Results 1 to 5 of 5
Thread: API Standard 530 Calculation of Heater-tube Thickness in Petroleum Refineries, 7th ed
    Does anyone has the API 530 Calculation of Heater-tube Thickness in Petroleum Refineries, Seventh Edition, April 2015
    This standard specifies the requirements and gives recommendations for the procedures and design criteria used for calculating the required wall thickness of new tubes and associated component fittings for fired heaters for the petroleum, petrochemical, and natural gas industries. These procedures are appropriate for designing tubes for service in both corrosive and noncorrosive applications. These procedures have been developed specifically for the design of refinery and related fired heater tubes (direct-fired, heat-absorbing tubes within enclosures). These procedures are not intended to be used for the design of external piping.
    This standard does not give recommendations for tube retirement thickness; Annex A describes a technique for estimating the life remaining for a heater tube.
    Re: API Standard 530 Calculation of Heater-tube Thickness in Petroleum Refineries, 7t
    please check the below thread:-
    Jul 2009
    Karachi, Pakistan
    Sorry, the provided link is expired...
  7. Re: API Standard 530 Calculation of Heater-tube Thickness in Petroleum Refineries, 7t
    Thank you very much for sharing of this useful document.
  1. DNV standard for thickness calculation
    By hajit in forum Oil And Gas Process
    Last Post: 01-18-2019, 01:43 AM
  2. Calculation of Heater-tube Thickness in Petroleum Refineries
    By Marty Thompson in forum Petroleum Refining
    Last Post: 07-12-2015, 09:51 PM
  3. Shell thickness calculation (residual wall thickness for thermowell)_ASME
    By tenthousand in forum Mechanical Engineering
    Last Post: 05-14-2015, 12:53 PM
  4. ASME: Thickness calculation of ovale/obround tube?
    By wassa in forum Mechanical Engineering
    Last Post: 08-28-2014, 07:31 PM
  5. Guide to thickness calculation of heater tubes
    By ashfaqanwer in forum Mechanical Engineering
    Last Post: 08-22-2010, 02:49 PM
