Thread: API RP 500 question
  1. API RP 500 question
    I couldn't find an explicit statement in NFPA/API about one group reciprocating for another, but would Group B cover Group D? API states that it should list each group that the specific equipment should be rated for if I am reading it right. So it should be listed for Groups B, C & D, not just Group B. Any comments or further data? Thanks!!
    Re: API RP 500 question
    Start in:
  5. Re: API RP 500 question
    Cooper cross hinds - eaton catalogs could clarify.
  6. Re: API RP 500 question
    Some products cover C & D.
    But some one told me that the most volatile component is Acetylene, and the most expensive components for Class I are for Group A.
    If you use a A group component, you could use it for A, B, C & D. If you use a B component you can use it in B, C, D. C rated components can be used for C & D groups. this is Only for Clas I.
    If you use always use A components your design will be very expensive. If you are designing, you must use the specified group component that is rated. If your flamable gas components is rated B, buy B group rated components. If is C group buy C rated components. this is for cost and securty aspects.
  1. CSWIP New Question Pattern and Model Question Paper needed.
    By vijay1583 in forum Mechanical Engineering
    Last Post: 07-26-2012, 10:35 PM
  2. question about PSV
    By javad64 in forum Pipeline And Fluid Flow
    Last Post: 07-01-2010, 06:39 PM
  3. Question
    By sinodas in forum Geology & Exploration
    Last Post: 03-03-2010, 12:03 AM
  4. question?
    By sajja41 in forum Drilling And Workover
    Last Post: 03-01-2010, 08:36 AM
  5. question
    By petro.Senoir student q8 in forum Geology & Exploration
    Last Post: 11-13-2009, 05:29 PM
