Results 1 to 1 of 1
Thread: Help required for determining for Code Stress in Caesar ii : Code: ASME 31.1
  1. Help required for determining for Code Stress in Caesar ii : Code: ASME 31.1
    My issue:
    1. Pls refer the attached file "1.Node" so that you may get the idea of the system. - It is a plain piping system (OD=168.3) anchored at Node 10. with no temp./pressure. Only self weight acts causing bending and torsion.
    2. Pls refer the stress "2. Stress table".
    I have doubt in Code stress
    **At node 10 & 18:
    Node18:
    Bending: 1552.8kPA, torsion: 78.8kPa, Maximum Stress Intensity = ((1552.8^2)+4*(78.8^2))^0.5=1560.8kPA
    Code stress = same as Maximum Stress Intensity since because SIF =1 ? Am i right.
    **At node 18:
    Maximum stress intensity = (435^2+4*(78.8)^2)^0.5 = 462.7 kPA
    SIF = 2.473
    Therfore as per ASME B 31.1,
    Stress = 0.75*i*(M/Z)
    M/Z = Stress
    Net Bending at node 18= 435-175.9=259.1kPA
    Net torsion at node 18= 48.8-48.8 = 0
    Therefore, Code stress = 0.75*2.473*259.1 = 480.56kPA
    - But the Code stress in report is 438.2 kPA
    - Pls explain how. I am mistaken somewhere.?
    **Similary At node 19 = Unable to determine how did 205.8 come?
    **But again at node 20, where torsion = 0, SIF=2.473
    Code = 0.75*bending = 0.75*64.2 = 48.1 k PA
    why SIF value is not used here?
    I am also attaching the report file (ELB1.TXT) for your ref.
    Prabhjyot Singh
    Attached Files Attached Files
  1. International Code for Fire Safety Systems (FSS Code)
    By sambun in forum Safety And Environment
    Last Post: 09-30-2016, 01:34 AM
  2. Code Case 2695 and ASME 2010 Code Cases
    By mbc.engg in forum Mechanical Engineering
    Last Post: 05-13-2016, 11:10 AM
  3. Replies: 0
    Last Post: 03-13-2014, 06:31 PM
  4. Need Help for SHELL code and Chinese code for fire protection
    By sumit.alok in forum Safety And Environment
    Last Post: 06-24-2008, 06:08 PM
