical Liquid Analyzers, 4th ed. 1984
Section 9, Water Quality Analyzers, 4th ed. 1984
Section 10, Area Safety Monitors, 4th ed. 1983
550 Part III, Fired Heaters and Inert Gas Generators, 2nd ed. 1977, 3rd ed. 1985
550 Part IV, Installation of Refinery Instruments and Control System, 1st ed. 1975, 2nd ed. 1984
API RP 550 P1-1965 manual on installation of refinery instruments and control systems - part I - process instrumentation and control
[replaced by: api rp 551, api rp 552, api rp 553, api rp 554, api rp 554]
API RP 550 P2-1977 manual on installation of refinery instruments and control systems part II - process stream analyzers
[superseded by: api rp 555, api api 555]
API RP 550 P3-1985 manual on installation of refinery instruments and control systems part III - fired heaters and inert gas generators
[replaced by: api rp 556]
API RP 550 P4-1984 manual on installation of refinery instruments and control systems part IV - steam generators
[maybe replaced by api standard 611, api standard 612]
API 557 is on advanced control systems
There are many sections here...[link Point to another website Only the registered members can access]
like
This file is needed right here the most, it is part 1
Please, whoever has access, download and post here. I will post what I have tomorrow. I have parts 2, 3, 4. We need a complete part 1, I have only a few sections there.
Thanks very much Marty
These are the sections that I have, if you have newer or more complete, please share
API RP 550 Part I - Section 2 - Level - 3rd Ed. 1974 missing page 4
API RP 550 Part I - Section 4 - Flow - 4th Ed. 1980
API RP 550 Part I - Section 6 - Control valves and Accessories - 4th Ed. 1985 missing contents
API RP 550 Part I - Section 11 - Electrical Power Supply - 3rd Ed. 1981
API RP 550 Part II - Process Steam Analyzers - Sections 14-21 - 3rd Ed. 1977
someone please post 4th edition with new section numbers
